HP Omen 17-an108nc - no EN sig to power rails/no SUSP/
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3597
    • slovakia
    Hello.
    Have this HP Omen 17-an108nc that have no EN sig to power rails/no SUSP/
    It have 3.3VALW and MAIN and EC bios 3.3V. But when i push power button nothing changes and board reset about 5seconds
    i suspect bad chipset that after recieving PWRBTN from EC do not have start SUSP, but dont have BV or schema. is some way to check if PCH is bad?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Omen 17-an108nc - no EN sig to power rails/no SUSP/
    Missing SUSP# is most often due to dry SOC. If you have time,tools to reball it, there may be a fix.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3597
      • slovakia
      this is not soc. PCH is standalone chip here
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • kitor
        Dell Latitude 7390 - all power rails up except VCC_GT, no image.
        by kitor
        I have Dell 7390, LA-F311P.
        AFAIK there's no schematics available, but there's one for LA-F312P in this thread. It differs in no Thunderbolt controller (iirc that's for 5290/5390), however rest of the schematics/BV seems to match 1:1.
        Behavior:
        Connected barrel plug, no RAM:
        - power LED turns on + orange light on front
        - turns off after a second or two
        Connected barrel plug, with RAM:
        - power led turns on + while light on front
        - after a few seconds power led turns off, white light...
        07-26-2022, 09:53 AM
