Chuwi Herobook Pro bios password
  • minuccio88
    • Dec 2022
    • 10
    • Italia
    I have a Herobook Pro JHeroBP256G201010862, the motherboard is X133GRX170-G60E.
    When i turn on the laptop there is a bios password request, someone can help me? I need or a bios dump or a bios unlocked
    I attached some photo and also the bios locked
    Thanks so much
  • peste
    • Dec 2016
    • 12806
    • ROMANIA
    Re: Chuwi Herobook Pro bios password
    Originally posted by minuccio88
    Thanks so much
    keep an eye on the board, maybe you still have a bios chip..
    • minuccio88
      • Dec 2022
      • 10
      • Italia
      Hi, thanks for the answer, but i don't understand what do you mean, i need to unlock the bios from the password, i have tried everything. I think the only way to solve the problem is to flash bios with one not locked or if someone can dremove the password i have attached the locked one
      • peste
        • Dec 2016
        • 12806
        • ROMANIA
        I think there is still a bios chip on the board.. look for it and if it is, post its content,,
        • hardware1
          • Sep 2021
          • 2930
          • N/A
          As you can see in the Images, your chip should be one of those Packages.
          all donations are welcome,
          • minuccio88
            • Dec 2022
            • 10
            • Italia
            Hi, Thank you so much for the answer, i have found the chip GigaDevice 25LB64CV (image attached) but i can't read it with ch341a, i think it isn't supported chip, it isn't in ch341a list
            • hardware1
              • Sep 2021
              • 2930
              • N/A
              It's a 1.8V Chip as mentioned in the datasheet, you need to use an adapter with the CH341A. I don't know if the Programmer support that chip or Not, also it's better to Desolder the chip (Don't use a clip).
              • minuccio88
                • Dec 2022
                • 10
                • Italia
                Hi, yes i have used the adapter 1.8V for the ch341a and i have desolder the chip but it don't work, i will try with XGecu T48, the chip is in the device support list of the T48 programmer
                • minuccio88
                  • Dec 2022
                  • 10
                  • Italia
                  Hi guys, finally i have read the bios correctly with the new programmer, i hope some one can help me to unlock the bios password
                  Thanks to everyone
                  • hardware1
                    • Sep 2021
                    • 2930
                    • N/A
                    Thanks to everyone
                    Here's your Unlocked Bios, hope it works fine.
                    Note: Your Backup was 3KB (C00h) Larger.
                    • minuccio88
                      • Dec 2022
                      • 10
                      • Italia
                      Sorry for the delay in my reply, today i have flashed the bios, it's work fine, thanks so much cheers:
                      • hardware1
                        • Sep 2021
                        • 2930
                        • N/A
                        You're Welcome.
                        • minuccio88
                          • Dec 2022
                          • 10
                          • Italia
                          Sorry for the delay in my reply, today i have flashed the bios, it works fine, thanks so much
                          • adiasterix81
                            • Aug 2017
                            • 36
                            • Romania
                            can you remove password from my bios too? please
                            • peste
                              • Dec 2016
                              • 12806
                              • ROMANIA
                              try...
                              • adiasterix81
                                • Aug 2017
                                • 36
                                • Romania
                                many thanks. It worked perfectly
                                • adiasterix81
                                  • Aug 2017
                                  • 36
                                  • Romania
                                  may I ask, what software did you use to remove the password?
                                  • montalesd
                                    • Jul 2023
                                    • 3
                                    • Philippines
                                    Hi sir how to reset bios to default chuwi hero book pro.
                                    • montalesd
                                      • Jul 2023
                                      • 3
                                      • Philippines
                                      After I dissamble the laptop chuwi hero book pro the screen dissappear all black bu when i connect it to minotor i has display. I research on youtube same issue it tells that it needed to reset the bios the problem is i dont have bios to flash. I have only Ezp2019 programmer
                                        • 20898
                                        If you didn`t disconnect the battery before you removed the screen cable you have damaged the motherboard,connector,cable and/or the screen. As its working ok with an external monitor it means the bios is ok.
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          Ack
                                          Ack
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
                                        • BlackVisor
                                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                          by BlackVisor
                                          RedmiBook Pro 1542022 6800H
                                          SKU: TM2113-39463
                                          Model Number: RMA2204-AB
                                          CMIIT ID: 2022AP1835
                                          SN: 39463/22WD01355
                                          BIOS version: RMARB5B0P1010 20230628
                                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                          01-14-2024, 06:35 AM
