2018 Macbook Pro A1990 2Tb, SSD1 dead
  • mattknudstrup@gmail.com
    • Aug 2023
    Hello All,
    My 2018 Macbook Pro (2TB) crapped out recently, won't turn on. Diagnosed so far as shorted second terabyte SSD1. Question for the forum. I'm thinking about removing or disabling SSD1 and just using SSD0 which will still give me 1Tb usable. I'm assuming all the boot up stuff is all in SSD0. Am I correct about this? If so is there a way to disable SSD1 without removing all the associated components? Will just powering it down do the trick?
    I currently have U9580 (TPS62180) removed as it was fried but that is as far as I have gone with it. In other words I haven't identified the short yet so I suppose it could still be a capacitor but guessing I won't get that lucky.
    Any info or advice on how I should proceed is appreciated. I do have schematics and board file, and I am a computer engineer so can understand the circuits. I just don't have much experience with this system.
  • mon2
    • 14662
    Re: 2018 Macbook Pro A1990 2Tb, SSD1 dead
    Check the resistance to ground of each inductor. Each inductor is linked to a local switching buck regulator.
    If the resistance is too low, the shorted cap may be on that power rail.
    Remove all power during the resistance checking.
    • reformatt
      • Feb 2020
      • 1495
      I don't believe it is possible to do that, as they are all striped with firmware as a set of 8 by Apple. Not to mention Apple has these all underfilled making a simple process a PITA.
      Watch this video on how hard Apple has made what is a simple replacement in a PC to a nightmare on a MAC. Built in obsolescence as the SSD will ultimately wear out and die, and the whole machine is thus useless.
      https://www.youtube.com/watch?v=yR7m...annel=iBoffRCC
        • Aug 2023
        Thanks for the replies guys. reformatt, I had watched that video and to me it looks like the two SSD's are striped separately with the nands labeled 0-3 on each one. Not a fan at all of Apple design techniques. I won't be buying another one. But I may test the theory that it's possible that the two SSD's are striped separately and will report back.
        • robka
          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
          by robka
          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
          After that the Macbook was dead. It isn't charging anymore.
          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
          03-02-2024, 02:58 PM
        • envym
          by envym
          Hi everyone!
          06-27-2025, 08:54 AM
        • pcash0007
          Dead 2018 Macbook Pro A1990 820-01041-07 stuck at 5V 0A
          by pcash0007
          First time looking at a logic board this closely, learnt enough from videos and forums here to be dangerous
          I was doing a OS update when the screen went blank at some point. Does not seem to be in DFU mode (checked using apple configurator).
          PPDCIN_G3H is 5.16V​
          PPBUS_G3H is 0.045V
          Resistance between TP_PPBUS_G3H and ground is 23.8 Ohms (which seems low)
          F7000 and F7001 seems fine.
          From what I learnt seems like there might be short on the down side on PPBUS_G3H.
          Is injecting low voltage and see what...
          03-07-2024, 06:19 PM
        • netboy69
          Macbook Pro 15, A1990 2018, showing recovery not dfu, error 9 when restore, HELP
          by netboy69
          Hi to all i have a faulty a1990 from 2018, no liquid damage, died during update, now on configurator i see recovery not dfu, and i get error 9. caps around u7701 show short after removing u7701 and shorted caps still short. can any help....
          02-07-2024, 04:34 PM
        • harshana
          Macbook pro 2018 15 inch Dead
          by harshana
          I found macbook pro from a relation and its dead. I'm thinking to learn from this stuff. Still I didn't even tested the voltages. when I plug power I see one NAND chip heats up. I guess Its about SSD failure. Can you guys help me in this matter. what should I do?
          I heard I can't replace only one chip. Is that true? where should I start? this is the first time I'm dealing with macbook.
          U8800 chip heats up
          Logicboard model No: 820-01041-A
          was able to find both brd file and schematics from this forum. here is the link to that.
          10-11-2022, 01:58 PM
