ASUS GX501GI clear me issue
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Hi
    I programmed the bios with a dump to try to fix a keyboard problem (the problem was the keyboard ITE controller). Not being a bios problem, I wanted to use the original bios file instead of the dump by doing a clear me first but MEanalyzer returns an error "File does not contain an intel engine firmware". So I wanted to leave the non-original dump but since it had a startup delay I tried a clear me but the file read with a programmer returns the same error as the original. The dumps before being programmed are regularly read with meanalyzer.
    GX501GI from board = working bios read from motherboard
    GX501GI orignal = original bios dump
    GX501GI bios test = a working dump from internet
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: ASUS GX501GI clear me issue
    Originally posted by jasko_jacker
    Hi
    Here's your Clean Bios, try it.
    The other 2 files have no ME Region nor Bios Region (only Flash Descriptor), I think your read the chip in a wrong way.
    I don't know if you have lost your Original Bios or there is still a chance.
    all donations are welcome,
      • 22279
      Hi
      Seem like the bios chip is losing data, or your programmer is failing for some reason, the backups are corrupt,mostly all FF`s
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • bestrafer
        Lenovo L460 LAN issue after BIOS dump flash
        by bestrafer
        Hello everyone.
        I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
        BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
        But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
        Could someone point on a direction...
        01-31-2023, 01:14 PM
      • Syph1979
        PS5 EDM-031 1216A BIOS Issue
        by Syph1979
        Hi all. First post here, so I hope I'm getting this right and operating in the spirit of things here.
        I've been working on consoles for a while now. Always learning and trying new repairs, but I have one that has been stumped and I wondered if anyone with more experience could help?
        I picked up a PS5 from eBay recently. It was described as not having the disc drive, but it was also a no power unit. On testing it was clearly an issue with the supply (no 12v), so I replaced that and then when I inserted the power lead, I got 3 beeps. So far, seems all related. As I was...
        09-25-2025, 05:48 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
