HP 15s-fq1906ng DA0P5DMB8C0 REV:C
  • REpairAT
    • Nov 2020
    • 143
    • Austria
    got a job with corrupted BIOS.
    Tried to clean ME by myself, no luck, still no picture.
    Notebook works with file from here https://www.badcaps.net/forum/showthread.php?t=106671
    Now it boots, but missing DMI Information.
    Could someone please fix my original dump? Thanks a lot!
    Model: 15s-fq1906ng
    Board: DA0P5DMB8C0 REV:C
    SN. #5CD0281XQX
  • lapfix
    • Mar 2020
    • 2756
    • my workshop
    Re: HP 15s-fq1906ng DA0P5DMB8C0 REV:C
    Try
    • REpairAT
      • Nov 2020
      • 143
      • Austria
      Thanks, but does not work, like my own file with clean ME.
      I assume a corrupt BIOS, not ME area.
      Thanks!
      • lapfix
        • Mar 2020
        • 2756
        • my workshop
        try the one you listed , just copy your DMI
        480000 - 4800FF
        • REpairAT
          • Nov 2020
          • 143
          • Austria
          480000 - 4800FF
          Thanks, notebook boots but now shows "Manufacture programming mode is in unlock mode"
          • hoaca388
            Badcaps
            • Jan 2022
            • 12268
            DMI missing.
            • lapfix
              • Mar 2020
              • 2756
              • my workshop
              Try hoac bios , if stil your issue than look at this tuto
              https://www.youtube.com/watch?v=9T57ktw8n3Y
              • REpairAT
                • Nov 2020
                • 143
                • Austria
                Also no POST with this file, I will check out the vid, thanks!
                • m1ch43lzm
                  by m1ch43lzm
                  Hi everyone
                  09-06-2025, 05:47 PM
                • backdoorsecurity
                  p51 uefi chip diagnosis
                  by backdoorsecurity
                  hey all i was messing around with digmorepakas thinkpad firmware advanced menu patches without success "resulted in black screen". i could flash modded file then flash the backup if needed. it got late so i put the p51 away and forgot about it for a month. i recently pulled it back out, flashed the backup file and it blackscreened. "screen turns on no splash". i had originally made 3 backups and diffed them, file integrity was good. i downloaded the files i could find on this site and it boots to splash then boots os but takes about 5-7 minutes to reach splash. i am trying...
                  07-20-2025, 08:27 PM
                • Forest79
                  by Forest79
                  07-23-2023, 07:39 AM
                • wwbielsko
                  Dell latitude 5320 corrupted bios repair
                  by wwbielsko
                  I got corrupted bios bin file, which way is correct to repair.
                  File puts errors on Me Analyzer and cannot open in FIT.
                  To open in FIT I made:
                  1. Extract MFS and EFS using MEAnalyzer from other bios file with the same parameters
                  2. put it in HxD to my file
                  3. MEAnalyzer shows 1 error after that
                  4. file opens in FIT
                  and:
                  A:
                  1. extract current dell bios on website
                  2. put System BIOS with BiosGuard v1.30.0.bin using FIT
                  3. MEAnalyzer OK no errors
                  (this version shows only logo at bootup - freezeing)...
                  04-23-2024, 06:16 PM
                • hazem3636
                  need Bios Bin file Dell server 220
                  by hazem3636
                  hi everyone
                  i need dump file for dell server r220
                  i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                  i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                  if anyone has this method please need his supporting .
                  all the best
                  EXE file is attched and Original Bin file from the Bios Chip is attached also
                  and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                  11-05-2022, 06:20 AM
