Has anyone Managed to ever solve DFU Restore error AM Restore Error Domain error75?
  • AJ847.63e
    • Aug 2020
    • 170
    • Africa
    Hi All,
    Judy doing some research on whether anyone's ever been able to resolve this. Seen quite a few examples and most have just gone eh guess it's dead, but surely there's something we can try?
    For instance, I'm working on a 2020 now with this error. Logiwiki says error 75 occurs when the system is in recovery mode but when I connect it to apple configurator it does show up as DFU so that doesn't seem right. When I try to restore it gets up to step 4/4 and the bar gets to the S of system then that's where it gives that code. Apple configurator then sits on "apple controller" instead of DFU.
    Is there a way to get a USB keyboard to work with the board in this state? I was hopping maybe the board is in recovery mode now and I could use the usual option R to try reinstall macos but don't want to reinstall the board into the chassis to use the internal keyboard.
  • AJ847.63e
    • Aug 2020
    • 170
    • Africa
    Re: Has anyone Managed to ever solve DFU Restore error AM Restore Error Domain error7
    Interesting. Connected the trackpad and retried and that seemed to work now Apple Configurator shows the lock icon.
    • iMuhtaseb
      820-02020 A2338 Restore/Revive Failed
      by iMuhtaseb
      A2338 - Pristine condition.. I took out of the board and inspected it.. nothing.. as if the computer is barely used even.
      Anyway, customer said they tried erasing/formatting it and it got stuck on Apple logo preventing to go further.. I asked them why they tried to erase it from the first place? They said it turned off randomly once.. then they erased it and it worked out for a few days then it shut off again..
      I put the computer in DFU; I downloaded the latest Ventura IPSW and restored it.. during the "Installing.." it restarts then it shows the exclamation...
      09-11-2023, 08:43 AM
    • stormanimal83
      Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
      by stormanimal83
      i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
      08-04-2024, 01:47 AM
    • Stephen
      iMac M1 DFU restore issue
      by Stephen
      iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
      this is the message it gives me with the error
      Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
      Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
      03-07-2025, 12:19 PM
    • harp
      is it possible restore data from the hdd with removed rom ic?
      by harp
      is it possible restore data from the hdd with removed rom ic so, is there any way, theory or practice, to restore or calculate missing data in flashrom ic from actual data stored on disk platers? In other words, is data on disc somehow reachable, recover without original rom firmware, using exactly donor board, special lab hardware, etc?
      12-26-2024, 05:00 PM
    • Bloodhoundje
      by Bloodhoundje
      03-16-2024, 03:12 PM
