Motherboard DA0ZQ1MB8D0 Rev. D no turn on
  • wzamoyski
    • Mar 2022
    • 27
    • Poland
    Hello everyone.
    It's my first post on this forum (sorry for my English). I want to try fix my first motherboard and hope found solution.
    I have problem:
    • DA0ZQ1MB8Do Rev. D;
    • Nuvoton NPCE78TLA0DX;
    • BD82HMSS;
    • I5-430M.
    When I press power switch the motherboard not turning on, no leds - no reaction. I measurement:
    Voltage:
    • CN2 n. 1 - 0V
    • PL3 - 0V
    • PL6 - 3.60-4V (very strange)
    • PL7 - 0V
    • PL10 - 0V
    • PL11 - 0V
    • PL12 - 0V
    • PL13 - 0V
    • PL15 - 5.13V
    • PL16 -3.38V
    • PL17 - 0V
    • PL18 - 0V
    Resistance:
    • PL3 - 221.7Ω
    • PL6 - 8kΩ and high
    • PL7 - 7.7Ω
    • PL10 - 27.3Ω
    • PL11 - 122.6Ω
    • PL12 - 122.7Ω
    • PL13 - 38.8Ω
    • PL14 - 38.8Ω
    • PL15 - 1kΩ and high
    • PL16 - 40kΩ and slow
    • PL17 - 44.6Ω
    • PL18 - 205.8Ω
    • U40 n. 8 - 4kΩ and higher
    • U29 n. 8 - 1kΩ and higher
    U40 have no power, I think (reading manual) probably is problem with KBC. Earlier have issue with fan - I follow this topic (reprogramming BIOS):
    Code:
    https://www.badcaps.net/forum/showthread.php?t=55264
    Maybe you have idea, what to do next. Maybe I do something wrong.
    Thanks.
  • mon2
    • Dec 2019
    • 14289
    Re: Motherboard DA0ZQ1MB8D0 Rev. D no turn on
    Can you link or post the schematic if on this forum?
    Check the voltage of the first 2 * dcin mosfets.
    Which charger IC is onboard?
    If the BQ charger IC, start with the voltage to ground of:
    REGN
    ACDRV
    Pins. Post each measurement.
    • mon2
      • Dec 2019
      • 14289
      See attached. Measure the voltage to ground of these 3 points of interest. Post each reading.
      • wzamoyski
        • Mar 2022
        • 27
        • Poland
        Hi @mon2. Thanks for reply.
        I use schematic from Quanta Zq1 and boardview (in attachement).
        REGN
        ACDRV
        Thanks for help. After reading Your post I realize use wrong charger and changed it. Now when I press switch button, motherboard power on. I have blue ligt on LED1. But now have another issue - no fan spinning.
        It's SL88731A. I checked:
        • PIN 2 (ACIN) - 3.96V
        • PIN 13 (ACOK) - 3.35V
        • PIN 22 (DCIN) - 18.77V
        1 - 0V
        2 - 3.34V
        3 - 3.35v
        • mon2
          • Dec 2019
          • 14289
          What is the voltage to ground of VA and VA1 points ?
          • wzamoyski
            • Mar 2022
            • 27
            • Poland
            what is the voltage to ground of va and va1 points ?
            va - 19.46v
            va1 - 19.15v
            • mon2
              • Dec 2019
              • 14289
              Remove all power. Measure the resistance to ground of pin #4 of PD32. If the resistance is not low, then consider to replace PD32.
              • wzamoyski
                • Mar 2022
                • 27
                • Poland
                I checked again every cable, connections. I saw, processor was no tightened into socket. Now motherboard turning on. Laptop works. Thanks @mon2 for suggestions and help.
                Topic may be closed.
                • glovecaps
                  Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                  by glovecaps
                  I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                  My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                  The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                  11-25-2024, 04:23 PM
                • Docus
                  Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                  by Docus
                  Hi everyone 😀,
                  I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                  To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                  Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                  1. I already own the exact same model, but its plastic chassis is badly damaged.
                  06-10-2025, 04:24 PM
                • Archimedes
                  HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                  by Archimedes
                  Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                  Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                  Fans are spinning. Blindly could install windows11 and got the device manager...
                  07-30-2024, 05:14 PM
                  ASUS P5GC-MX motherboard recap
                  by momaka
                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                  So here is what the motherboard looked like with its original caps:
                  CPU VRM area up close…...
                  01-27-2021, 11:59 PM
                • dragon3x
                  After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                  by dragon3x
                  Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                  power on.
                  Here are some examples :
                  (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                  switching supply area).
                  (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                  than 6.3 V.)
                  1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                  I replaced capacitors with aluminum-polymer.
                  3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                  03-21-2025, 02:46 PM
