HP ProBook 650 G4 Blinking Amber Light
  • sect-sin
    • May 2022
    • 101
    • Hungary
    I have a HP ProBook 650 G4 with a continuously blinking amber light, no post issue. The motherboard version is CHROMIA-6050A2930001-MB-A01(A1), no schematics or boardview is available for it.
    What I have done so far is the following: There is no short anywhere on the board, and all high and low MOSFETs check out fine (I checked resistances across G-S-D as well as diodes). BIOS and EC both get 3.3V, I tried reflashing both with fixed versions from hoaca, no change.
    I measured all coil voltages, see attached image for values, some get voltages, some do not. 19V stops at one of the MOSFETs, which shows some strange values, see image for measurements (MOSFET is a SM3335PSQG). The charge controller is an Intersil / Reneas ISL9538H. Unfortunately there is no Datasheet available for it, so I do not know which pins to measure (see image).
    Can anybody help me in diagnosing this? Thank you very much in advance.
    Cheers,
    sect-sin
  • mon2
    • Dec 2019
    • 14667
    Re: HP ProBook 650 G4 Blinking Amber Light
    Attached is a reference schematic of the ISL9538 to get started.
    • sect-sin
      • May 2022
      • 101
      • Hungary
      Mon2,
      Thank you very much, this is great. What should I measure (with utmost care most certainly)?
      Cheers,
      sect-sin
      • mon2
        • Dec 2019
        • 14667
        From the internet...
        Blinking Amber: Indicates a battery that is the only available power source has reached a low battery level. When the battery reaches a critical battery level, the battery light begins blinking rapidly.
        Locate all mosfets near this IC.
        Post their top side markings. We want to learn if they are N-channel or P-channel mosfets.
        • sect-sin
          • May 2022
          • 101
          • Hungary
          The green ones are all N-channel AON6380, the red ones are all P-Channel SM3335PSQG. On the bottom side of the PCB, there is another SM3335.
          • mon2
            • Dec 2019
            • 14667
            In the posted picture of the logic board, the top left side of the isl regulator appears to have shorted solder pins.
            Has this board been worked on already?
            The other pins on the device are clean and you can see the pcb between each of the pins but not the left side.
            Suggest to flux and heat with hot air to clean up the soldering. Go in circles and the solder will melt and self align into the pcb pads. If it is only a bad angle of the picture then ignore.
            • sect-sin
              • May 2022
              • 101
              • Hungary
              I have been working on the board, I replaced one of the SM3335 Mosfets, because I thought it was faulty (but it was not). So flux got on the ISL, but I have not touched it (see attached). There is not short, I can confirm.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Your problem seems like 19V not crossing the 1st dc-in mosfet. It wont unless the gate voltage is correct. Measure , with care, voltage on pin 17/18/19/20/24/8 and post here. I hope u have checked the dc-in fets for shorting. Check Resistance on CLR also.
                • sect-sin
                  • May 2022
                  • 101
                  • Hungary
                  Hi mcplslg123,
                  Thank you for helping. I have measured everything, results are the following:
                  DCIN (17)=19,15V
                  VDD(18)=5,129V
                  ACIN(1)=3,866V
                  CMIN(20)=0V
                  ACOK(24)=3,305V
                  VDDP(8)=5,123V
                  I can confirm that none of the MOSFET's are shorted. I have attached a further picture showing what values both P-channel MOSFET measure.
                  Unfortunately I have no idea where the current limiting resistor is. If you can tell me what to look for, I will gladly measure.
                  Cheers,
                  sect-sin
                  • sect-sin
                    • May 2022
                    • 101
                    • Hungary
                    I forgot to attach the photo, here it is.
                    Cheers,
                    sect-sin
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      All the measurements seems good. Try replacing the charging IC.
                      • sect-sin
                        • May 2022
                        • 101
                        • Hungary
                        I have ordered a replacement, unfortunately none of my donor boards have it. Will be here in a week, will let you know the outcome.
                        Another thing came to my mind, as mon2 has already mentioned it. Is it possible that this notebook will not run without a working battery?
                        Cheers,
                        sect-sin
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Very unlikely. It should work without battery.
                          • Sephir0th
                            • Oct 2020
                            • 1289
                            Since some basic step down voltages like 5V, 3.3V and 1V are present and also ACOK is deasserted, I see no point to troubleshoot the DC-IN Circuit tbh. For the MOSFET in question near the NVDC circuit for creating the Main power rail you have to use your multimeter to to check to what it connects. Follow the rails and also look for connection the the charging controller just to be sure. It's hard to work without schematics but in these cases the multimeter is your only friend. if you don't want to troubleshoot the board for years you have to go ahead and check some things by yourself.
                            Do you have 3.3V at the power button by any chance?
                            FairRepair on YouTube
                            • sect-sin
                              • May 2022
                              • 101
                              • Hungary
                              Hi Sephir0th,
                              First of all, I checked, and yes, there is 3,3V at the power switch. As you mentioned, I searched for the gate connection of the SM3335 which receives 19V but does not turn on. I found it, it connects to a SOT-26 chip, but I have no idea what kind of chip it is. I have attached an image showing to which pin it connects.
                              There are two such chips with marking S2AN, the other S2AN is connected to the other SM3335 (which opens correctly), though the gate of that one is connected to a different PIN. I could further trace back the S2AN's to the charging IC.
                              Has anybody any idea on what this chip is?
                              Cheers,
                              sect-sin
                              • sect-sin
                                • May 2022
                                • 101
                                • Hungary
                                Today the new ISL9538 charging chip arrived from Mouser. I changed it, but unfortunately this did not help. The same blinking amber light prevails and it is driving me nuts. I think this board will be my nemesis, but I am definitely not about going to give up.
                                I will measure around randomly as Sepiroth has recommended, but would welcome any suggestions from you guys.
                                Cheers,
                                sect-sin
                                • dvbsmc
                                  • 17
                                  hi
                                  do you have white light with amber light blinking or only amber light blink without white light? (on the power connector)
                                  • sect-sin
                                    • May 2022
                                    • 101
                                    • Hungary
                                    It was amber blinking light, no white light. I do not have the board anymore though.
                                    Cheers,
                                    sect-sin
                                    • dvbsmc
                                      • 17
                                      thank you for your reply
                                      i have 2 board elitebook and probook with the NPCX797HA1BX IO, the white light is on and amber light blink, and all voltage are good, i tested multi dumps but same thing, i think the bga IO must be reprogrammed or earased or replaced with a new one
                                      • jverganio
                                        • Feb 2020
                                        • philippines
                                        Cheers,
                                        sect-sin
                                        Hi. Just a reference. Blinking orange light means a faulty/corrupted bios chip. In some cases bad solder joints on the bios chip.
                                        • huzo
                                          HP 470 G5 blinking amber light no power
                                          by huzo
                                          The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                          So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                          I've tried flashing the bios...
                                          interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                          06-08-2023, 04:08 PM
                                        • NConstantinou
                                          DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
                                          by NConstantinou
                                          I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
                                          WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
                                          BIIOS PINS 7,8 I HAVE 3.3V
                                          IS THE PROBLEM ON MOTHERBOARD OR BIOS.
                                          08-21-2025, 03:23 AM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • What?
                                          Vizio SV422XVT blinking amber/white power light
                                          by What?
                                          Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
                                          Problem:
                                          I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
                                          Power Board:
                                          I am getting 5v only. I have unplugged...
                                          04-27-2020, 06:21 PM
                                        • Jacksoft
                                          HP ProBook 440 G6 infinite orange blinking
                                          by Jacksoft
                                          I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
                                          The PC worked but it was very slooow to show HP logo in first place.
                                          A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
                                          The laptop doesn't power on anymore, and the blinking led happens...
                                          08-29-2025, 01:24 AM
