Troubles with HP pro x2 612 g2
  • johnjohnjohnjohn
    • Sep 2019
    • 120
    • france
    #141
    Re: Troubles with HP pro x2 612 g2
    Ok, so i placed the mosfet back. Nothing better. I checked it for short, and the desoldering must have finished it, it now show only 5kOhms from S to D. I tested the pads on the board after removing it, no short, it really seems it s just that it finished "dying" ? I put back to replacement one (that seems good when I check it on the board) but now, not boot at all, but on dc I can read 11.8V on the two USB C V pins
    • mon2
      • Dec 2019
      • 14634
      If you see 12v from the adapter, the USB Type C negotiations have been performed correctly by the Cypress CYPD4125 power delivery controller and its firmware.
      1) Do you see 12v AFTER the 2 x USB-C mosfets ? Same voltage should appear at the first of the 2 x DCin charger mosfets.
      Confirm this detail.
      2) Next, probe the 2 x DCin charger mosfets for the voltages on each pin:
      source (1-2-3)
      gate (4)
      drain (5-6-7-8)
      • johnjohnjohnjohn
        • Sep 2019
        • 120
        • france
        #143
        I d'ont have 11.8V anymore, now it stays at 5V
        I was goign to give up, thinking it fried for good. But in fact in boots fine on battery now. And you know I had to pull another mosfet, this time from a tiny asus, thes one that used core M in 2016. So this one does not seem to go bad.
        • johnjohnjohnjohn
          • Sep 2019
          • 120
          • france
          #144
          it s back to square one, let s say, but this time it doesn't work on dc at all. Sometime when it get worse it become easier to diagnose the part failing. Could it be the case here ?
          • mon2
            • Dec 2019
            • 14634
            Remove all power -> meter in resistance mode.
            Measure the resistance across the 2 x USB Type-C circuit mosfets:
            source (1-2-3) & drain (5-6-7-8)
            source (1-2-3) & gate (4)
            gate (4) & drain (5-6-7-8)
            Check each of these mosfets.
            Repeat for the 2 x DCin charger mosfets.
            Post each measurement.
            If push comes to shove - you can remove one of the USB Type C mosfets (the 2nd one) and apply a normal 12v power supply onto the first of the charger DCin mosfets.
            That is, then a traditional 12v power adapter at the proper current can power this beast.
            • johnjohnjohnjohn
              • Sep 2019
              • 120
              • france
              #146
              S to G 50kOhms on both usb c mosfets
              S to D and G to D are OL
              dcin mosfet are fine, more than 500KOhms on all reads
              • mon2
                • Dec 2019
                • 14634
                Post the top side markings again of each of these USB Type C related mosfets.
                Suspecting that the 2nd one is defective since that is where the injection was placed and it is making both of them look low in resistance for the S-G reading.
                • johnjohnjohnjohn
                  • Sep 2019
                  • 120
                  • france
                  #148
                  Tpca 8120
                  • johnjohnjohnjohn
                    • Sep 2019
                    • 120
                    • france
                    #149
                    should I remove it to check ?
                    • mon2
                      • Dec 2019
                      • 14634
                      Yes. With care so other parts do not go flying.
                      • johnjohnjohnjohn
                        • Sep 2019
                        • 120
                        • france
                        #151
                        mhh, i forgot which one was to one i injected...
                        • mon2
                          • Dec 2019
                          • 14634
                          50/50 so flip a coin. Suspecting the first one is ok so it will be the one that is mated with the 2 x DCin CHARGER mosfets to review.
                          After removal, interested in the S-G readings again of both.
                          • johnjohnjohnjohn
                            • Sep 2019
                            • 120
                            • france
                            #153
                            yep. Second one
                            • mon2
                              • Dec 2019
                              • 14634
                              If you attach the power adapter now (without this 2nd mosfet) - do you get 12v ?
                              Granted the voltage will not reach the DCin charger mosfets but curious. This is like an open switch / relay now since this mosfet is removed.
                              • johnjohnjohnjohn
                                • Sep 2019
                                • 120
                                • france
                                #155
                                but i can t manage to see this leaks on the mosfet itself, it s just by probing the pad that I saw to leak disappear when removing it
                                • mon2
                                  • Dec 2019
                                  • 14634
                                  What is the resistance of S-G pins on the removed mosfet ? Is it low ?
                                  • johnjohnjohnjohn
                                    • Sep 2019
                                    • 120
                                    • france
                                    #157
                                    still at 5v
                                    • johnjohnjohnjohn
                                      • Sep 2019
                                      • 120
                                      • france
                                      #158
                                      could heating the leaking mosfet had temporarily fixed it ? I mean not fixed it for real, because now it s remove i can't see any leaks
                                      • mon2
                                        • Dec 2019
                                        • 14634
                                        Yes - perhaps. Have seen when we purchased some early models of a VOIP handset during a visit to Taipei, the phone LCDs were pixelated now and then. The vendor was somewhat surprised but said they would replace the handset. We opened up the unit and found a fast 8051 microcontroller with a local SRAM IC. The speed (from memory; no pun) was ~150ns or 200ns access time). We proceeded to find the fastest version from Digikey @ 100ns - 120ns access time. While waiting, we reflowed the slower part on the phone -> the display worked 100%. After 20-30mins later (ie. the memory chip was at room temp); the display became pixelated again. Repeat the cycle, fix the display.
                                        When the replacement part arrived from DK, the faster grade of memory worked 100% without heating.
                                        So perhaps yes for your case. To summarize, you had 12v earlier today on the Type C adapter ?
                                        • johnjohnjohnjohn
                                          • Sep 2019
                                          • 120
                                          • france
                                          #160
                                          i had 12V until last test by replacing a leaking mosfet, the hidrv if i rember correctly, or was it the ldrv
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • flat-earther
                                            how to prevent a connected charger from draining battery when not charging?
                                            by flat-earther
                                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                            So the battery is backfeeding the charger and being drained.
                                            How can I prevent...
                                            08-07-2025, 01:04 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            by sam_sam_sam
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
