MacBook Pro M1 2020 A2338 (NO BACKLIGHT HELP)
  • XxMicroSoldering
    • Oct 2022
    • 38
    Hello Guys. I was repairing a MacBook with no backlight. I noticed the resistor/diode RP802 was bad so I took it off. I also had a faulty motherboard that can't be repaired that had that resistor/diode on it (RP802). So it took the good RP802 off the faulty board. And when I had it on my tweezers it accidentally flew away. And now I don't know what to do. I 100% can't find it because of how small it is. Do you guys know any other diode/resistor that can work as the RP802
    I'm a newbie to microsoldering and I'm still learning. All help is really appreciated
    Oh and I also messed up the copper parts by myself how to fix this
    Regards
  • mon2
    • Dec 2019
    • 14664
    Re: MacBook Pro M1 2020 A2338 (NO BACKLIGHT HELP)
    Post pics of the copper parts that may be faulty.
    • XxMicroSoldering
      • Oct 2022
      • 38
      Ofcourse
      • XxMicroSoldering
        • Oct 2022
        • 38
        Do you know how to fix the copper parts
        • mon2
          • Dec 2019
          • 14664
          Unless there is a broken trace within the copper area - you can leave it as-is.
          On PCB designs, the blank PCB starts off as a full coating of copper -> then masking is applied and chemicals are used to etch away portions of the copper to create the 'wire' between components. After the PCB is etched, the solder mask is coated ontop.
          Unless there is a cut in the copper plane, you can ignore it - only the solder mask (green or whatever color it was) has been flaked off but it is not of concern for this region.
          • XxMicroSoldering
            • Oct 2022
            • 38
            Got it. But I have to place back diodes and resistor. How to do that if the copper parts is exposed is it even possible when the copper parts is exposed. I need to place back RP801 RP802 and a other. But the copper parts is removed. Is it possible then to place back?
            • mon2
              • Dec 2019
              • 14664
              Ok - believe I understand the concern.
              See attached. From this list - which parts are missing off your logic board?
              • XxMicroSoldering
                • Oct 2022
                • 38
                Yes thanks . So RP801 is missing , RP802 AND CP800
                • XxMicroSoldering
                  • Oct 2022
                  • 38
                  So how do place back those on the exposed copper ?
                  • reformatt
                    • Feb 2020
                    • 1497
                    Don't you have UV mask? Apply it to the areas you want to cover, and scrape off any overfill in the areas you want to solder to.
                    • XxMicroSoldering
                      • Oct 2022
                      • 38
                      Hi thank you very much for you're reply. No I don't have uv mask is that necessary to buy if so I will buy it. One thing when you apple uv mask and you want to scrape of. I don't know where the pads are for the diodes / resistors to place them back. Thing is I don't know where it is now because the copper parts is removed. So how do I know where to exactly place them back
                      • mon2
                        • Dec 2019
                        • 14664
                        Remove all power. Meter in diode mode. Locate parts on your board that share a connection with the missing parts. Apply a meter probe on one side of the part still on the board. Other meter probe on the exposed copper. If you hear a tone, then the trace is the same connection and could be used for the repair. Do not solder anything till we can review the points. Best to also check the resistance of each such copper trace points.
                        • XxMicroSoldering
                          • Oct 2022
                          • 38
                          Got it only thing is. I have a multimeter but mine doesn't make sound what now ??
                          • XxMicroSoldering
                            • Oct 2022
                            • 38
                            So what do I do now. If there is a reading what should it be ??
                            • XxMicroSoldering
                              • Oct 2022
                              • 38
                              I really don't know
                              • XxMicroSoldering
                                • Oct 2022
                                • 38
                                Hi what to do
                                • mon2
                                  • Dec 2019
                                  • 14664
                                  Post a picture of your multimeter.
                                  • XxMicroSoldering
                                    • Oct 2022
                                    • 38
                                    Sorry for the late reply I will do it asap tommorow
                                    • XxMicroSoldering
                                      • Oct 2022
                                      • 38
                                      Here you go
                                      • XxMicroSoldering
                                        • Oct 2022
                                        • 38
                                        Hi sir I really need you're help regards
                                        • XxMicroSoldering
                                          Lost Diode/Resistor RP802 MacBook Pro 2020 A2338 HELP
                                          by XxMicroSoldering
                                          Hello Guys. Yesterday I was repairing a MacBook with no backlight. I noticed the resistor/diode RP802 is bad so I took it off. I also had a faulty motherboard that can't be repaired that had that resistor/diode on it (RP802). So it took the good RP802 off the faulty board. And when I had it on my tweezers it accidentally flew away. And now I don't know what to do. I 100% can't find it because of how small it is. Do you guys know any other diode/resistor that can work as the RP802
                                          10-06-2022, 12:41 AM
                                          Apple MacBook Pro 13" M1 2020 A2338 820-02020 Schematic & Board View
                                          Apple MacBook Pro 13" M1 2020 A2338 820-02020 Schematic & Board View...
                                          10-01-2024, 07:14 AM
                                        • KappaDev
                                          2020 Macbook Pro M2 A2338 820-02773
                                          by KappaDev
                                          Hey all,
                                          I have a Macbook Pro A2338, board number 820-02773 (schematics + board view attached for reference).
                                          When plugged in, meter shows 0A at 20.78V. Makes charger connected sound when plugged in, but the battery does not charge. Battery is detected in macOS, but shows 0%.Strangely, it seems to run off of the battery for several minutes despite being at 0%.
                                          The board had some light corrosion around JE501 fan connector (as shown in photo), but am not sure if there is any relation. Corrosion has been cleaned, but fan runs at 100% when on (laptop speed/performance seems...
                                          11-03-2024, 08:13 PM
                                        • bigbadbios
                                          a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
                                          by bigbadbios
                                          I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
                                          When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
                                          I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
                                          Your help is GREATLY appreciated. Thanks!
                                          08-18-2024, 05:47 PM
                                        • mariusm28
                                          Macbook pro 13'' A2338 late 2020 stuck at 5V
                                          by mariusm28
                                          I bought a waterdamaged macbook pro A2338 , late 2020 EMC 3578, its stuck at 5V 0,06mA.
                                          The 3V8 (U5700) chip is shorted out, atleast the PPBUS_VMAIN_VIN_ISNS Cap is and a bunch of resistors. It also seems that a resistor is missing. Does anyone have a boardview to tell me wich resistor goes where arround the U5700?
                                          And for the macbook to boot it requiers 20V am I right? Wich chip tells the charger that it is a Macbook and not a phone?
                                          Thank you so much!...
                                          06-13-2022, 12:30 PM
