IC compatibility?
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    IC compatibility?
    Hey Guys, I have a Lenovo AIO that came in for repairs.
    One of the issues is a dead ethernet controller chip (RT8111C).
    The only replacement I currently have is a RT8111H. Are the 2 interchangeable? I can't seem to find much info on the RT8111C.
  • mon2
    • 13923
    Re: IC compatibility?
    Datasheet is attached.
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      Hi mon2, it's not the RTL8111C. It written REALTEK 8111C, sometimes listed as RT8111C. The pin count is different.
      Similar to this: https://shopee.vn/REALTEK-8111G-IC-m...335.7305583727
      • stormanimal83
        somebody familiar with hasboard repairs? BM1397AD interchangeable with Bm1397AG ? S17+ and T17+
        by stormanimal83
        i got myself a complete Antminer T17+ with 3 dead hasboards for a very good price.... for parts i bought S17PRO boards.... i replaced all missing resistors and changed some asics because they were bad... but wihout a tester... i used the miner instead and changed firmware to awesome miner firmware for better and faster diagnoses via miner log and lower fan speed...
        for my understanding and what i read on the internet these asics should be interchangeable in one chain but in my case iΒ΄m getting no more communication to none of the asics on all 3 boards. 2 of the boards werenΒ΄t in...
        04-13-2025, 04:26 AM
      • SoulFreeze
        Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
        by SoulFreeze
        Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
        After repairing the above issue, I realized the following remaining problem,
        Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
        The computer recognizes headphones are connected and displays a popup in windows
        Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
        06-21-2025, 09:53 AM
      • Nagyesz
        Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
        by Nagyesz
        I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
        All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
        How can I extend its lifespan? Could reflow help?
        It has ryzen 5 5500h, rtx 2050, no soldered ram.
        Example of the artifacts:
        03-01-2025, 11:11 AM
      • pwnjuice
        Bitlocker issues
        by pwnjuice
        Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
        Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
        Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
        01-06-2025, 05:33 PM
      • Skgod
        Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
        by Skgod
        Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
        Black screen, freeze
        The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
        When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
        So can anyone tell me what would be the possible cause?...
        10-16-2024, 08:11 PM
