Need asus m433d bios dump
  • bilen
    • Aug 2014
    • 632
    • istanbul
    no screen.
    motherboard code x421da rev 2.0
    old dump :
  • hardware1
    • Sep 2021
    • 2925
    • N/A
    Re: Need asus m433d bios dump
    Originally posted by bilen
    no screen.
    old dump :
    Model Number: M433DA-HM247T.
    Serial Number: L9N0CX03J096377.
    If the previous information are identical with yours, you should have another Bios chip and you must upload it too. It could be 4M (32Mbit).
    all donations are welcome,
    • bilen
      • Aug 2014
      • 632
      • istanbul
      no there is no other bios chip.
      device with a built-in amd gpu this is not possible.
      The serial number and other information are deleted from the bottom of the safe, I can't read it.
        • 20643
        Its an AMD bios,they are usually smaller in size than intel bios, DMI starts at 21000 .The QR code sticker doesn`t have the model number on it and its not on a barcode sticker either,you can get the update/full image from asus support https://www.asus.com/supportonly/m433da/helpdesk_bios/
        AMD bios`es are weird,sometimes they start with code at the top and other start with a bunch of FF`s
        • bilen
          • Aug 2014
          • 632
          • istanbul
          yes that's right thanks. but it gives 8194 kb how do I shrink it to original size. I have RT809F machine and it gives error
            • 20643
            With HxD ,delete offset 0 - 800 and save,or open with UEFITool and select "Action -> Capsule -> Extract Body" .It does have a CAPsule header even though the file extension is .302 (for the latest bios version) and not .CAP
            The DMI (i think) is at these offsets 21000 - 26BFF Length: 5C00 .Finding the start and end offsets is trial and error.If you can`t do it let us know and someone will help.
            • bilen
              • Aug 2014
              • 632
              • istanbul
              thank you. working is machine
                • 20643
                • hardware1
                  • Sep 2021
                  • 2925
                  • N/A
                  I'm already downloaded that file, but I was thinking it's just a Bios Region because it's much similar to the beginning of it. Also when I searched for the device specs, I saw Intel CPU somewhere
                  Next time will be more precise, Thanks for explanation.
                    • 20643
                    I know what you mean,it does look like a bios region.
                    • bilen
                      • Aug 2014
                      • 632
                      • istanbul
                      keyboard backlight not working. What can I do for it ?
                        • 20643
                        Try this one,its the virgin bios + your DMI. If the backlight isn`t working after the that i don`t know what to suggest. I don`t know if there`s a newer version of the Asus block trasmit tool to fix the backlight.
                        • cacla
                          • Apr 2015
                          • 442
                          By sn this is your bios i will attach tool soon i am out of office
                          • mich1982
                            • Oct 2014
                            • Ghana
                            [QUOTE=cacla;1200725]By sn this is your bios i will attach tool soon i am out of office[/QU
                            Please, can you post the tool here
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • DynaxSC
                              by DynaxSC
                              06-14-2024, 03:49 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • Anchar777
                              ASUS P1412CE need BIOS DUMP
                              by Anchar777
                              Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                              06-26-2025, 03:39 AM
