IT8227 programming with Vertyanov?
  • sopik78
    • Nov 2013
    • 519
    • Czech Republic
    Dear friends,
    I need some advice with programming IT8227 (IT8226 as well). Is it possible to reprogramm EC with Vertyanov rev 3.4?
    I dont see MB NM-C871 in the list of MB pin connection.
  • sopik78
    • Nov 2013
    • 519
    • Czech Republic
    Re: IT8227 programming with Vertyanov?
    OK, I found schematic and checked that Vertyanov works well.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      Did u have any problem with writing on it. when i erase chip i get allways lost comunication after 5 seconds when try to write
      • questore
        • Dec 2015
        • 564
        • csongrád
        1. If you have a correct connection IC ID response and you cannot read or write then you have an electric interferrence problem, try turning down your other electric devices in the same wall outlet. (sometimes even have problems with electric device in the same room)
        2. If you are not getting a correct IC ID either, then you are probably use A-side instead of B-Side or the other way around in the software option so try swithing.
        • ferah831208
          by ferah831208
          03-18-2025, 01:18 AM
        • ktmmotocross
          how to check if my vertyanov works? is keyboard test enough?
          by ktmmotocross
          i have problems with with my vertyanov. i was not able to comunicate with sio chips of four laptops in row. so i need to do some test on my vertyanov. can keyboard test on connector will be enough?
          10-25-2025, 10:56 AM
        • araxnido
          Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
          by araxnido
          Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
          When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
          06-10-2025, 09:26 PM
        • ronaldopdias
          ITE programmer. IT8226, IT8227, IT8586 and others.
          by ronaldopdias
          Hi everyone.
          Sice I have not found a solution in here for my problem I create this new thread to help me and help others.
          I've got an Lenovo Y540 in with bad IT8226.
          Charging port replaced as it was broken.
          I bought a new blank chip and installed on the motherboard.
          It programed automatically, but a weird behavior started. When charging was plugged in backlight is off, when disconnected charger and its only on battery backlight works normal.
          So, I've just decide to update BIOS and through Windows and it updated BIOS and EC, but stop half way...
          12-12-2022, 01:54 PM
        • myth77
          Help programming IT8987 with vertyanov
          by myth77
          The motherboard is HP Omen 17 G38D, ITE8987, i am getting error message that "motherboard not powered up?
          i use this settings:
          Quanta G38D KB_pins=32 LEFT DOWN 1MM PD0=26 PD1=22 PD2=20 PD3=15 PD4=19 PD5=23 PD6=16 PD7=18 BUSY=29 STB=21 AFD=32 INIT=25 SLIN=24 KSI4=28 KSI5=27
          The board is not starting automaticly when i plug in adapter. When charger/adapter is plugged i have +3VPCU, +3VECACC and +3V_VSTBY, they are all around 3,3 V. I dont have on pin 11 +3v but i used lab power supply and injected 3.2V....and then tried to read.... but again i get error "motherboard...
          11-09-2020, 06:33 AM
