asus X403FA rev:2.1 bios
  • Marc97
    • Jan 2016
    • 189
    • Phillipines
    hello happy newyear,,, someone who have bios bin for this,,,
    i download bios on asus website,,, ez file exceed on 16384mb,,,
    thank you
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    Re: asus X403FA rev:2.1 bios
    try
    • Marc97
      • Jan 2016
      • 189
      • Phillipines
      Originally posted by aboumohamed
      try
      thank you sir i will update u,,, for the result
      • Marc97
        • Jan 2016
        • 189
        • Phillipines
        try
        un success,,, but a good result on your file,,, light indicator on charging battery comes out,,,,, but still no power,, all volts present,,, i have download the asus EZ FILE,,, i cant remove cap,, thnx for some help
          • 22182
          The bios at post #2 is an F1 asus service bios. Post your laptop serial number ,your original bios backup and a picture of the white QR code sticker on the motherboard.
          The files you posted from asus are only bios updates not a full image.Open one with a hex editor, at the top you`ll see the word AMIPFAT , you can remove the PFAT header using AMI BIOS Guard extractor https://github.com/platomav/BIOSUtil...uard-extractor .It will still need editing to the correct size using a hex editor after the header is removed.The update is 10MB.
          • Marc97
            • Jan 2016
            • 189
            • Phillipines
            thank you sir for your time,,, i recieve the unit second touch from other tech,,, my unit casing was faded serial i only view model on casing A403F motherboard number X403FA REV.2.1
            • Marc97
              • Jan 2016
              • 189
              • Phillipines
              back up,,,readed file from ic,,, back-up from second touch,,, no light indicator on charge
                • 22182
                Post a good clear picture of the white QR code label on the motherboard, below the metal ram cover
                • Marc97
                  • Jan 2016
                  • 189
                  • Phillipines
                  thank you so much!
                  • Marc97
                    • Jan 2016
                    • 189
                    • Phillipines
                    cant upload image
                    • qonma
                      Kuli Solder
                      • Jun 2017
                      • 185
                      • INDONESIA
                      need to but bios size 8MB, please help
                      thanks
                      • qonma
                        Kuli Solder
                        • Jun 2017
                        • 185
                        • INDONESIA
                        original bios
                        x403fa rev 2.1
                        please help
                        • peste
                          • Dec 2016
                          • 13834
                          • ROMANIA
                          Originally posted by qonma
                          original bios
                          x403fa rev 2.1
                          please help
                          read this..
                          post the s/n, clear pictures with white stickers from the ram memory area...
                          • Bryan1892
                            • Nov 2020
                            • 19
                            • Philippines
                            hello everyone please help me this bios
                            x403fa revision 2.1
                            the laptop has no sign of light years that not used maybe a frozen bios
                            thank you appreciate your effort
                              • 22182
                              x403fa revision 2.1
                              Please type the serial number that is on the base cover sticker
                              • razor_amd
                                by razor_amd
                                12-15-2020, 07:07 PM
                              • pirati
                                by pirati
                                10-27-2025, 04:20 PM
                              • grimacelord
                                by grimacelord
                                07-10-2025, 02:52 PM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • throwaway327
                                by throwaway327
                                Model No: RC72LA
                                Serial No: SBNVKD001014459
                                06-18-2025, 05:52 PM
