PC laptop ASUS X751YI blocked on logo Asus
  • goliat17120
    • Nov 2022
    • france
    Hello everyone,Laptop
    model : ASUS X751Y
    CM : ( 200 ) X751YI
    Description !
    This laptop had been shut down for two years due to a black screen and unable to boot the system.
    So I recovered this pc to try to restart it.
    I connected it to the mains with two functional green and orange LEDs.
    I made an F2 to have access to the bios successfully and put back the right date, create a bootable USB stick with W10 21h2 64 bits after recovering all the files! Until the it was all ok! I launch the updates via Windows update and during the restart, the computer stuck on the ASUS logo!!!
    I do a hard reset and always the same!
    Battery voltage following disassembly 6V and well on the pc does not work on battery and no charge despite the orange
    led I controlled some voltage 3v and 5v and especially the voltage of the bios which is 3v!
    I'm thinking of a corrupted bios! What do you think friends? HELP !!!
    PLEASE! Thank you
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: PC laptop ASUS X751YI blocked on logo Asus
    Hello
    Backup original Bios bin and flash the Bios, you can find the working BIOS in the BIOS area in the same platform
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • lrouw84
      Asus vivobook s510ua bios changed to x510un
      by lrouw84
      Hi there,
      I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
      I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
      01-28-2023, 01:31 PM
