Macbook pro 13" a1278 820-2879 mosfet subst
  • NConstantinou
    • May 2017
    • 335
    • Cyprus
    dear all
    can i substitute sis424 and sis426 with 7410 mosfet!
    thanks
  • NConstantinou
    • May 2017
    • 335
    • Cyprus
    Re: Macbook pro 13" a1278 820-2879 mosfet subst
    i found that motherboard looks like 820-2530.
    i noticed that u9000 ic H600 pin1 is ON.
    There i have 0v. there is no short. this comes from LVDS_IG_PANEL_PWR
    through a resistor and goes to graphis ic.
    does pin1 on u9000 should be 3v!
    if yes can i replace with J600!
    on more question.
    i removed motherboard and i shorted the pads grn and 3.4v but fan does not
    spin unless i have keyboard connected.
    how to power on mobo for troubleshooting.
    • Adogabriel100
      Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
      by Adogabriel100
      Hey! This is a A1278 macbook 2011.
      Problem: Not turning on / No green light
      Im using by3200s charger.
      Voltajes:
      PPBUS_G3H = 12.26v
      SMC_RESET_L = 3.3v
      PP3V42_G3H = 3.42v
      U7000 =
      Pin 1 CHGR_AGATE = 0v
      Pin 2 CHRG_DCIN = 19v
      Pin 3 CHRG_ACIN = 4.6v
      Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
      Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
      Pin 12 PP3V42_G3H = 3.42v
      Pin 13 CHRG_RST_L = 3.3V
      Pin 14 SMC_BC_ACOK = 0.8V
      Pin 19 PP5V1_CHRG_VDD = 5.05V
      Pin 20 PP5V1_CHRG_VDDP = 5.03V...
      04-01-2024, 01:02 PM
    • Rezendes
      Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
      by Rezendes
      Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
      I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
      The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
      05-10-2024, 02:18 PM
    • pcbmaniac
      MacBook A1278 (3115) No PPBUS_G3H Issue
      by pcbmaniac
      Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
      I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
      1. U7000 Measurements:
        • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
      2. Resistors:
        • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
      Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
      • If I also decide to replace the SMC, do I need to order it pre-programmed,
      12-02-2024, 04:12 PM
    • sizar00740
      macbook pro 13 inch a1278 820-2879
      by sizar00740
      please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
      07-30-2025, 10:21 AM
    • prodigy83
      MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
      by prodigy83
      My reference only: TT10141.
      Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
      Mosfet specs are as follows:
      Chip markings:...
      03-12-2024, 01:38 PM
