iPhone 11 Error -1
  • Instafixx
    • Jul 2022
    • 374
    • India
    iPhone 11 Error -1
    Helllo Everyone, Namaste.
    I have an iphone 11. The client was doing an OTA updae and the phone crashes and it is stuck in recovery mode. While trying to restore again was getting an Error 3194.
    We removed the NAND and used JCID P13 to format and restore the data. Now when we try to restore it via itunes or 3uTools we get an error -1.
    It sometimes gives the error halfway through or sometimes at the end
    at about 96% when doing via 3uTools
    Restoring Firmware when doing via iTunes.
    One more weird thing is that the device will simply not go into DFU mode at all. It is stuck at recovery mode only.
    Sharing a screenshot of the error at 3uTools. Its a parseregex error everytime.
  • mon2
    • Dec 2019
    • 14677
    Re: iPhone 11 Error -1
    Not sure if you have seen this video?
    https://www.youtube.com/watch?v=STnpmyMNWJ4
    • Instafixx
      • Jul 2022
      • 374
      • India
      The points are fine. Even if we are doing software with just the upper board getting an error too
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        The TV does not turn on, the standby indicator is on. All voltages are present.
        Emms is dead. Not readable, not detected.
        Replaced emmc.
        But with another dump there is no launch
        Terminal log
        UART
        AC_ON
        RPMB key is not yet programmed
        HASH1_VERSION=0x00000000 64bit
        E-B
        FDE enabled
        layout pattern onebin by SAR7,0...
        06-01-2025, 02:11 AM
      • AJ847.63e
        Has anyone Managed to ever solve DFU Restore error AM Restore Error Domain error75?
        by AJ847.63e
        Hi All,
        Judy doing some research on whether anyone's ever been able to resolve this. Seen quite a few examples and most have just gone eh guess it's dead, but surely there's something we can try?
        For instance, I'm working on a 2020 now with this error. Logiwiki says error 75 occurs when the system is in recovery mode but when I connect it to apple configurator it does show up as DFU so that doesn't seem right. When I try to restore it gets up to step 4/4 and the bar gets to the S of system then that's where it gives that code. Apple configurator then sits on "apple...
        06-02-2023, 12:12 AM
      • sushilachuthan
        APC UPS error P13
        by sushilachuthan
        one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
        the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
        The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
        We replaced the SCR with new device,, but the device is not power on as expected.
        Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
        09-26-2025, 09:00 AM
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
      • dbuergi
        Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
        by dbuergi
        this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
        Is there anything i can do?
        11-19-2024, 09:27 AM
