Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Chuwi Herobook Pro bios password
  • minuccio88
    • Dec 2022
    • 13
    • Italia
    I have a Herobook Pro JHeroBP256G201010862, the motherboard is X133GRX170-G60E.
    When i turn on the laptop there is a bios password request, someone can help me? I need or a bios dump or a bios unlocked
    I attached some photo and also the bios locked
    Thanks so much
    Premium supporters get full download access and other benefits.
  • peste
    • Dec 2016
    • 15894
    • ROMANIA
    Re: Chuwi Herobook Pro bios password
    Originally posted by minuccio88
    Thanks so much
    keep an eye on the board, maybe you still have a bios chip..
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
    It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • minuccio88
      • Dec 2022
      • 13
      • Italia
      Hi, thanks for the answer, but i don't understand what do you mean, i need to unlock the bios from the password, i have tried everything. I think the only way to solve the problem is to flash bios with one not locked or if someone can dremove the password i have attached the locked one
      • peste
        • Dec 2016
        • 15894
        • ROMANIA
        I think there is still a bios chip on the board.. look for it and if it is, post its content,,
        • hardware1
          • Sep 2021
          • 2956
          • N/A
          As you can see in the Images, your chip should be one of those Packages.
          all donations are welcome,
          • minuccio88
            • Dec 2022
            • 13
            • Italia
            Hi, Thank you so much for the answer, i have found the chip GigaDevice 25LB64CV (image attached) but i can't read it with ch341a, i think it isn't supported chip, it isn't in ch341a list
            • hardware1
              • Sep 2021
              • 2956
              • N/A
              It's a 1.8V Chip as mentioned in the datasheet, you need to use an adapter with the CH341A. I don't know if the Programmer support that chip or Not, also it's better to Desolder the chip (Don't use a clip).
              • minuccio88
                • Dec 2022
                • 13
                • Italia
                Hi, yes i have used the adapter 1.8V for the ch341a and i have desolder the chip but it don't work, i will try with XGecu T48, the chip is in the device support list of the T48 programmer
                • minuccio88
                  • Dec 2022
                  • 13
                  • Italia
                  Hi guys, finally i have read the bios correctly with the new programmer, i hope some one can help me to unlock the bios password
                  Thanks to everyone
                  • hardware1
                    • Sep 2021
                    • 2956
                    • N/A
                    Thanks to everyone
                    Here's your Unlocked Bios, hope it works fine.
                    Note: Your Backup was 3KB (C00h) Larger.
                    • minuccio88
                      • Dec 2022
                      • 13
                      • Italia
                      Sorry for the delay in my reply, today i have flashed the bios, it's work fine, thanks so much cheers:
                      • hardware1
                        • Sep 2021
                        • 2956
                        • N/A
                        You're Welcome.
                        • minuccio88
                          • Dec 2022
                          • 13
                          • Italia
                          Sorry for the delay in my reply, today i have flashed the bios, it works fine, thanks so much
                          • adiasterix81
                            • Aug 2017
                            • 43
                            • Romania
                            can you remove password from my bios too? please
                            • peste
                              • Dec 2016
                              • 15894
                              • ROMANIA
                              try...
                              • adiasterix81
                                • Aug 2017
                                • 43
                                • Romania
                                many thanks. It worked perfectly
                                • adiasterix81
                                  • Aug 2017
                                  • 43
                                  • Romania
                                  may I ask, what software did you use to remove the password?
                                  • montalesd
                                    • Jul 2023
                                    • 3
                                    • Philippines
                                    • Repair mobile and computer board level
                                    Hi sir how to reset bios to default chuwi hero book pro.
                                    • montalesd
                                      • Jul 2023
                                      • 3
                                      • Philippines
                                      After I dissamble the laptop chuwi hero book pro the screen dissappear all black bu when i connect it to minotor i has display. I research on youtube same issue it tells that it needed to reset the bios the problem is i dont have bios to flash. I have only Ezp2019 programmer
                                        • 24945
                                        If you didn`t disconnect the battery before you removed the screen cable you have damaged the motherboard,connector,cable and/or the screen. As its working ok with an external monitor it means the bios is ok.
                                        • chriswfrye21
                                          HP 255R G10 – BIOS Admin Password Locked, Cannot Enter BIOS (Need Guidance / SMC.bin Help)
                                          by chriswfrye21
                                          I’m working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
                                          This is not a Power‑On Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
                                          I’m posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
                                          Model: HP 255R 15.6 inch G10 Notebook PC SK...
                                          08-10-2026, 03:49 AM
                                        • Olegst44
                                          Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
                                          by Olegst44
                                          I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
                                          Device Information:
                                          - Model: Acer Aspire 3 A315-22G
                                          - Motherboard: NB8607G02-MB (Compal LA-J761P)
                                          - BIOS Chip: Winbond W25Q64 (8MB)
                                          - Serial: NXHE7ER00X95002B784S00
                                          Problem:
                                          - BIOS is password protected (Supervisor Password)
                                          - Boot from USB is disabled in BIOS
                                          - After 3 wrong password attempts, system shows Unlock Key Hint
                                          - I have RT809H programmer available
                                          What I need:
                                          1. Clean BIOS dump (password...
                                          04-11-2026, 05:36 PM
                                        • TomBob71
                                          HP zBook Ultra G1a 14 Bios - Password Locked
                                          by TomBob71
                                          Please help with attempting to unlock the bios password for this laptop. I attempted to use the RCUnlocker but is said it did not support my 32mb sized file. I read the chip with a t48 and included the default saved .bin and the flash saved .bin.
                                          Chip: Winbond 25Q256JWEN
                                          ProdID: AY8K2AV
                                          S/N: 2MQ54212XY
                                          Motherboard appears to be HSTNS-I001MB2...
                                          06-15-2026, 02:07 PM
                                        • Gad007
                                          Locked bios password getac s410
                                          by Gad007
                                          I’m working on a small technical challenge and could really use some guidance from people more experienced in BIOS/EEPROM work 🙂
                                          I picked up a old rugged laptop (Getac S410) for $50 at a garage sale. The seller warned me it was locked with a BIOS password (prompt appears immediately at power-on, before any BIOS/UEFI access).
                                          My end goal is to turn this machine into a dedicated automotive diagnostic PC, so I’m trying to unlock it rather than scrap it.
                                          What I’ve done so far:
                                          Fully disassembled the laptop
                                          03-31-2026, 11:21 AM
                                        • marcolinha
                                          LG All-in-One 22V240 BIOS Password Locked - Unlock Key Hint Number Z5DD4808 - Need Help
                                          by marcolinha
                                          I need help unlocking the BIOS password on my LG All-in-One 22V240.
                                          Model: LG All-in-One 22V240
                                          Background: I received this PC as a gift when I was a child. I left
                                          it unused for years after upgrading to a better machine. Now I want
                                          to give it a new life by installing Linux, but I cannot format it
                                          because of this BIOS password lock. I have no idea who set the
                                          password or when.
                                          Important: The Unlock Key Hint Number changes every boot (dynamic).
                                          Examples of hint numbers I have seen:
                                          - Z5DD4808
                                          - C649CBC7
                                          06-06-2026, 03:06 PM
