How to revive Li Ion battery which was not used for like a year?
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    Hi guys.
    I have this old netbook Asus Transformer T100 which I was not using for probably more then a year.
    It really had great battery back last time it was used (lasted like
    cca 10 h of its complete usage)
    Tonight I wanted to turn it on but could not, battery was at 0% and to 100% charged pretty quickly and lasted only 15 minutes until complete discharge (back then I know it lasted like 10 hours).
    Please tell me there is hope.
    Now I am trying to discharge it again and charge just to try revive some cells in it if they are not complely dead.
    Now I know this is old laptop but I have like same old tablets which I do care about and last me few hours of battery screen on time.
    Is there a hope for this sweet boy?
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    Re: How to revive Li Ion battery which was not used for like a year?
    Okay so far I did drain and charge battery in 3 cycles, so far showing battery health of a 32 % and was 2 %.
    I will do few more charge7/discharge cycles, wish me luck...
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • ferah831208
      by ferah831208
      03-18-2025, 01:18 AM
