HP Elitebook 845 G8
  • JersonP
    • Mar 2020
    • 29
    • mozambique
    HP Elitebook 845 G8
    please clean me
  • hoaca388
    Badcaps
    • Jan 2022
    • 11691
    Re: HP Elitebook 845 G8
    Originally posted by JersonP
    please clean me
    Bios for AMD cpu have no ME region.
    • aminealae
      • Jun 2013
      • 97
      • morocco
      hello all friand please i need your help bios locked Elitebook 845 G8
      • alfredposadas09
        • Aug 2020
        • 343
        • Philippines
        here try it and give me feedback
        • hirens
          • May 2022
          • 177
          • uganda
          hello guys, hope your festive seasons are well.
          kindly help me fix my bios, am pretty sure my bios region has a problem.
          the machine powers on then brings the bios update screen and it goes off.
          its a repetitive sequence
          i think machine was updating and it lost power
          sn:5cg1243tq1
          hp elitebook 845 g8
          attached is the backup
          • hoaca388
            Badcaps
            • Jan 2022
            • 11691
            sn:5cg1243tq1
            hp elitebook 845 g8
            Here you are
            • bauteile24
              • Feb 2018
              • Deutschland
              hi, can you help fix my 845 G8 (AMD)?
              SN:5cg13220IK
              • hoaca388
                Badcaps
                • Jan 2022
                • 11691
                SN:5cg13220IK
                HP EliteBook 845 G8_AMD
                • duong.160694@gmail.com
                  • Nov 2017
                  • 19
                  • viennam
                  hi, can you help fix my 845 G8 (AMD)? NO DISPLAY
                  LANCIA13/Grizzly2.0-6050A3234201-MB-A0 (A1)
                  SN#5CG2433YC2
                  Proid 54W37UP#ABA
                  • shiyab
                    • Sep 2023
                    • 1366
                    • india
                    SN#5CG2433YC2
                    Proid 54W37UP#ABA
                    hi try
                    • truongvannay
                      • Vietnamese
                      hi, can you help fix my 845 G8 (AMD)? erro endpoint security controller problem
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11691
                        Add serial number to post.
                        • truongvannay
                          • Vietnamese
                          Thank ad. SN:
                          5CG21553FH
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11691
                            Thank ad. SN:
                            5CG21553FH
                            Endpoint security controller problem.
                            • jagg
                              • Feb 2012
                              • 25
                              • Mexico
                              Hi, can someone help me with the BIOS of the HP Elitebook 845 G8, it turns on but doesn't give an image, thanks!!
                              mainboard: lancia13/grizzli 2.0-6050a3234201-mb-a1
                              ProdID: 61H99UC#ABA
                              SN# 2TK23001Y1
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11691
                                ProdID: 61H99UC#ABA
                                SN# 2TK23001Y1
                                HP EliteBook 845 G8 Notebook PC Bundle (61H99UC)
                                • jagg
                                  • Feb 2012
                                  • 25
                                  • Mexico
                                  Hello, thanks for the help. I programmed the BIOS, but the same error persists. I turn on the laptop, but only the fan spins quickly and it still has no imag and the caps lock doesn't work. If I remove the memory, the laptop beeps. Could the problem be caused by something else?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11691
                                    Maybe !
                                    • Gabriel7
                                      • Mar 2014
                                      • 8
                                      • Greece
                                      Hello. I have serial number 5CG15048BF - HP 845 G8. Can you please help me with a bios for this? Thank you.
                                      • lapfix
                                        • Mar 2020
                                        • 2719
                                        • my workshop
                                        Upload your bios even his corrupted
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                        • dr_crx
                                          Dell 7740 Bios locked J3JSD43-8FC8
                                          by dr_crx
                                          Hello i need help please
                                          i have DELL 7740 ST: J3JSD43-8FC8
                                          i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                          anyone can help to show its location on motherboard please.
                                          i attached the results file the IC i read is : winbond 25q80dvsig
                                          i don't know if its the needed bios or another bios on the motherboard.
                                          thank you in advanced for your help...
                                          07-11-2025, 12:22 AM
                                        • moshu
                                          HP EliteBook 755 G4 bios password locked
                                          by moshu
                                          Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
                                          I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
                                          Can you please help to remove the password?
                                          after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
                                          HP EliteBook 755 G4
                                          ProdID: W5Q98AV
                                          SN: 5CG7524BY4...
                                          02-01-2025, 06:59 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • fulaphex
                                          Lenovo Thinkpad X13 Gen 3 AMD locked bios
                                          by fulaphex
                                          hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                                          I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                                          07-09-2025, 07:04 PM
