DELL inspiron 15-3515 GDM54 LA-L245P bios
  • Kuroneox
    • Feb 2017
    • 24
    • México
    #41
    Dell Inspiron 15 3515
    system disable
    0474D4FF840197F1
    SERVITAG
    4BW08K3
    • hoaca388
      Badcaps
      • Jan 2022
      • 12118
      #42
      system disable
      0474D4FF840197F1
      SERVITAG
      4BW08K3
      Inspiron 15 3515
      Service Tag: 4BW08K3​
      • Carlos Simbaña
        • Jun 2024
        • 31
        • Ecuador
        #43
        Hello, please somebody could repair my bin, all the rails are ok but it has black screen, thanks.
        ST: FBZX3W3
        EX: 33377194227
        BOARD: GDM54 LA-L245P REV 1.0 (A00)
        • Carlos Simbaña
          • Jun 2024
          • 31
          • Ecuador
          #44
          Originally posted by hoaca388
          Inspiron 15 3515
          Please help me
            • 21457
            Originally posted by Carlos Simbaña
            Please help me
            Try the bios at post 36.
            • adssi
              • Jul 2020
              • Argentina
              #46
              Hi! i have this original bios dump, and no video. I cant see the tag service because no have one attached on stick. Please help.
              Regards.
                • 21457
                Regards.
                Try the bios at post 36. Your service tag is J3CZVN3
                • xloomx
                  • Oct 2020
                  • 51
                  • Argentina
                  #48
                  Many people are having BIOS issues with Dell. I have a laptop that gives me a CMOS/Battery error. The Caps Lock key light stays on solid. 1 white light and 3 amber lights. I have RTC lines enabled, Battery OK, and a data loop in the CMOS. Its a Ryzen Machine
                  Dell Inspiron 15 3515 P112F
                  Mother: GDM54 LA-L245P REV 1.0 (A00)
                  2021-07-26
                  ST: HNZ7PS3
                  EX: 38455168323
                  IC: 25Q128JWSQ
                  AMD Ryzen 5 3450U 2.1GHz YM3450C4T4MFG
                  thanks!
                  • norobert
                    • May 2020
                    • 10
                    • argentina
                    #49
                    Hello i have an Inspiron 15 3515 with no image, I think that this bios is corrupted!
                    ST:33WHHK#
                    EX:6766309155
                    BOARD:GDM54 LA-L245P 1.0(A00)
                    here is my dump! Very thanks!!!
                    • pablo_1084
                      • Jun 2017
                      • 11
                      • guatemala
                      #50
                      CAN SOMEONE HELP ME?
                      I HAVE A DELL THAT JUST FLASHES THE SCREEN AND DOESN'T WORK.
                      SERVICE TAG 751BRM3
                        • 21457
                        ST:33WHHK#
                        EX:6766309155
                        SERVICE TAG 751BRM3
                        Try the bios at post 36 from hardware1 ,just enter the service tag at first boot https://www.badcaps.net/forum/troubl...83#post3638983
                        If you want to copy the windows key from your backup to the new bios use a hex editor. Enter these start and end offsets into both C8A000 - C8A03F ,copy from the backup, paste into the new, that`s it.
                        • norobert
                          • May 2020
                          • 10
                          • argentina
                          #52
                          Hello, SMDFLEA, thank you very much for responding to my questions. I did what you mentioned: I took the newBIOS from post #36, modified the Service Tag sector, and also copied the Windows key from my oldbios.bin and pasted the newbios into the address you gave us (C8A000 - C8A03F). I want to tell you that the process didn't work for me at first because it shows that the range of the hexadecimal address array is different, and I don't know if I'm doing something wrong. I've attached an image showing the problem I think I'm having. I'd appreciate it if someone could help me create the newBIOS and explain what my mistake was.
                          ST:33WHHK
                          EX:6766309155
                          • m1ch43lzm
                            • Mar 2019
                            • 634
                            • Peru
                            #53
                            Your hex editor is tricking you by showing 15 columns instead of 16, check software settings
                            ST 33WHHK3
                            Try, BIOS from post 36, added service tag and win key
                            • norobert
                              • May 2020
                              • 10
                              • argentina
                              #54
                              ST 33WHHK3
                              Hi M1ch43lmz, I'm trying again. Can you confirm that the address range for copying and pasting the service tag into the editor is: 0x00 - 0x4B? Thank you so much!
                              • m1ch43lzm
                                • Mar 2019
                                • 634
                                • Peru
                                #55
                                I copied 000-7FF and C8A000-C8A03F from your BIOS to the working BIOS
                                • norobert
                                  • May 2020
                                  • 10
                                  • argentina
                                  #56
                                  My problem was the address. Friend, thanks for your time!
                                  • Haker418
                                    • Sep 2021
                                    • 3
                                    • ukraine
                                    #57
                                    hello friends please help. my dell vostro 3515 shows a black display. help fix the bios
                                    st:7ZLHGJ3
                                    ex:17389879023
                                    ryzen 3 my vers bios 1.28.0
                                    • LBTT1121
                                      • Nov 2024
                                      • 655
                                      • Việt Nam
                                      #58
                                      st:7ZLHGJ3
                                      ex:17389879023
                                      try
                                      • Haker418
                                        • Sep 2021
                                        • 3
                                        • ukraine
                                        #59
                                        Originally posted by LBTT1121
                                        try
                                        Thank you very much, tell me which lines I need to copy from my bios
                                        0000- to ?
                                        • Haker418
                                          • Sep 2021
                                          • 3
                                          • ukraine
                                          #60
                                          0000- to ?
                                          thank friend its works 👍👍👍
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • zlr8r
                                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                            by zlr8r
                                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                            cheers
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                            Attached;
                                            1. My saved bios using a programmer
                                            2. Dells Bios updater .exe (v1.16)
                                            3. Dells Bios recovery file
                                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                            5. Image of ME...
                                            12-18-2023, 03:08 PM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • GadgetsFix
                                            Dell Inspiron 16 5630 BIOS request
                                            by GadgetsFix
                                            I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
                                            • Model: Dell Inspiron 16 5630
                                            • MainBoard Part Number: 4550SC01C004
                                            • Laptop Serial No: GKH3JX3
                                            • DP/N: 0303KM
                                            • QUAKE N RPL UMA CS MB
                                            • 213251-2
                                            • TMN0H$KB
                                            01-17-2025, 07:38 AM
                                          • computerbacon79
                                            Dell Inspiron 3480 All in One corrupt Bios issue
                                            by computerbacon79
                                            The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                                            05-06-2025, 06:43 PM
