Macbook 820-00165
  • Instafixx
    • Jul 2022
    • 374
    • India
    Macbook 820-00165
    We have a Macbook Air 820-00165 in Dead Condition.
    Charger having Green/Orange Light.
    PPBUS_G3H at 8.55V
    After inspection we found a little Green at U8000. Went ahead cleaned and reballed the IC.
    The motherboard otherwise is squeaky clean.
    Upon inspection with a working same motherboard we found that there isnt aby voltage at R8177.
    I dont know whether i am on the right track here or not.
    Please guide.
  • Aliseo
    • Dec 2022
    • 12
    • Italy
    Re: Macbook 820-00165
    check PP3V3_S5 and PP5V_S5
    • Instafixx
      • Jul 2022
      • 374
      • India
      Voltages in these 2 Lines are fine.
      There is no voltage at Pin#1 and Pin#2 of L7520.
      • mon2
        • 14671
        Measure the voltage to ground of the EN pin #4 (P5VS4RS3_EN_R) U7501 that is the ENABLE for this power rail.
        If this voltage is a logic high '1' then remove all power -> check the resistance to ground of this coil / inductor L7520.
        • Instafixx
          • Jul 2022
          • 374
          • India
          Resistance on both Pin 1 and Pin 2 is 380 (Meter is set to 2k)
          • mon2
            • 14671
            The first part was missed.
            • Instafixx
              • Jul 2022
              • 374
              • India
              Voltage Measured. It was 1 as you said it might be.
              • mon2
                • 14671
                1) Remove the LIO cable -> measure the resistance to ground again on L7520. Is it still ~300 ohms ?
                If yes, lift up one leg of L7520 and then measure the resistance to ground on each side of the PCB pads for L7520.
                Need to know which side of the coil is with the low resistance.
                Is it the producer side (U7501 = L7520, pin #2)
                or
                is it the consumer side (L7520, pin #1) ?
                The 300R (300 ohms) to ground on L7520 sounds low to me on this high current rail.
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  or
                  Removed the L7520.
                  Resistance on Pin #1 is 399
                  Resistance on Pin#2 is 428.
                  Meter is set to 2k Mode.
                  • envym
                    by envym
                    Hi everyone!
                    06-27-2025, 08:54 AM
                  • Flasman90
                    Macbook Pro DFU Restore Issues
                    by Flasman90
                    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                    08-30-2025, 10:27 AM
                  • tobeend
                    Bypass mdm macbook m2 ventura
                    by tobeend
                    1. RESET MACOS WITH IPSW
                    a. Power off MacBook, press and hold the power button to enter Recovery
                    b. Open Disk Utility, remove Macintosh HD
                    c. Reboot, connect to the network to Activate Mac.
                    d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                    d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                    e. Release the other keys, but keep holding the Power key for another 10 seconds
                    f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                    05-26-2023, 07:18 AM
                  • SarcasticOP
                    General question about MacBook power rails for repair.
                    by SarcasticOP
                    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                    • PPBUS_G3H (12.6V-12.8V)
                      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                    • PP3V42_G3H (3.42V)
                      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                    • PPVRTC_G3H (3.3V)
                      • This
                    12-12-2024, 05:50 PM
                  • obelix24
                    A2941 Macbook air 15” - 5V 0a
                    by obelix24
                    I’m working on one macbook air 15” m2 that was water damaged.
                    keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                    i’ve put macbook in shelf and order new screen so i can fully repair it.
                    Now i got the screen and macbook stays at 5v 0a.
                    i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                    i don’t have schematics so i don’t know where to start can someone help me?...
                    03-27-2025, 01:19 PM
