NOKIA c2 TA-1204 smd diode identify
  • ashan000
    • Jul 2022
    • 34
    • Sri lanka
    i need a big favour. i need to identify a smd diode. its codes as "B8 T " its a too small diode. plz help
    https://drive.google.com/file/d/1Idu...ew?usp=sharing
    https://drive.google.com/file/d/1O5Z...ew?usp=sharing
    • 22089
    Re: smd diode identify
    what motherboard is this on
    • ashan000
      • Jul 2022
      • 34
      • Sri lanka
      it is on NOKIA c2 (TA-1204)... locate near battery pin.
        • 22089
        Re: NOKIA c2 TA-1204 smd diode identify
        It could be a zener diode
        UDZ3V9B
        https://pdf1.alldatasheet.com/datash...S/UDZ3V9B.html
        Working voltage 3.890 - 4.160
        https://www.alldatasheet.com/datashe...K/UDZ3V9B.html
        BZT52H-C3V9
        https://www.lcsc.com/product-detail/...5_C454971.html
        Working voltage 3.7 4.1
        • ashan000
          • Jul 2022
          • 34
          • Sri lanka
          UDZ3V9B
          BZT52H-C3V9
          thank you for your time..
          but the diode have 2 pads under, not have legs. any suggestions?
          • mon2
            • Dec 2019
            • 14715
            Find a SMD zener diode that looks like what you have -> review the voltage to match what was discovered by @SMDFlea.
            It will help to use micrometers to measure the dimensions of the damaged part.
            Summary: it is a SMD zener diode but the final physical dimensions will have to come from your side so you can drop and replace onto the PCB pads of your logic board.
            • hobostove
              Corsair RM1000e - Help identify 5VSB Zener diode
              by hobostove
              Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
              Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
              There's a 22ohm resistor that's melted and open, but it still has the bands.
              The other part is a zener diode and it's top went to jesus, so I can't read the marking.
              It looks like the diode connects the source and drain of a TNY284...
              03-27-2025, 02:25 PM
            • jjne
              AUO M270QAN01 - identify diode?
              by jjne
              I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
              Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
              ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
              01-24-2024, 08:39 PM
            • jezzaaaa
              Identify replacement diode
              by jezzaaaa
              I'm trying to find a replacement diode for one that has gone short.
              I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
              I can't find the exact part number for sale. Similar...
              05-09-2023, 11:26 PM
            • gurj1979
              Ubiquitiu 24 port POE. Help Identify Diode 3pin)
              by gurj1979
              Hi again guys.
              Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
              I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
              Anyone help me identify the model of this Diode ?...
              08-23-2023, 08:39 AM
            • rddube
              Asus C423N motherboard - trying to identify diode
              by rddube
              Can anyone point me in the right direction as I am trying to identify which diode this is as in the red square.
              Many thanks!
              Ray...
              06-24-2023, 08:08 PM
