hey all i was messing around with digmorepakas thinkpad firmware advanced menu patches without success "resulted in black screen". i could flash modded file then flash the backup if needed. it got late so i put the p51 away and forgot about it for a month. i recently pulled it back out, flashed the backup file and it blackscreened. "screen turns on no splash". i had originally made 3 backups and diffed them, file integrity was good. i downloaded the files i could find on this site and it boots to splash then boots os but takes about 5-7 minutes to reach splash. i am trying to figure out if problem lies in the chip itself or corrupted files. my backups are exact same size as ones i downloaded here but "file downloaded .bin original-backup.bin" show binary files differ. i tried flashing downloaded file then updating bios but same problem. does anyone have a file i could test? password or no password i would just like to try a couple more to rule out corrupted files. here is my specs: MACHINE MODEL NUMBER: 20HH000YUS, CIRCUIT BOARD NUMBER: DP510 NM-B041 (REV1.0) i added one of my backup files below.
p51 uefi chip diagnosis
Tags: None
post snidhey all i was messing around with digmorepakas thinkpad firmware advanced menu patches without success "resulted in black screen". i could flash modded file then flash the backup if needed. it got late so i put the p51 away and forgot about it for a month. i recently pulled it back out, flashed the backup file and it blackscreened. "screen turns on no splash". i had originally made 3 backups and diffed them, file integrity was good. i downloaded the files i could find on this site and it boots to splash then boots os but takes about 5-7 minutes to reach splash. i am trying to figure out if problem lies in the chip itself or corrupted files. my backups are exact same size as ones i downloaded here but "file downloaded .bin original-backup.bin" show binary files differ. i tried flashing downloaded file then updating bios but same problem. does anyone have a file i could test? password or no password i would just like to try a couple more to rule out corrupted files. here is my specs: MACHINE MODEL NUMBER: 20HH000YUS, CIRCUIT BOARD NUMBER: DP510 NM-B041 (REV1.0) i added one of my backup files below.
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by NoRelaxGood day,
In my hands I have a Thinkpad T14 gen 1 (20UD002BIX) showing sporadic BSOD issues caused by failing onboard soldered RAM. I suspect disabling the onboard RAM via a bios mod would do the trick.
The laptop has already the latest updates as well as latest bios 1.51 as of today.
I informed myself in an attempt to DIY my way to victory but it left me with more questions than answers. This is not a BIOS request, what I really need is somebody to verify that the following procedure is correct.
Step 1: grab a bios image:
- Method 1: from the official website:... -
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
