A1932 820-01521-A PP3v3_UPC Short
  • rotceh_dnih
    • Jun 2020
    • 43
    Hi all got a head scratcher
    A1932 came in booting just with no keyboard or trackpad, I found missing PP3v3_G3S rail on J6700 lead me to what I thought was a short around U3700 "wifi ic" so i removed R5510 and injected voltage 0.5v not seeing anything under thermal camera i stupidly increased voltage to around 2v 3A and still nothing..
    Now i have no boot and short on both CC PP3v3_UPC_XA_LDO 8.4Ω & PP3v3_UPC_XB_LDO 2.5Ω, PPDCIN_G3H is 0V regardless of what port i plug into and my voltages are as follows
    Port 1 - U3200 5v - 0.148A
    Port 2 - U3100 5v - 0.153A
    Nether cycles so my best guess atm is both CD32's are dead? any assistance would be greatly appreciated!
    Prior to repair I warned my customer of known cpu issues and made a backup so i don't feel to bad just tilted i made things worse.
  • rotceh_dnih
    • Jun 2020
    • 43
    Re: A1932 820-01521-A PP3v3_UPC Short
    I've Ordered two new CD3215C00 ic's just waiting on the postman.
    However, before I install them, is there anything I should be looking at before I power up?
    Pretty sure I still have a short @ pin 1 R5510, but if after CC32 replacement it boots I'm handing it straight back and referring them to someone like Paul Daniels, I'm just worried I caused more damage then what i found :/
    Also if anyone has any tips on voltages or basic steps/post formatting I may have missed or not posted that would help with diagnostics I'm very open to hearing you out and learning!
    • mon2
      • 14370
      What is the voltage to ground of PP3v3_G3H_RTC?
      Check this webpage about your case:
      https://repair.wiki/w/A1932_2018_-_2019_MacBook_Air
      • rotceh_dnih
        • Jun 2020
        • 43
        PP3v3_G3H_RTC = 3.291V
        I replaced both the CC32 ic's and now its back to 20v and seems like its charging and somewhat booting as i have fanspin again but no image
        I checked its not in dfu mode then ran the thermal cam over the board again and seen U8210 is hot so i lifted it and i still have a short on pin 5/6 PP3v3_G3S
        I'll lift R5510 again and see its its really on the PP3v3_G3S_WLANBT line & read through the repair wiki and report back.
        Also has anyone got any good suggestions for a new lab power supply ? i need something that can do 5-10A @ 0.5v-1v as my current supply is limited to 3A and only gets there above 2V..
        • mon2
          • 14370
          We use the TS-30A Short Killer product from Phone fix on AliExpress. It can spike out 30A and we dial up 0v8 on the voltage. Works well to locate shorted caps.
          • rotceh_dnih
            • Jun 2020
            • 43
            Ordered one thank you very much!
            Lifted R5110, Short still on pin 1. after some thermal imaging @ low voltage limited current i didn't see anything so suspected U3700, Lifted U3700 WIFI/BT IC and my short from PP3v3_G3S is now gone however its still not booting though i get 20v and what seems to be normal booting/charging current.
            all voltages around U7800 appear normal without cycling and as per the wiki these rails check out
            PP5v_G3S - 5v & high resistance 10K+
            PP3v3_G3S - 3.3v & high resistance 10K+
            PP1v8_G3S - 1.8v & high resistance 10K+
            PP3v_G3H - 3v & high resistance 10K+
            then i get to PPBUS_G3H
            PPBUS_G3H - 9.7v 53K+ this is so very wrong.. U7000?
            • mon2
              • 14370
              Remove the fuse on PPBUS_G3H.
              Power up again. What is the voltage to ground of PPBUS_G3H from the producer side (ISL)?
              • rotceh_dnih
                • Jun 2020
                • 43
                Sorry that reading was with battery connected and it must have been alittle flat as its up to 12v now and 12.65v without battery connected and 12.65V with a know good battery.
                • DynaxSC
                  Extreme High Current & Low Voltage Short Killer ??
                  by DynaxSC
                  Hi Folks
                  I'm looking for a extreme high current short killer solution for a reasonable cost.
                  I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                  After taking off the socket, the shorts dissappear again.
                  The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                  10-15-2024, 10:13 AM
                • Stephen
                  MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                  by Stephen
                  I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                  02-06-2025, 12:03 PM
                • Victor Moreira Silva
                  Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                  by Victor Moreira Silva
                  I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                  Well, my decice specs are the following:
                  Model: Acer Nitro 5 AN517-54-55T5
                  CPU: Intel Core i5-11400H
                  GPU: NVIDIA GeForce GTX 1650
                  Motherboard: GH51G LA-L181P Rev:1c
                  The symptom:
                  When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                  05-26-2025, 10:49 AM
                • aaronkatrini
                  Help me find the short circuit on this WORKING Nvidia GTX1650
                  by aaronkatrini
                  Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                  Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                  04-18-2024, 03:15 PM
                • Geeker007
                  9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                  by Geeker007
                  Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                  I am new to electronics repair, so my queries could be naive but I am ready to learn.
                  So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                  01-28-2025, 03:31 PM
