Macbook pro 2018 15 inch Dead
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    I found macbook pro from a relation and its dead. I'm thinking to learn from this stuff. Still I didn't even tested the voltages. when I plug power I see one NAND chip heats up. I guess Its about SSD failure. Can you guys help me in this matter. what should I do?
    I heard I can't replace only one chip. Is that true? where should I start? this is the first time I'm dealing with macbook.
    U8800 chip heats up
    Logicboard model No: 820-01041-A
    was able to find both brd file and schematics from this forum. here is the link to that.
    https://www.badcaps.net/forum/attach...7&d=1566766401
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    Re: Macbook pro 2018 15 inch Dead
    Any Luck
    • mon2
      • 14662
      Have not personally worked on the nands on this model but read from other posts that the NAND should be taken from a donor board of the same.
      • harshana
        • Aug 2022
        • 216
        • Sri Lanka
        Thank you so much for the reply mon2. I tried to find nand from donor board and I was able to find programmed Nand chip for the same model from Aliexpress. My question is,
        Should I replace NAND before further tests??
        I tested roughly, laptop take 20v from the charger and 5v and 3v are present. also I see 1.8v present near ssd chip.
        Anyhow I will order the chips today. lets see
        • mon2
          • 14662
          Read this thread:
          https://www.reddit.com/r/learnprogra..._specifically/
          • harshana
            • Aug 2022
            • 216
            • Sri Lanka
            Seems Like I can fix this.
            here is the link I found from alibaba and ordered it today.
            https://m.alibaba.com/product/160047...6gb-500gb.html
            I contacted them and they told me that chips are programmed.
            • piernov
              • Jan 2016
              • 4439
              • France
              Must fix SSD power rails before killing new SSD ICs.
              If ICs do not come from a similar donor board, they may need to be reconfigured with JC P13.
              • harshana
                • Aug 2022
                • 216
                • Sri Lanka
                Hello piernov,
                I will test ssd rails. anyhow the seller said that the chip has installed right program.
                Sounds like they have programmed. will look into power rails. Someone has tried to remove the logicboard and some screws are damaged. need to find a way to remove them.
                • harshana
                  • Aug 2022
                  • 216
                  • Sri Lanka
                  Finally I fucked up everything. When I remove defective NAND chip some pads on the the board damaged. Completely my mistake. anyhow I canceled the order from alibaba because its useless to order chips now.
                  unexpected experience to me. I learned something.
                  • mon2
                    • 14662
                    We have all been there. Lots of flux with enough heat and air pressure to gently nudge the IC.
                    Only when the ic is swimming in liquid solder, then remove it.
                    • harshana
                      • Aug 2022
                      • 216
                      • Sri Lanka
                      mm. I was afraid about the other components. so I used lower temperature. anyway I will try to find another logicboard to fix this stuff. lets see.
                      Thanks for the support
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        @harshana, you learnt a hard lession but at what cost?? You damaged a expensive machine. Thats why always practice on scrap boards unless and until you feel confident.
                        • harshana
                          • Aug 2022
                          • 216
                          • Sri Lanka
                          I purchased this laptop for 370$. full set with box. Im trying to find a dead logic board and replace. if I failed I should sell other parts to cover the cost. Thats the only hope I have.
                          Thats the main lesson I learned. small mistake but expensive.
                          I totally agree with you.
                          • harshana
                            • Aug 2022
                            • 216
                            • Sri Lanka
                            Hello. I purchased another logic board from ebay to fix this laptop. but that motherboard also not working. I feel the haptic when I click on the trackpad but no backlights or nothing on screen.
                            • harshana
                              • Aug 2022
                              • 216
                              • Sri Lanka
                              Here is the latest update. I was able to turn on the laptop but I see lines flickering on the display. I checked also keyboard backlight not working. how I troubleshoot those things?
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 674
                                Have you DFU restored it? Once you replace the NAND you always have to DFU restore the board
                                sigpic
                                MEOWING IN THE IMPOSSIBLE UNIVERSE!
                                • envym
                                  by envym
                                  Hi everyone!
                                  06-27-2025, 08:54 AM
                                • robka
                                  MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                                  by robka
                                  my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                                  I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                                  The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                                  After that the Macbook was dead. It isn't charging anymore.
                                  The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                                  03-02-2024, 02:58 PM
                                • dellxps15
                                  macbook a1707 15 inch trackpad dead. blown fuse identification
                                  by dellxps15
                                  hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                  another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                  04-30-2024, 10:48 AM
                                • Jiayi
                                  Macbook Pro 2018 dead with 5V 0A
                                  by Jiayi
                                  Hi everyone, this is my first time trying to repair my 15" MBP 2018 A1990. I've been watching logic board repair videos for a long time so I wanted to experiment with reviving my own MBP, board number 820-01814.
                                  This is all the information I gathered so far:
                                  - All USB-C ports are dead with 5V 0A, none of them loops
                                  - Weird fact: when charger is connected to the port corresponding to UB400 and I try to measure the volts at CB401, the charger is restarted. It happens only with that port and UB400. CB401 is not shorted. I don't know enough to explain this....
                                  12-16-2023, 09:31 AM
                                • mattknudstrup@gmail.com
                                  2018 Macbook Pro A1990 2Tb, SSD1 dead
                                  by mattknudstrup@gmail.com
                                  Hello All,
                                  My 2018 Macbook Pro (2TB) crapped out recently, won't turn on. Diagnosed so far as shorted second terabyte SSD1. Question for the forum. I'm thinking about removing or disabling SSD1 and just using SSD0 which will still give me 1Tb usable. I'm assuming all the boot up stuff is all in SSD0. Am I correct about this? If so is there a way to disable SSD1 without removing all the associated components? Will just powering it down do the trick?
                                  I currently have U9580 (TPS62180) removed as it was fried but that is as far as I have gone with it. In other words I...
                                  08-30-2023, 09:15 AM
