Troubles with HP pro x2 612 g2
  • mon2
    • Dec 2019
    • 13867
    Re: Troubles with HP pro x2 612 g2
    No - this is only a USB hub controller. It fans a single USB port into multiple for your laptop.
    • johnjohnjohnjohn
      • Sep 2019
      • 120
      • france
      #62
      hidden under the small metal cover
      • mon2
        • Dec 2019
        • 13867
        From here:
        https://support.hp.com/us-en/drivers...12-g2/14432855
        it appears your controller onboard will be from CYPRESS.
        then search for an IC with the following graphics on the topside:
        https://www.bing.com/search?q=cypres...NTA1&PC=EDGEDB
        See attached and it appears that there is a firmware tool / update to allow you to update the Cypress firmware. This is desirable to confirm you are current and that this tool can reflash the controller.
        It cannot hurt to perform this update.
        • johnjohnjohnjohn
          • Sep 2019
          • 120
          • france
          #64
          • mon2
            • Dec 2019
            • 13867
            That helps. See attached.
            Cypress p/n CYPD4125 is the USB Type C controller for this logic board.
            Does your power adapter power up this unit each & every time (without the battery connected) ?
            The other chip, nearby is the TI 2546 which is a load switch - we can ignore this since your issue is with the main power source; not the downstream devices you may want to charge.
            Datasheet for both are attached.
            • johnjohnjohnjohn
              • Sep 2019
              • 120
              • france
              #66
              yes every time
              Oh the updated firmware was for docks only
              Indeed I think this throubleshooting of the board will help many people, because there really nothing to be found elsewhere
              • mon2
                • Dec 2019
                • 13867
                See attached. With great care, review the voltage readings of the VBUS control pins.
                That is, when the adapter is connected - these pins should offer some voltage to enable local mosfets (that should be nearby this controller IC).
                These mosfets then feed to the charger IC.
                If these mosfet driver pins are not enabling then the fault could be with the CC1 and CC2 pins on this IC.
                To check the CCx pins; remove all power; meter in DIODE MODE.
                Red probe to GROUND. Yes, RED probe.
                Black probe to CC1 pin -> what is the reading ?
                Repeat for CC2 pin -> what is the reading ?
                Also - with no power -> meter in resistance mode -> do check the resistance to ground of any and all polarized caps nearby. Especially the tantalum in your posted picture. Tantalums are crap - we do not use them in any of our designs - with pride. Tantalums are cheap and are for planned obsolescence. When they die, they act like a short.
                I am being pulled away - will continue to review over the weekend and post when I can. Review the above details and post your measurements.
                • johnjohnjohnjohn
                  • Sep 2019
                  • 120
                  • france
                  #68
                  here are the readings
                  pin 7 0V
                  pin 9 0.67V
                  pin 11 0V
                  pin 12 4.75V
                  I don't think I have diode mode ou my tools
                  • johnjohnjohnjohn
                    • Sep 2019
                    • 120
                    • france
                    #69
                    could it really be the charger ??
                    • mon2
                      • Dec 2019
                      • 13867
                      Post a pic of your meter.
                      • johnjohnjohnjohn
                        • Sep 2019
                        • 120
                        • france
                        #71
                        Oh wait, there s a diode mode...
                        I check the ic in the morning. Here in France it's 11:30 pm. Thank again. If we can figure out the problem I ll owe you a big one
                        • johnjohnjohnjohn
                          • Sep 2019
                          • 120
                          • france
                          #72
                          hello.
                          I measured in diode mode the cypress ic pin 7 and 9
                          When red probe on ground, the black one read 0.53V on pin 7 and 9
                          I tried just in case to test with black on ground and red on pin 7 and 9, in that case pin 77 and pin 9 reads 0.77V
                          Now I try to check tantalum caps, but for me it's hard to recognize which one are concerned. I'll update what I manage to understand.
                          So there only so much polarized caps that I found. I believe they are always marked with a white stripe on positive, right ?
                          • johnjohnjohnjohn
                            • Sep 2019
                            • 120
                            • france
                            #73
                            here I managed to take a photo trough my microscope. Is it normal that the cap pointed by the toothpick is grounded on both side ?
                            • johnjohnjohnjohn
                              • Sep 2019
                              • 120
                              • france
                              #74
                              on a few post before you asked me to measure the cypress ic pin 7 9 11 12 when on charger.
                              I did it again, this time running on battery and plugging the charger after the board is powered on. In that case, reading are : pin 7 0V pin 9 0.7V pin 11 0V pin 12 0V
                              Though I'm still reading 5V on the two pin on the usb c port.
                              • mon2
                                • Dec 2019
                                • 13867
                                When you manage to glitch the external adapter to work, there is a 12v output from the power adapter.
                                This voltage is switched through mosfets before it reaches the battery charger IC mosfets.
                                Study the parts near this Cypress usb C controller to locate these other mosfets. These parts will be linked to the usb C Vbus line of the connector. We need to test these mosfets.
                                Post pics of other parts in this area. The mosfets will likely be 8 pins and similar to the other mosfets.
                                • johnjohnjohnjohn
                                  • Sep 2019
                                  • 120
                                  • france
                                  #76
                                  When running on the charger alone, the two TCPA 8120 have 12V at Source, 12V at Drain, and 0.20V at gate. I checked their resistance : Infinite S to D, infinite G to D, 50KOms G to S
                                  • mon2
                                    • Dec 2019
                                    • 13867
                                    The parts are TPC8120. They are p-channel mosfets and look correct for the type C controller usage.
                                    The voltages are correct to enable each mosfet.
                                    When with the adapter alone, confirm the 12v presence on each boot..test a few times. This is important to confirm the power delivery contract is being negotiated.
                                    After this confirmation, measure if the 12v reaches any of the pins of the battery charge mosfets. It should.
                                    In this case, the logic board is not powered?
                                    When you glitch the board to work, measure the same path of voltages. Do you still see 12v travel through these mosfets?
                                    What is the gate voltage of these mosfets when working?
                                    Have a concern of the low resistance being measured between gate and source. One of these mosfets may be leaking. The resistance should be much higher.
                                    • johnjohnjohnjohn
                                      • Sep 2019
                                      • 120
                                      • france
                                      #78
                                      in fact, if the battery is not plugged in, the logic board turns on as soon as I plug the usb c charger. Everytime. Always 12V. I even used the pc like this a few hours. We could say it works normaly when battery is not plugged, though it display an error message every boot wrning me about the issue with the battery (bios think it s ether dead or missing, which is true. Same as if I use the pc on battery, i works fine, but in that case the usb c port seems deactivated. The type A is working fine.
                                      The glich I found was that if I "hot plug", I mean I plug the battery on the logic board while the pc is already powered on with the usb c charger, then the battery charges. That's how I did to be able to use the battery alone.
                                      • mon2
                                        • Dec 2019
                                        • 13867
                                        Attach both, battery and charger.
                                        Measure the voltage on these tpc8120 mosfets and also the charger 2 x DCin mosfets.
                                        Post the readings.
                                        • mon2
                                          • Dec 2019
                                          • 13867
                                          Measure also the voltage on each pin of the battery connector.
                                          The battery management system (BMS) is communicating with the charger IC over the smbus / I2C interface. Need to be sure the SCL and SDA pins are ok.
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            by sam_sam_sam
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
                                            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                            by sam_sam_sam
                                            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                            So I have put them on the battery testing machine to drain each battery cell down to...
                                            09-04-2022, 04:45 PM
