HP DV6-7245US Won't Charge
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Tried 3 batteries, all the same.... Wont charge on or off. OS (Windows or Linux) says 'not charging'. BIOS is the latest, batteries are good. OEM charger (also good).... At a bit of a loss.... Kind of a shame, its in mint condition with 16gb RAM in it.
    Maybe some of you laptop junkies might have some ideas.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • mon2
    • Dec 2019
    • 14663
    Re: HP DV6-7245US Won't Charge
    Review the voltage on each pin of the battery connector.
    Specifically interested in the SMBUS (aka I2C) port pin voltages (SCL & SDA) to ground.
    Post each measurement for a review.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Here's the connector:
      8 pins, read from left to right as in the photo:
      1 = 3.1v
      2 = 3.1v
      3 = 3.3v
      4 = 3.3v
      5 1~1.4 mV
      6 = 3.3v
      7 = 0
      8 = 0
      Charge LED is white when batt is out, with batt installed, it flashes back & forth from amber to white; occasionally I can hear a 'ticking' sound from the corner of the unit where the plug is. Laptop functions fine as long as it's plugged in; with or without a batt installed. If I charge the battery in another DV6, it runs fine on batt until the batt dies.
      Team : 49813
      Join in!!
      Team Stats
      • mon2
        • Dec 2019
        • 14663
        1) the smbus / I2c line voltages are fine.
        2) you may have the usual DCin mosfet failure. Locate the DCin power connector -> nearby should be 2 * DCin mosfets.
        a) what are there markings on the topside ? (to determine if N-channel or P-channel)
        b) need to check if they are defective or not as follows:
        Remove all power / no battery.
        Meter in resistance mode -> check the resistance across the mosfet pins:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each measurement. As per above sticky from @Pienov - often the 2nd mosfet gets damaged and leaks causing issues such as this one.
        Best to take and post each measurement but if convenient, replace the 2nd of the 2*DCin mosfets for quick testing.
        c) The same 2*DCin mosfets will be linked to a local charger IC which will be nearby. Which one is on your board ? Likely the TI (aka BenchmarQ = 'BQ') markings so the above mosfets will then be N-channel style but confirm each detail. From the charger IC information, we can review a typical schematic to debug this case.
        d) post any other silk screen markings on your logic board -> found a few schematics in the database with 'DV6' keyword.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          Much appreciated. I'll disassemble it tomorrow.
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            I'm still working on getting this thing apart....it's pissing me off. Palm rest/keyboard is all one piece, hung around the HDMI....and I don't want to break anything (didn't find any missed screws)....so I'll have to consult the google when I have a little more time to figure out what I'm missing...
            Team : 49813
            Join in!!
            Team Stats
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              Ok, finally got it....this was a bit of a pain to get apart....but I got it...and dind't break anything.
              The motherboard.
              Power section:
              What appears to be 'PQ3804' (so many numbered components around it) reads a short across the pins indicated with red dots. All neighboring transistors read as they should.
              Team : 49813
              Join in!!
              Team Stats
              • mon2
                • Dec 2019
                • 14663
                See attached.
                1) to avoid static charge kills, best to place perhaps a piece of cardboard underneath the logic board rather than carpet. ESD bags are even a better choice.
                2) what are the topside markings of the referenced parts in the attachment. PQ3804 may be a dual esd diode array for the battery SCL / SDA interface.
                Interested to know the square device part number which is probably a 'BQ' (TI) charger IC.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  Originally posted by mon2
                  See attached.
                  That is anti-static carpet....I promise, I'm not that careless!! ...but yea, I'll slip an ESD bag under it. Stand by for the numbers.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • mon2
                    • Dec 2019
                    • 14663
                    Can you also post any additional silk screen markings from your logic board? Perhaps have a schematic in my database or perhaps not but will search for it.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      The chip, you were correct; BQ738
                      The transistor is LNW28
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        Here you go. Unedited.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • mon2
                          • Dec 2019
                          • 14663
                          May have a hit...see attached.
                          1) PQ3804 = 2N7002 (SOT-23)
                          2) PD3802 is on your board - also in the next attachment.
                          3) PU4001 = BQ24738 charger IC
                          4) DCin charger mosfets - as per sticky from @Piernov, often the 2nd DCin mosfet gets damaged. Review the voltage on each pin of these 2 * DCin mosfets.
                          Interested in:
                          source (1-2-3)
                          gate (4)
                          drain (5-6-7-8)
                          voltage readings of each - PU4006 & PU4004 (likely the defective guy).
                          5) After the above check -> power down -> meter in resistance mode.
                          Check the resistance across the above 2 x mosfets as per above.
                          PU4004 is of interest. If really keen - replace this mosfet and test again.
                          These mosfets are N-channel so the gate has to be higher than the voltage it is passing and should be ~25v using the ACDRV pin on the charger IC (BQ).
                          Confirm it is this voltage to enable the 2 x DCin mosfets.
                          It is yabba-dabba-doo time at the office. Will continue to monitor the thread over the weekend. Do post your readings.
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            Same here and I'm going to be pretty busy this weekend...but I'll get this done.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16959
                              I haven't forgotten about this, just been crazy busy!!
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Astonished
                                Fixing the Charge Circuit of the Batteries of the DC Motor
                                by Astonished
                                Hi friends of electronics
                                What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                Please help me fix this circuit.
                                (the datasheet of the IC: https://pdf.datasheet.live/28...
                                01-28-2025, 06:24 AM
                              • ipatch
                                troubleshooting microsoft surface pro 4 no power no led charge light
                                by ipatch
                                hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                10-05-2023, 11:59 AM
                              • ruletero
                                Acer a515-43 low battery charge voltage
                                by ruletero
                                Hi
                                Acer A515-43
                                LA-H801P
                                Fail: Does not charge battery, has low voltaje on connector.
                                Laptop didn't want to turn on, only charge led blinked.
                                I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                10-24-2022, 02:31 PM
                              • dicky96
                                HP Laptop TPN-C125 replacement batteries will not charge after 12 months
                                by dicky96
                                I got four replacement batteries for these HP laptops about a year ago. The originals would not charge, and these replacements have now gone the same way.
                                I'm not sure what the expected life of a laptop battery is but I woud have thought they would last longer than that
                                I now need to order four more batteries. Possibly these replacement ones were now good? The owner does not mind paying a bit more for originals or good compatible batteries that last longer
                                The top one is the original
                                Any ideas?
                                Cheers...
                                05-19-2021, 07:53 AM
                              • razenxd
                                How can I charge that battery pack?
                                by razenxd
                                it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                Now, I have noticed a few things.
                                The "dead" battery, while connected to charger and NOT Charging will...
                                12-05-2024, 06:11 AM
