Medion P6705 potential BIOS issue?
  • ezenia
    • Jun 2020
    • 58
    • England
    Ever since I updated to Windows 11 22H2, I've been experiencing a strange issue with my laptop. It started with the laptop freezing as the OS tried to load. I'd see the Medion logo, the circular OS loading icon appeared and then it'd get stuck.
    After some troubleshooting with the above issue (e.g. removing all my drives, testing RAM in all possible configurations, trying to boot off of both a W10 and W11 USB stick), I took out the CMOS battery, left out for a bit and that reset the CMOS. Laptop came back to life.
    However, the issue hasn't been fixed. It seems that after I restart my laptop (click Start > Restart or accept a restart request from something that requires a reboot), it fails to reboot. I see the usual "Restarting..." and then after the screen goes black. It stays black for a bit and then shuts off.
    After shut off, it powers back on and then gets stuck. The keyboard backlight is fading in and out (like a slow blink). The blinking does stop afterwards. The screen remains black. After some time, the laptop shuts off and powers back on repeating the exact same behaviour. It does this indefinitely.
    I tried force powering off the laptop and it shuts off as I expect. After I press the power button, it does the same thing again. No Medion logo, just a black screen with the blinking keyboard backlight. So I took the CMOS battery out again to reset the CMOS. This worked. Laptop comes back, boots into Windows and is fine.
    I've been able to repeat the above issue 3 times now. It's always fixed by resetting the CMOS.
    Once the laptop is in Windows, it stays on and runs fine. I can let it sleep and the laptop will wake up and work with no problems. I can also seemingly turn off the laptop (by holding power button for example) and it'll turn right back on.
    I just can't restart the machine any more. If I do, it triggers the black screen keyboard blinking issue.
    Based on what I am seeing, it looks like a BIOS issue. Is it possible that the Windows 11 update somehow caused some sort of BIOS corruption that's only affecting restarts?
    It's a strange problem and somewhat concerning. I don't know if it's coincidence, but this only started happening after I made the switch to Windows 11 22H2. I had upgraded to Windows 11 a while ago and experienced no problems.
    Appreciate any input/thoughts on this.
  • ezenia
    • Jun 2020
    • 58
    • England
    Re: Medion P6705 potential BIOS issue?
    Also I haven't tried reinstalling Windows yet (by doing a proper wipe via USB stick) as I want to try and avoid that if possible. However, I may end up trying it out if it's just case of the OS being corrupted and somehow temporarily breaking the BIOS.
    If a proper reinstall will fix that, I'll definitely just do that.
    • ezenia
      • Jun 2020
      • 58
      • England
      So I reinstalled Windows 11 22H2 via USB and I thought it was solved since I could reboot without issue. I used my laptop for several hours and decided to do a reboot. It happened again. Same exact issue. I had to reset the CMOS to bring the laptop back to life.
      I am not sure what's going on. Maybe some hardware is failing. I'm guessing maybe the CPU/GPU. I do notice that the GPU fan stops spinning while the CPU fan continues to spin.
      After the CMOS reset, I tried a reboot to see what happened and the laptop rebooted without issue. Looks like the restarts aren't the problem. Something else must be going on.
      • ezenia
        • Jun 2020
        • 58
        • England
        Well after reinstalling Windows 11 22H2 and also trying a clean install of Windows 10, the issue remained.
        After lots of fiddling about, I've now been able to trigger the problem quickly after a CMOS reset. If I put the laptop to sleep and try to restart the OS (where uptime on Task Manager goes back to 0), the issue starts. Laptop gets stuck and stays on a black screen and eventually reboots repeating the same thing over and over until power is cut.
        To pass POST, the CMOS must be reset.
        I can sleep and shutdown the laptop, but only if fast startup is enabled. With fast startup enabled, clicking on shutdown doesn't trigger a full reboot (up time doesn't reset). If I turn off fast startup and try to shutdown after the laptop has been to sleep, it'll also trigger the problem.
        So what seems to be the issue is once the laptop has been to sleep and has woken up, it breaks if it has to properly reboot the OS.
        If anyone has even a remote idea of what this might be, I'm all ears. I tried testing RAM in various configurations (each stick tested separately in each slot). I was still able to trigger the fault.
        Something's telling me that Windows 11 22H2 might've have corrupted in the BIOS in some way and now that's why it's playing up. This problem only started after updating to 22H2. It was fine before that update.
        • ezenia
          • Jun 2020
          • 58
          • England
          Looks like the issue was caused by the PCIe SSD. I got a spare M.2 SSD, put that in, installed Windows and then tried various sleep+restart cycles to force the fault to occur. I have not been able to reproduce the fault with this M.2 SSD.
          To be more sure, I took out the M.2 SSD and re-inserted the PCIe SSD. Fault came back.
          The SSD was the last thing I expected to be the culprit since removing it from the laptop did not allow POST to pass. I always had to reset CMOS to get it to POST.
          Whatever is wrong with the SSD seems to be triggered once the laptop wakes from sleep and is told to restart the OS. POST just fails and doesn't come back until the CMOS is reset.
          I'm still going to give it a few days to see if it's truly fixed. It certainly looks that way. Hopefully the laptop isn't playing tricks on me, giving me false hope, only to fail again in a few days. Time will tell.
          • questore
            XPS 13 9370 CMOS battery voltage always low
            by questore
            Hi Everyone,
            I have brought you a mistery item
            This laptop have come with some strange faults.
            1. CMOS battery was flat 0v
            Symptoms:
            - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
            Amp drawing was stuck at 0.005 milliamps.
            - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
            After inverstigation RTCD1 diode had a low value...
            09-30-2025, 05:47 AM
          • BlackBeetle
            MEDION AKOYA S15450 MD 63650 MSN: 30030203
            by BlackBeetle
            Hello, I have a problem with a Medion notebook.
            https://www.medion.com/de/service/pr...etail/30030203
            MEDION AKOYA S15450 (MD 63650) A-DE N MSN: 3003 0203 with Windows 10 64x
            The keyboard makes random entries and I don't seem to be the only one. Someone on this board has the same problem. I had BIOS version 207 installed and the BIOS version that Medion Support offers here as 209.
            https://community.medion.com/t5/Note.../104097/page/2
            Bios Version...
            08-09-2024, 05:50 PM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • shahnld
            Lenovo legion 5 pro startup issue
            by shahnld
            Good day Experts
            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
            08-24-2025, 12:31 PM
