bios dump please
Asus ROG G513QR Amd
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
Re: Asus ROG G513QR Amd
2021 ROG Strix G15Attached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
I said 'hi' in the main welcome thread, but I still can't post a new thread. That's why I'm asking for help here.
I'm looking for an older BIOS version for my laptop, the 2021 ROG Strix G15 G513QR. I need version 316 or older, but I can't seem to find it anywhere.
Thanks!Comment
hello,
i said 'hi' in the main welcome thread, but i still can't post a new thread. That's why i'm asking for help here.
I'm looking for an older bios version for my laptop, the 2021 rog strix g15 g513qr. I need version 316 or older, but i can't seem to find it anywhere.
Thanks!Attached FilesComment
after replacing the controller, the keyboard backlight does not work,
looking for firmware it8252e248a
Version 331 Attached FilesComment
Hi, please need help for my Asus g17
Motherboard is
G533- 6050A3250201 -MB-A02(A2)
keybord not working and rgb ligth ok
it8252e.bin
1 PhotoComment
Hello, can you update my bios with the original version please, my laptop does not display anything on the screen and the eeprom is well supplied in 1V8, I think the bios is corrupted, I attach the original one recovered on the site thank you for your help
I don't know how to convert 331 format to bin format
I tried post 4 it didn't work for me
For Asus G513QR
SN : MANRKD01131G6417Attached FilesLast edited by madjid911; 03-09-2025, 08:52 AM.Comment
For Asus G513QR
SN : MANRKD01131G6417Attached FilesComment
the bios posted is empty...
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
Every donation made will go towards server fees and maintenance costs.Comment
hi me again passwort remove please
N9NRKD021302361
asus G513QR
6050A3250202-MB-A01Attached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
- Loading...
