Macbook pro M1 a2338 820-02020 water damage only 5V but powers on from battery
  • kuba2102
    • Jan 2020
    • 42
    • Scotland
    Hi. Having this M1 after liquid it has only 5V on USB ports, but oddly it can be powered on from the battery source only without a jumper S5191.
    Liquid affected IC's:
    UF400, UF500
    UF725, UF720, UF710
    UF260
    UP800, UP900, QD530, UC710, UD560
    UF400 VOLTAGES:
    PPHV_INT0_AONSW.............5.15V
    PPVBUS_USBC0...................5.16V
    PP1V5_UPC0_LDO_CORE .....1. 59 V
    UPC0_SS............................0V
    USBC0_3V3LDO_EN.............1.8V
    PP1V8_S2 ...........(PIN L20)..1.8V
    PP3V3_UPC0_LDO (PIN C22) 1.8V
    PP1V25_S2.........................1.22V
    PP3V3_S2_UPC....................3.31V
    PP5V_S2.............................5.19V
    On the schematics it says PP3V3_UPC0_LDO but openboardview says PP1V8_S2, So I assume that the schematic isn't correct? Pins PP1V8_S2 (PIN L20) PP3V3_UPC0_LDO (PIN C22) go to the same component pin, another words are bridged.
    UF500 VOLTAGES:
    PPHV_INT1_AONSW...............5.15V
    PPVBUS_USBC1.....................5.16V
    PP1V5_UPC1_LDO_CORE .......1.58V
    UPC1_SS..............................0V
    USBC1_3V3LDO_EN (PIN L18) 1.8V
    PP1V8_S2 ..............(PIN L20).1.8V
    PP3V3_UPC1_LDO..................3.3V
    PP1V25_S2...........................1.22V
    PP3V3_S2_UPC......................3.31V
    PP5V_S2...............................5.19V
    On the schematics it says PP1V8_S2 but openboardview says USBC1_3V3LDO_EN, so I assume that the schematic isn't correct? Pins USBC1_3V3LDO_EN (PIN L18) PP1V8_S2 (PIN L20) go to the same component pin, another words are bridged. I'm not sure if those schematics can be trusted. I have been going through test point on the board that clearly have some voltage in it, yet schematic claims that is NC.
    Conclusion. I couldn't find any abnormalities on the board, I have identical working board to compare and the voltages measured are identical. ;/;/
  • mon2
    • Dec 2019
    • 14267
    Re: Macbook pro M1 a2338 820-02020 water damage only 5V but powers on from battery
    UF400 VOLTAGES:
    Is this a correct measurement ?
    • kuba2102
      • Jan 2020
      • 42
      • Scotland
      I think that my post might have been either misunderstood or hasn't been read fully. Yes it's correct. Same voltage when measured a working M1 motherboard.
      • kuba2102
        • Jan 2020
        • 42
        • Scotland
        Got it. Manage to find a short, the guilty parts name was UP900 keyboard backlight pwm. I thought I'll be able to source out the part from the old 2019 MacBook Pro but it's got different components. Does anyone know where to get it or some sort of substitution to it? Kind thank you
        P.S. Never fully trust the schematics, they are cheeky bastards
        • mon2
          • Dec 2019
          • 14267
          Sure:
          https://www.findchips.com/search/SN74AXC1T45DRL
          Be sure to watch the suffix which defines the package of this device = SOT-5X3.
          DK:
          https://www.digikey.com/en/products/detail/SN74AXC1T45DRLR/296-47599-6-ND/8111087?utm_source=findchips&utm_medium=aggregator&WT.z_cid=ref_findchips_standard&utm_campaign={0}
          • kuba2102
            • Jan 2020
            • 42
            • Scotland
            Thank you for that. Can I just ask tak the device package in this case SOT-5X3 is just a part dimension or specs as well? Cheers
            • mon2
              • Dec 2019
              • 14267
              It is only a package definition. Required to match the pcb landing pattern.
              • kuba2102
                • Jan 2020
                • 42
                • Scotland
                Hello again. I replaced the part it solved the problem for a wee while then again I only get 5V. According to Louis Rossmann if you only get 5V and your CD3217 is not boot looping it means it's a bad one. In my case none of the ICs are boot looping. I have replaced the CD3217 from macbook pro 2019 (hopefully these are interchangeable) and again I get no boot loop on that new IC, which makes me think in it's not only that both CD3217 must have communication between themselves to initialise 20V, but there must be some extra communication going on either to UF000/UF100 or the SOC itself. The thing is very occasionally I get 20V and battery charging, also my battery still has charge in it and If I leave the battery connected and plug charger in it boots with 5V only but not charging, once system is loaded after unplugging and replugging the charger 20V 0A appears. This is baffling..
                • cnunez
                  • May 2023
                  • Bermuda
                  Good day guys ,I got the same issue CD3217 5V bootloops after 6sec. ( 20V) Not present )
                  i believe CD3217 is corrupted ) or may be both chips are failing.ill try to make a video if i get a programming box to fix the issues soon.
                  • TheNuclearOption
                    A2338 water damage with burnt charge port connector
                    by TheNuclearOption
                    Hi everyone, I bought a damaged a2338 MacBook pro with water damage and I'm hoping to learn how to fix it. I've worked on electronic for a long time for never attempted repairing water damaged components. The charge port connection on the motherboard along with the USBC connector is burnt. I'm hoping this is worth my effort and I'm not wasting my time. I've sourced some parts but first I was wondering if there was a way to check to see if it was Beyond repair if there was a fried CPU. Is there anything I should check before I order parts?
                    01-31-2024, 08:57 PM
                    20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                    by sam_sam_sam
                    I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                    At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                    Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                    04-09-2023, 08:04 PM
                  • TheNuclearOption
                    HOW BAD IS MY PCB DAMAGE A2338 820-02337 water damage burnt caps
                    by TheNuclearOption
                    Short on ppbus. Taking 3a at 1v and nothing is heating up. I have at least 3 pads that are badly burnt from capacitors. Ive scraped (at least attempted to) not sure how good I did? Are these possibly containing internal shorts? Do you think they need to be scraped more?...
                    02-28-2024, 06:21 PM
                  • gizaha
                    macbook pro M1 a2338 820-02020 water damage
                    by gizaha
                    Small water damage, cleaned it.
                    Shorted CL002, i removed it carefully with soldering iron, now it has voltage.
                    5v instant 180ma and then 100ma stable. I didn't found cycling voltage nor shorts in the motherboard.
                    I don't have pp5v_s2 because uc300 does not get enable pin from u8100 (it gets VIN). pp5v_s2 is not shorted, nor enable pin line.
                    PP3V3_S2 OK
                    PP3V3_S2_UPC OK
                    PP1V5_VLDOINT_MPMU OK
                    PP3V3_AON OK
                    PP1V8_AON OK
                    PP1V25_S2 OK
                    PP1V8_S2 OK
                    PP1V8_S2SW_VDD1 OK
                    PP3V8_AON OK
                    u8100 did not have corrosion...
                    07-15-2022, 07:12 AM
                  • edugimeno
                    Stagg sms12p audio amp has water damage
                    by edugimeno
                    Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                    I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                    There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                    There is only one signal wire connecting the first boards...
                    05-24-2025, 06:00 AM
