Troubles with HP pro x2 612 g2
  • johnjohnjohnjohn
    • Sep 2019
    • 120
    • france
    #161
    Re: Troubles with HP pro x2 612 g2
    found it shorted, so replaced it just now, by one coming from a similar architecture laptop
    • johnjohnjohnjohn
      • Sep 2019
      • 120
      • france
      #162
      I did not work on the board since we last chatted, las time I lost all voltage battery and dc after replacing hidrv mosfet. I replaced it again today, I mean an hour ago, because i found it shorted, though it wasn't when i soldered it. With the new hidrv mosfet coming from the similar architecture laptop, battery works again, but dc still 5V
      • johnjohnjohnjohn
        • Sep 2019
        • 120
        • france
        #163
        I'm going to bed. I'll work on this board tomorrow for sure. Good night, or good day i should say
        • mon2
          • Dec 2019
          • 14137
          So on battery, the laptop works ?
          Measure the resistance (without power) of both, the high side and low side battery charging mosfets as well.
          It will be a good idea to replace both and purchase the replacements for the USB Type C as well as the 2 x DCin mosfets and the charger IC. Not each part needs to be replaced but good to have them as spares, if they are required. Basically want to be able to rebuild this circuit if required. Each are inexpensive from Aliexpress.
          this store should have each part (we use them often):
          https://www.aliexpress.com/store/173...55d8673b4CmdQY
          Plan B is to head on over to @Piernov's with a box of fresh (almond) croissants and this motherboard for repair. Have already selected the mode of transportation.
          • johnjohnjohnjohn
            • Sep 2019
            • 120
            • france
            #165
            I sent him a message. But, hum.. though I'm sure this vélocipède is fast, because big whell-big speed, Piernov lives very far from me, in fact it couldn't be further without leaving the country
            I found a new cypress IC (usb c) do you think I should try to swap it or is it just a waste of time ?
            • mon2
              • Dec 2019
              • 14137
              Is the Cypress chip you have from a similar donor board? If yes, then it is worth a try since it will contain the firmware. Do you see 12v on the donor board?
              As far as I can recall, it is a Cortex Mx processor that uses GUI tools to create the firmware. Puzzled as to why the logic board would not function when the battery was installed with the adapter. This condition is often linked to defective mosfets.
              • johnjohnjohnjohn
                • Sep 2019
                • 120
                • france
                #167
                I must find a suitable replacement for the one tpca8120 that is dead. Of course I found some mosfet of the same size, but only N channel when it need to be P channel
                • johnjohnjohnjohn
                  • Sep 2019
                  • 120
                  • france
                  #168
                  well. I suppose I shouldn't try, the donor board is not using usb c to power on, it has a separate standard Dell jack
                  • mon2
                    • Dec 2019
                    • 14137
                    Test the power adapter with another port on the logic board. Flip the power cable by 180 degrees.
                    Any difference in the voltage output at the mosfet #1 of the type c ?
                    Interesting find...
                    https://h30434.www3.hp.com/t5/Busine...r/td-p/7098443
                    The CCG4 is part of the BIOS update and is updating the usb-c port controller firmware - actually separate from the BIOS, but included in the update
                    • johnjohnjohnjohn
                      • Sep 2019
                      • 120
                      • france
                      #170
                      there are no other usb c on this board, it's tiny and only has a usb c, a usb a, audio and that's all. there isn't even a video output port.
                      • johnjohnjohnjohn
                        • Sep 2019
                        • 120
                        • france
                        #171
                        do you think i should try again injecting 11.8V on this mosfet ?
                        • mon2
                          • Dec 2019
                          • 14137
                          Check the resistance (without power) of the 2 x DCin mosfets @ charger IC.
                          • johnjohnjohnjohn
                            • Sep 2019
                            • 120
                            • france
                            #173
                            4.4KOhms, there is a 4K resistor on the road
                            OH ! I tried to put back the leacking tcpa8120
                            the first one smoked and now has a hole in it. The usbc V lines are now shorted
                            Removed the two tpca 8120, usb c no longer shorted, 5V waiting on the first TPCA drain pads
                            • mon2
                              • Dec 2019
                              • 14137
                              Ok. Leave the 2 x TPCA8120 off the board. That should remove them from the equation of this power path from the Type C connector to the charger IC.
                              Rotate the head of the power adapter to see if the CYPD4125 is able to negotiate a 12v power delivery contract.
                              Will study the CYPD4125 design but do not believe the mosfets are required to negotiate a valid power delivery contract.
                              The firmware is applied through a bios upgrade but of course the logic board has to be powered to boot.
                              Do you have spare N-channel mosfets for the charger IC ? Is that what is with a low resistance of 4k ? Yes, there is a 4k series resistor between the gate pins and the charger IC - that is from the TI datasheet / reference design.
                              • johnjohnjohnjohn
                                • Sep 2019
                                • 120
                                • france
                                #175
                                yes
                                4KOhms from pin 4 of bq24780s (ACDRV) to the gates of the two E6 GUD mosfets (DC)
                                what do you think about the strange behavior the pc had when I injected the 11.8V directly at the G8 VUD drain (this mosfet drain is the next pad where the 11.8V could be found after passing through the two USB DC tpca 8120)
                                • johnjohnjohnjohn
                                  • Sep 2019
                                  • 120
                                  • france
                                  #176
                                  now that the tpca s are removed, I have bigger pad to solder an inject wire, I can still try again. What do you think ?
                                  • mon2
                                    • Dec 2019
                                    • 14137
                                    1) confirm that the first mosfet driven by the 24780S does not have a low resistance to ground. This will be the first of the 2 x DCin mosfets. It should be ok but just confirming.
                                    2) After the above, since the TPCA8120 are removed, there should not be anything else in the power path from the Type C circuit. You should be able to apply the 12vdc from your power supply onto the first 2 x DCin charger IC mosfet.
                                    When you do this, ACDET pin on the charger IC should be a high enough value to enable the same 2 x DCin mosfets. Check the voltage of ACDET.
                                    Also check the voltage of REGN pin on the 24780S. This should be ~6 volts on REGN. This rail is important to create the boost voltage required for pin # 4 of each N-channel mosfet linked to this IC.
                                    Current limit your power supply to be similar to the HP power adapter rating.
                                    HP website notes that 45W is the default power adapter but a 65W is available for rapid charging of this unit. The 65W most likely supports the use of 20V power delivery contracts - like the rest of the industry.
                                    Aliexpress sells small bridge boards ($1-$2 USD) that auto-enable the power delivery contract out of your adapter. That is, a 12v bridge board will select the 12v PD contract provided your adapter has this contract. A 20v bridge board will select the 20V contract, etc.
                                    Cypress sells a small board with a rotary switch to select other voltages - provided your adapter has the same support.
                                    These bridge boards are effectively the same as the CYPD4125 design on your board.
                                    • johnjohnjohnjohn
                                      • Sep 2019
                                      • 120
                                      • france
                                      #178
                                      12V at dc mosfet drain. its gate receive 0 so the 12V stay there. ACDET is at 3V REGN is at 5.1V
                                      • mon2
                                        • Dec 2019
                                        • 14137
                                        REGN is low in the voltage. It should be 6v.
                                        With no power, check the resistance to ground of the REGN pin.
                                        • johnjohnjohnjohn
                                          • Sep 2019
                                          • 120
                                          • france
                                          #180
                                          REGN resistance is OL
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            by sam_sam_sam
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
                                            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                            by sam_sam_sam
                                            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                            So I have put them on the battery testing machine to drain each battery cell down to...
                                            09-04-2022, 04:45 PM
