hp 830 g5 no power
  • mo000
    • Nov 2017
    • 276
    • algeria
    hp 830 g5 no power
    hi!
    hp 830 g5 no power no led
    i can't find schematic or boardview
    no short
    i tried to change all power mosfets but i always get 0.24v .
  • mon2
    • Dec 2019
    • 14106
    Re: hp 830 g5 no power
    See attached. Fix up the SOT-23 device so it is properly on the logic board.
    1) What are the topside markings on this mosfet ?
    2) which charger IC is onboard this logic board ?
    3) Share all white silk screened markings on the logic board. Could not find anything in my schematic database with '830'.
    • mo000
      • Nov 2017
      • 276
      • algeria
      the SOT-23 i fix it i touch it when i change the mosfet .
      1- 21307 p channel mosfet
      2-i can't find it .
      3-motherboard number 6050A2930901-MB-A01 .
      • mustangank
        • Jun 2021
        • 27
        • Türkiye
        I couldn't find the schematic.
        I have the same problem with my motherboard, did you solve the problem?
        • motanya
          • Nov 2021
          • 160
          • Kenya
          This laptop does not power on, voltages as attached in the pictures below. Behind mosfet Q6000 I have 19v, 0v if measured in front(3 leg and gate), if i short the mosfet the laptop turns on, I have changed the mosfet it works fine on a different motherboard, I have also changed the charging ic intersil 9538h, same result. No short to ground exists within the same mosfet what could be the issue.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            ACOK status?
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • Thomas Smith
              Asus Tuf gaming fx506l no power, mosfet does not open
              by Thomas Smith
              Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
              Initial Symptoms:
              • The laptop has no power at all (no LEDs, no fan spin).
              • No 3.3V or 5V present on the board.
              • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
              Power Rail Checks:
              1. Charger input (FETs PKCH2BB)
                • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
              2. BQ24780S Charger IC:
                • VCC and ACDET are present.
                • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                • Shunt resistor has 10Ω to ground.
              03-30-2025, 03:38 AM
              by sam_sam_sam
              03-31-2024, 02:12 PM
