HP Envy 13 #13-d006nl dump bios
  • shybear
    • Jan 2010
    • 96
    hi,
    I need dump bios for this HP Envy model 13-d006nl.
    Mainboard is ASE30 LA-C482P Rev.:1.0
    Thnaks in advance for help
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    Re: HP Envy 13 #13-d006nl dump bios
    dumps ok
    • shybear
      • Jan 2010
      • 96
      [QUOTE=aboumohamed;1198600]dumps ok [/QUOTE
      in the archive there are 4 files:
      080E9.bin
      080E6.bin
      080DA.bin
      080D7.bin
      How can I find the right file?
      I've seen there is a rear label with Build ID and Feature Byte numbers.
      Anyway I attach here the backup copy of the installed BIOS.
      • hardware1
        • Sep 2021
        • 2894
        • N/A
        [QUOTE=shybear;1198842]
        Originally posted by aboumohamed
        dumps ok [/QUOTE
        080E9.bin
        080E6.bin
        080DA.bin
        080D7.bin
        Here's your New bios file, it's a virgin bios from HP with your DMI and Windows Key.
        Serial Number: CND5423PQZ.
        all donations are welcome,
        • shybear
          • Jan 2010
          • 96
          [QUOTE=hardware1;1198844]
          Yeah perfect one, at first boot I got a blue windows with flash upgranding and next to reboot it started properly.
          Just a thing:
          when it start it show for few seconds this message at top of screen:
          "Manifacture Programming Mode is in Unlock Mode"
          is there a way to fix it?
          Thanks so much !!!!
          • hardware1
            • Sep 2021
            • 2894
            • N/A
            [QUOTE=shybear;1199155]
            Just a thing:
            Thanks so much !!!!
            After the counter finish (Boot times) the message will gone, or you can use a tool called (BCU) to lock the MPM.
            • shybear
              • Jan 2010
              • 96
              [QUOTE=hardware1;1199159]
              I tried to boot at least 20 times without success so following your tips I found the HP Bios Configuration Tool so I was able to lock the MPM setting.
              • dowent88
                • Sep 2023
                • 6
                • MOROCCO
                [QUOTE=hardware1;n1745270]Re: HP Envy 13 #13-d006nl dump bios
                please, i need a working bios file for this model HP ENVY - 13-d016nl (ENERGY STAR) motherboard ASE30 LA-C482P REV 2.0 ( 2015-10-14 )
                Serial number is CND60344CV
                I HAVE TRY Many bios files but the laptop turn on and no picture and the CAPS LOCK button on the keyboard blinking
                my original bin file is here
                Thank you in advance...​
                • peste
                  • Dec 2016
                  • 12254
                  • ROMANIA
                  [QUOTE=dowent88;n3640597]
                  you have everything you need at post #3
                  https://www.badcaps.net/forum/troubl...14#post1758260
                  • dowent88
                    • Sep 2023
                    • 6
                    • MOROCCO
                    [QUOTE=peste;n3640618]
                    NONE WORKING SAME PROBLEM
                    • peste
                      • Dec 2016
                      • 12254
                      • ROMANIA
                      [QUOTE=dowent88;n3640621]
                      Maybe the laptop has another problem...
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • Kenzi
                        Cannot modify HP Envy 15 ep-00008na BIOS
                        by Kenzi
                        I'm trying to modify my BIOS to unlock the advanced menus and unlock the processor power limits. The first thing I have tried is reading the BIOS from the laptop and opening it up in amibcp, and changing the advanced menu to User. However, no matter what tiny change I make to the BIOS, when I flash it back to the laptop with a programmer it says there is corruption and the BIOS needs to be recovered.
                        I've also tried rolling back the BIOS to an older version. I made the mistake of updating to the latest version and now I cannot even edit the CFG and OC...
                        11-09-2023, 05:22 AM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • grimacelord
                        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                        by grimacelord
                        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                        Motherboard model number: DA0PAMB46A1 REV: A
                        Secondary motherboard model number: 0PAB
                        SKU: 685K4UA
                        Serial number is: 5CD3223BJP
                        Recently reflashed this laptop with latest BIOS and once...
                        05-07-2024, 08:06 AM
                      • DynaxSC
                        Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                        by DynaxSC
                        I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                        It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                        I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                        11-06-2022, 05:22 PM
