Troubles with HP pro x2 612 g2
  • johnjohnjohnjohn
    • Sep 2019
    • 120
    • france
    #101
    Re: Troubles with HP pro x2 612 g2
    ok, first here is the adapter photo :
    • johnjohnjohnjohn
      • Sep 2019
      • 120
      • france
      #102
      the nintendo switch adapter can only do 5 and 15V, I tried to plug it, nothing happens and i read 5.3V at the two usb c V pins
      I tried with my Mii 11 phone adapter, it can go up to 20v (but with a weak 1.35A) but it doesn't even negociate.
      • mon2
        • Dec 2019
        • 13834
        Only if you feel comfortable, consider to use your external lab power supply to mimic the power adapter.
        To do this, disconnect the external Type C power adapter.
        Now the TPC8120 mosfets will remain off.
        Dial up your DC power supply to 12v @ 3A (current limit it to this value).
        Ground to ground.
        Red power lead to the DCin mosfet (first mosfet where you measured the 0 ohms to the TPC8120 mosfet).
        While the TPC8120 remains OFF; you will inject this external power supply feed.
        With this condition, the ACDET should go HIGH -> charger IC should turn ON the 2 x DCin mosfets and power the logic board.
        Test with and without the battery if you proceed. In theory, the battery should also charge under this setup.
        Have to wolf down a late breakfast and then fix some blinds (they are not the LG brand) - BBL.
        • johnjohnjohnjohn
          • Sep 2019
          • 120
          • france
          #104
          I injected 11.83V on the first dc mosfet drain, the same 11.83V that can be read when the board is power with the usb c charger.
          When current is applied, the port led blinks as it does when plugged on dc, but then turns off, and the logic board too.
          • mon2
            • Dec 2019
            • 13834
            That bytes.
            See attached on the ref design of the charger IC.
            Locate the other mosfets on your board that are the high and low side for the battery charging.
            These are mosfets Q4 (high side) and Q5 (low side) in the attachment.
            Respectively, they will be connected to pin 26 and 23 on the charger IC.
            Once you locate the mosfets, post a pic of the parts. Remove all power and measure their resistance across the pins, as you have done before.
            We are checking if perhaps the high side mosfet is leaking. Check even the low side mosfet.
            Post your measurements.
            • johnjohnjohnjohn
              • Sep 2019
              • 120
              • france
              #106
              hi, ok
              So first of all, in the photo 2 you ll see that the pin 26 goes, it seems, to the intersil IC (photo 3) :
              I read resistance values coming from pin 26 of bq24780s on many, many pins of this IC
              I can't find any datasheet for this IC.
              I can't find where pin 23 goes. It directly sink into the board... I didn't find any track of it
              Pin 26 gives reading on these components around BQ24780S (see first photo) : K727, A7W,
              L43 (x2), SBI, NM742 (below SB)
              • mon2
                • Dec 2019
                • 13834
                Search for mosfets with 8 pins like before.
                • johnjohnjohnjohn
                  • Sep 2019
                  • 120
                  • france
                  #108
                  Ok,
                  The task is pretty hard... I have readings from pin 26 on almost every 8 pins mosfets I found... ! How can I proceed ?
                  • mon2
                    • Dec 2019
                    • 13834
                    See the ref schematic. The mosfets will be close to a coil (grey?). The mosfets will share common pins like schematic and probably near the battery connector since this rail charges the battery.
                    Post pics of mosfets that you find and their topside markings.
                    Assuming that they will be single package single mosfets like before.
                    • johnjohnjohnjohn
                      • Sep 2019
                      • 120
                      • france
                      #110
                      These two mosfets might be the ones...
                      I marked them with a white Posca
                      What s your take on this ?
                      • mon2
                        • Dec 2019
                        • 13834
                        Perhaps. Remove all power.
                        Meter in resistance mode.
                        Check the resistance from the grey coil to the battery connector where you saw the red wires. Do not connect the battery. Measure only at the battery connector on the logic board.
                        The resistance should be ~0 ohms if the coil is the correct one. The mosfets we wish to measure will be connected to the same coil.
                        • johnjohnjohnjohn
                          • Sep 2019
                          • 120
                          • france
                          #112
                          the resistance is 0 on the red wires corresponding pins. In fact it is the only one with 0 resistance.
                          • mon2
                            • Dec 2019
                            • 13834
                            With meter in resistance mode. No power / no battery.
                            Place one meter probe on the connector where the battery red wires end up on the logic board.
                            Place other meter probe on the nearby coil you can find.
                            If you read ~0 ohms on this test, then the coil is linked to the battery charging.
                            Confirm the part and location if you find this measurement to be ~0 ohms.
                            • johnjohnjohnjohn
                              • Sep 2019
                              • 120
                              • france
                              #114
                              Indeed, the grey coil, just beside the G8 VUD mosfet, is the only one showing 0 Resistance to the three red battery pin
                              • mon2
                                • Dec 2019
                                • 13834
                                Perfect. Now review which side is the source (pins 1-2-3) will be shorted; pin 4 by itself; drain (pins 5-6-7-8) will be shorted - for each of these mosfets.
                                Then proceed to continue to test the resistance across the mosfet pins:
                                source (1-2-3) & drain (5-6-7-8)
                                source (1-2-3) & gate (4)
                                gate (4) & drain (5-6-7-8)
                                Post the readings of each measurement.
                                Then repeat for the next mosfet that is also connected to this coil.
                                One mosfet = high side.
                                Other mosfet = low side.
                                These 2 mosfets & the coil you have found are responsible for the battery charge voltage. Each mosfet pulses ON / OFF till the ideal charge voltage is in range for your target battery pack. This is a BUCK regulator and accepts the high input voltage (12V in your case) and lowers it to a safe value for the battery pack.
                                The LOW side mosfet will have ~0 ohms resistance to ground on likely the source (pins 1-2-3).
                                • johnjohnjohnjohn
                                  • Sep 2019
                                  • 120
                                  • france
                                  #116
                                  left mosfet on the photo (7506 GA 712H)
                                  Source to Drain 1050KOhms
                                  S to G 230K
                                  G to D 1500K
                                  Right mosfet (G8 VUD 71Z04) It has 0 resistance to ground on its source
                                  S to D 12.8K
                                  S to G 195K
                                  G to D 216K
                                  • mon2
                                    • Dec 2019
                                    • 13834
                                    S to D 12.8K
                                    This measurement looks very low.
                                    Do you have hot air tools (flux / tweezers / hot air station) to remove this mosfet so that it can be tested out of circuit ?
                                    When the mosfet is out of the circuit, the same S-D resistance should be checked once it is cool to do so.
                                    • johnjohnjohnjohn
                                      • Sep 2019
                                      • 120
                                      • france
                                      #118
                                      yes, i remove it right away, let's see
                                      • johnjohnjohnjohn
                                        • Sep 2019
                                        • 120
                                        • france
                                        #119
                                        ok, so
                                        probing the empty traces :
                                        S to D keeps climbing over 500KOms
                                        G to S about 200KOms
                                        G to D keeps climbing over 500KOms
                                        I took the tiny mosfet and probed it for resistance. It s almost 0Ohms Source to Drain
                                        • mon2
                                          • Dec 2019
                                          • 13834
                                          Ok - back from the never ending shopping for groceries...
                                          1) Measure the resistance on the pins of the actual mosfet you have removed (not the PCB pads). We want to check if the removed mosfet is leaking / defective without influence of the other parts on the logic board.
                                          Post each measurement.
                                          2) Which tiny mosfet ? Can you post a pic ? What are the top side markings ?
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            by sam_sam_sam
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
                                            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                            by sam_sam_sam
                                            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                            So I have put them on the battery testing machine to drain each battery cell down to...
                                            09-04-2022, 04:45 PM
