Help programming IT8987 with vertyanov
  • myth77
    • Feb 2017
    • 380
    • Croatia
    The motherboard is HP Omen 17 G38D, ITE8987, i am getting error message that "motherboard not powered up?
    i use this settings:
    Quanta G38D KB_pins=32 LEFT DOWN 1MM PD0=26 PD1=22 PD2=20 PD3=15 PD4=19 PD5=23 PD6=16 PD7=18 BUSY=29 STB=21 AFD=32 INIT=25 SLIN=24 KSI4=28 KSI5=27
    The board is not starting automaticly when i plug in adapter. When charger/adapter is plugged i have +3VPCU, +3VECACC and +3V_VSTBY, they are all around 3,3 V. I dont have on pin 11 +3v but i used lab power supply and injected 3.2V....and then tried to read.... but again i get error "motherboard not powered up?"
    what am i missing? Any help appreciated.
  • khaahk
    • Dec 2013
    • 814
    • Estonia
    Re: Help programming IT8987 with vertyanov
    1st pin location ok? Also check pin connections from programmer to mainboard, sometimes the flex cable has bad connections. GND connected?
    • myth77
      • Feb 2017
      • 380
      • Croatia
      yes, everything is properly connected...i checked several times with multimeter connections from programmer to mainboard. Gnd connected.
      Also i used programmer on several other motherboards with success so the only problem is this one.
      And the motherboard is fine..its working and i am trying to extract ITE from it to use it on some other motherboard but always message "not powered up"...
      I didnt used programmer till now with IT8987, maybe there are some differences there...
      • khaahk
        • Dec 2013
        • 814
        • Estonia
        Sadly can not help you there, i have used the programmer on G35D, ITE8987 and i did get a read and write there. Can not remember details - but read on programmer ver 2 and ITE8987 should be possible.
        A few times i have had connection only when mainboard is powered on - not just connected to power adapter.
        I see that Vertyanov has not answered to your post at ascnb1 also...
        • emestee
          • 228
          go to ascnb1.ru forum and ask Vertyanov directly?
          • questore
            • Dec 2015
            • 565
            • csongrád
            HP laptops require correct ID pin value to respond.
            If use are using LAB Power supply that is not using ID pin value or a charger that is lower wattage then needed then EC will shutdown and wont respond.
            I had no problem connecting it with the Vertyanov 3.2 and the config inside.
