HP ProBook 650 G4 Blinking Amber Light
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Same motherboard, same bahaviour
    Q68100 :
    D=19.52v.../ G= 17.33v.../ S = 19.52
    Q68101 :
    S = 19.52.../ G = 19.48../ and Drain = 0.307v
    So voltage gate isn't acceptable !
    No 3 v/5 v are present...no short to Gnd..
    no 3v is present at PW connector :
    pin 1 =GND
    pin 2 = 0.111v
    pin 3 = 0.350v
    Pin 4 = 0.340v
    Same voltage for isl with post n #9
    but pin 24 is 0.009v
    DCIN (17)=19,15V
    VDD(18)=5,129V
    ACIN(19$)=3,866V
    CMIN(20)=0V
    ACOK(24)=0.009V
    VDDP(8)=5,123V
    At both 3/5 v circuit there's 12.63v
    the 3v circuit is marked = LE=5G 51y
    If somone have idea what to check else..thank you​
    • mon2
      • 14664
      Q68100 :
      Q68101 :
      Both mosfets are suspects. Remove all power. No battery. Meter in resistance mode.
      Measure the resistance across the mosfet pins:
      source (1-2-3) & drain (5-6-7-8)
      source (1-2-3) & gate (4)
      gate (4) & drain (5-6-7-8)
      Post each resistance measurement in ohms for these 2 mosfets.
      • lapfix
        • Mar 2020
        • 2764
        • my workshop
        Q68100 :
        red probe at drain
        source (1-2-3) & drain (5-6-7-8) = 3.353 mohm
        source (1-2-3) & gate (4) = OL
        gate (4) & drain (5-6-7-8) = OL
        inverse probe = all OL
        Q68101 :
        red probe at drain
        source (1-2-3) & drain (5-6-7-8) = 3.653 mohm
        inverse probe = all OL​
        • arber1232
          • 379
          • Albania
          Hi i have same problem with Hp 650 G4 charching port blinking amber ... But i see my cpu is litle hot .. Are you have samesyptoms ?
          • mon2
            • 14664
            Dua Lipa hot?
            Test the voltage to ground of each inductor on the board. Confirm there are valid voltages on each power rail. Test with a known good battery. Does the unit power up without the battery?
            • huzo
              HP 470 G5 blinking amber light no power
              by huzo
              The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
              So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
              I've tried flashing the bios...
              interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
              06-08-2023, 04:08 PM
            • NConstantinou
              DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
              by NConstantinou
              I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
              WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
              BIIOS PINS 7,8 I HAVE 3.3V
              IS THE PROBLEM ON MOTHERBOARD OR BIOS.
              08-21-2025, 03:23 AM
            • YasaCh
              Sony kdl 40p5500 red light keeps blinking 3 times
              by YasaCh
              Hello...
              my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
              i opened the back cover no sign of damage on the powery suply or motherboard
              when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
              another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
              07-07-2025, 11:53 AM
            • What?
              Vizio SV422XVT blinking amber/white power light
              by What?
              Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
              Problem:
              I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
              Power Board:
              I am getting 5v only. I have unplugged...
              04-27-2020, 06:21 PM
            • Jacksoft
              HP ProBook 440 G6 infinite orange blinking
              by Jacksoft
              I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
              The PC worked but it was very slooow to show HP logo in first place.
              A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
              The laptop doesn't power on anymore, and the blinking led happens...
              08-29-2025, 01:24 AM
