Hp 15-P104NI Laptop switches off with new Battery when AC unplugged!! Please help!!
  • mon2
    • Dec 2019
    • 14801
    Re: Hp 15-P104NI Laptop switches off with new Battery when AC unplugged!! Please help
    Given that the battery charge LED is on - what is the voltage of BQHIDRV ?
    This pin is connected to the GATE of the high side mosfet @ PQ36.
    What voltage do you measure @ PL8 (either side) while the ADAPTER & BATTERY are connected ?
    This is the battery charge voltage.
    • roxboy1984
      • Jan 2022
      • 183
      • South Africa
      #42
      Battery LED went from amber to white suggesting it was fully charged but the laptop still wont boot on battery alone.
      • mon2
        • Dec 2019
        • 14801
        What is the voltage you see on the battery connector ?
        Measure the voltage on each pin of the battery connector -> interested in the SMBUS data line voltage as well.
        See attached.
        • roxboy1984
          • Jan 2022
          • 183
          • South Africa
          #44
          Ok so im getting 20.8V on BQHIDRV.
          on either side of PL8 i get 1.028V
          Battery pin voltages are as follows
          pin 1 = 2.87V
          pin 2 = 2.87V
          pin 3 = 0.852V
          pin 4 = 3.36 V
          pin 5 = 0.00V
          pin 6 = 3.3V
          pin 7 = 0.00V
          pin 8 = 0.00V
          Not sure where to measure the SMBdata line. i took a measurement on either side of "PD1" and got 4.4mV and 0.0V
          • mon2
            • Dec 2019
            • 14801
            Remove all power. Remove PD1 off the board.
            Attach the battery and adapter. Measure the voltages again on each of the battery pins.
            Post all readings.
            • roxboy1984
              • Jan 2022
              • 183
              • South Africa
              #46
              Post all readings.
              with PD1 removed i get the below.
              pin 1 = 1.007V
              pin 2 = 1.010V
              pin 3 = 0.002V
              pin 4 = 3.33 V
              pin 5 = 0.00V
              pin 6 = 0.00V
              pin 7 = 0.00V
              pin 8 = 0.00V
              • mon2
                • Dec 2019
                • 14801
                Remove all power.
                Measure the resistance to ground of pin #3 on the battery connector on the logic board. No battery but only the connector.
                The 0v is not correct. It should be 3v3. You may be missing a required pull up resistor on this pin.
                There is another part on pin #3? Remove it for a quick test.
                Post the resistance to ground.
                • roxboy1984
                  • Jan 2022
                  • 183
                  • South Africa
                  #48
                  Remove all power.
                  Resistance to ground on pin 3 is 145 Megaohms
                  • mon2
                    • Dec 2019
                    • 14801
                    Locate the pull up resistor for this signal on the logic board.
                    Check it's resistance and then, the voltage on both sides of the resistor.
                    This is a smbus line and it requires a pull up resistor to function. Appears to be missing or defective. This line must be 3v3 in the idle state not 0v.
                    • roxboy1984
                      • Jan 2022
                      • 183
                      • South Africa
                      #50
                      Remove all power.
                      Im not exactly sure what other part is on pin 3. is it PC10 that you mean? looks to be a tiny ceramic cap i think.
                      • roxboy1984
                        • Jan 2022
                        • 183
                        • South Africa
                        #51
                        Sorry, again please excuse my ignorance but would that be PR1? if so, there doesnt seem to be anything on the board at that location and the pads dont seem to even have solder on.
                        • mon2
                          • Dec 2019
                          • 14801
                          1) do not worry about the cap on MBDATA line - your resistance is fine so that is not the fault.
                          2) the issue is that SMBUS are open-drain lines. When they are not active, the line is floating and an external resistor must be present to perform a soft pull-up to 3v3. This appears to be ok for the MBCLK line but not the MBDATA line.
                          Search for a resistor with label R182. Nearby should be also R190 which appears to be ok but R182 is not working here.
                          Post a close up pic of that region of these resistors.
                          • roxboy1984
                            • Jan 2022
                            • 183
                            • South Africa
                            #53
                            Thanks. so that took me alot longer to find than i expected but here is a pic of that area as you requested.
                            • mon2
                              • Dec 2019
                              • 14801
                              See attached.
                              Believe that these resistors are of interest - specifically R182.
                              With no power to the logic board, meter in resistance mode -> measure the resistance across resistor R182.
                              What is the measurement? It should be ~4k7 = 4,700 ohms. Confirm it.
                              R190 should be also a similar value.
                              If this is close, then apply power and measure the VOLTAGE on both pins of this resistor R182.
                              Both sides should be ~3v3.
                              • roxboy1984
                                • Jan 2022
                                • 183
                                • South Africa
                                #55
                                See attached.
                                The resistance of those resistors is correct as well as the voltage on both sides being correct also.
                                • mon2
                                  • Dec 2019
                                  • 14801
                                  According to the schematic, the same resistor should reach pin #3 of the battery connector.
                                  Remove all power. Meter in lowest resistance scale.
                                  Check the resistance from this resistor R182 to pin #3 of the battery connector. It should be ~0 ohms.
                                  Check against the schematic. That is, the 3v3 on the 4k7 pull up resistor should also be present on pin #3 of the battery connector.
                                  • roxboy1984
                                    • Jan 2022
                                    • 183
                                    • South Africa
                                    #57
                                    ok so if i measure the resistance from R182 to pin 3 i get 0.320 Mega Ohms which is obviously far from 0 ohms
                                    • roxboy1984
                                      • Jan 2022
                                      • 183
                                      • South Africa
                                      #58
                                      Post all readings.
                                      can I put PD1 back on the board?
                                      • mon2
                                        • Dec 2019
                                        • 14801
                                        Yes, PD1 is a surge supression device. After you place it back, measure the resistance to ground again but it does not appear that PD1 is defective.
                                        Do note the orientation of the part. Review PD2 for guidance.
                                        • roxboy1984
                                          • Jan 2022
                                          • 183
                                          • South Africa
                                          #60
                                          ok so i returned PD1 and measured resistance again and got 0.320 Mega ohms
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • flat-earther
                                            how to prevent a connected charger from draining battery when not charging?
                                            by flat-earther
                                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                            So the battery is backfeeding the charger and being drained.
                                            How can I prevent...
                                            08-07-2025, 01:04 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            by sam_sam_sam
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
                                            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                            by sam_sam_sam
                                            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                            So I have put them on the battery testing machine to drain each battery cell down to...
                                            09-04-2022, 04:45 PM
