Asus a555uj bİos need
  • Kitayu
    • Oct 2021
    • 22
    • Turkey
    my device draws 0.10 A current, the lights are on, but the screen does not turn on. CPU gets very little hot. (hard to really feel) I copied and backed up the bios and deleted and reinstalled. It drew a current of 0.60 A, the fan turned, but this only happened once. I'm pretty sure the problem is the bios.
    mainboard model : a555uj rev 2.0
    my bios :
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Re: Asus a555uj bİos need
    Originally posted by kitayu
    my device draws 0.10 a current, the lights are on, but the screen does not turn on. Cpu gets very little hot. (hard to really feel) i copied and backed up the bios and deleted and reinstalled. It drew a current of 0.60 a, the fan turned, but this only happened once. I'm pretty sure the problem is the bios.
    Mainboard model : A555uj rev 2.0
    my bios :
    try if posted bios backup is orignale
    • Kitayu
      • Oct 2021
      • 22
      • Turkey
      doesnt worked
      • J_PH
        • Dec 2022
        • 37
        • Chile
        Try this
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • lrouw84
          Asus vivobook s510ua bios changed to x510un
          by lrouw84
          Hi there,
          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
          01-28-2023, 01:31 PM
