MacBook Pro 2010 15" 820-2850 no charge, green light, powers on
Re: MacBook Pro 2010 15" 820-2850 no charge, green light, powers on
Q7030 and Q7035 replaced, both at the same time.
No change.
Still Green LED and fan spin.
Gave it about a minute.
Was really starting to get my hopes high too.
Think I'm going to reassemble it to check where I stand on coconutBattery.
Could this actually be the DC in board?
It is a bit worn in the plastic on the sides of the connector.Comment
Well, things changed quite dramatically here.
In the good way.
I have an orange light again!
Got a "parts/wreck" identical mbp with a _working_ battery from a colleague.
Finally I had the possibility to do a sanity check, which would have saved me some time but robbed me from the experience I have gained (More valuable than time itself).
The two Subtel batteries would not charge in the parts machine, at all.
They wouldn't even run on their own without a charger.
Hopefully I still have a warranty with the seller.
mon2: A thousand thanks ("Tusen takk" in Norwegian) for your patience, guidance and knowledge!Comment
by crnimrkiMacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime. On power on fan spins 5 seconds then stop and again spin and stay spinning.
CPU Warm, DVD Drive not spinning, Mouse on USB Port inactive. No beeps without RAM DIMM-s.
PPBUS_G3H - 12.55V without battery, 11.99 with battery charging
PP3V42_G3H3.39V
PPVCORE_S0_CPU - 0.98
RAM VOLTAGE 1.49
Where to search... -
I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
by judamexMacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
by ipatchhello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
by vdrokko99Hello,
I'd like to ask help to repair 820-2850. There is green light, but not turning on because the PPVBUS_G3H is 0.5xxx V. I already measured resistance to GND, but no short ciurcuit. I did a few measure next to U7000,
R7020 ok,
R7050 ok,
F7040 ok,
SCM_RESET_L 3,4V
CHRG_DCIN 16V,
PP5V1_CHGR_VDD, and PP5V1_CHGR_VDDP is 0,5V but no short to GND
I think the missing PP5V1_CHGR_VDD is the problem which is comes from and go to the U7000.
This missing voltage means a defective U7000 or cause other missing voltage?... - Loading...
