Troubles with HP pro x2 612 g2
  • johnjohnjohnjohn
    • Sep 2019
    • 120
    • france
    #41
    Re: Troubles with HP pro x2 612 g2
    yes, i did that. I just tried something else. I did my hot plug, you know, this time first plug the usb c port, THEN the battery. In that case, the readings on the dc mosfets are the usual 11.8V on S and D BUT only 16V on gate ??
    • johnjohnjohnjohn
      • Sep 2019
      • 120
      • france
      #42
      and sorry for the misunderstanding, I missed a message because of the new page of the thread
      • mon2
        • Dec 2019
        • 13837
        Ok. This is getting closer...see my last post. The charger IC is performing the selection of the mosfets.
        • johnjohnjohnjohn
          • Sep 2019
          • 120
          • france
          #44
          so yeah, the first reading were with battery first plugged in then DC charger, and now, the new one are with the reverse
          • johnjohnjohnjohn
            • Sep 2019
            • 120
            • france
            #45
            do you think I should try to swap it with the other one I have on an old board ? both are named BQ24780S only the other markings below are different
            • johnjohnjohnjohn
              • Sep 2019
              • 120
              • france
              #46
              I just saw your updated message
              So if both jack and battery plugged in but battery first, it shuts down the pc, the batt gate -Error, meant batt Source and Drain- is still 8.3v, The ACOK et ACDET are at 0V
              If Jack (i mean usb c) first then battery, the light is on, and then the ACOK and ACDET are at 3.3V
              • mon2
                • Dec 2019
                • 13837
                So if both jack and battery plugged in but battery first, it shuts down the pc, the batt gate is still 8.3v, The ACOK et ACDET are at 0V
                For this case, what is the voltage on the 2 x DCin mosfet pins ?
                Do you still see ~12v present on the first mosfet ? Post each voltage reading.
                With batt gate @ 8v3, the N-channel mosfet is being told to remain OFF.
                • johnjohnjohnjohn
                  • Sep 2019
                  • 120
                  • france
                  #48
                  no, in the case of plugging the battery first, as soon as i add the usb c, it turn the light off. But I still can read the battery mosfet, 8.3V Drain and Source, 14.3V at Gate
                  The two DCin mosfets are then at 0V S, 8.3V D and 0V G
                  EDIT sorry, in my previous message I meant 8.3V Source and Drain, not gate
                  • mon2
                    • Dec 2019
                    • 13837
                    Take your external power adapter and flip it 180 degrees and insert back into your laptop under the same conditions.
                    Anything different in the operation ?
                    • johnjohnjohnjohn
                      • Sep 2019
                      • 120
                      • france
                      #50
                      no
                      • johnjohnjohnjohn
                        • Sep 2019
                        • 120
                        • france
                        #51
                        once the pc start on battery, the usb c dc in stop being recognized, per say. No light if I connect anything
                        • mon2
                          • Dec 2019
                          • 13837
                          Do you have any other USB Type C power adapter for testing ? Or another USB type C device that can be used for testing ?
                          It is possible that the external adapter is flaky and not able to power up the logic board. The power delivery contract is enabled over negotiations. A USB Type C bus analyzer is a good tool to use here to validate on what the adapter and logic board are chatting about, if anything.
                          Or, the logic board's power delivery controller IC is acting flaky due to some fault of the CCx lines (CC1 is on one side / CC2 on the other side of the Type C connector blade).
                          Try:
                          1) Power down -> leave in the battery -> meter in DC volts scale (20V scale is ok).
                          2) attach the power adapter -> check the voltage of each pin you can see on the logic board - these are small through hole solder blobs for this connector. Red probe on a hole; black to ground. One of your posted pics has clear access to these points.
                          Measure each voltage. By default, you must see 5v on one combination of these test points. After negotiations, you should see the expected ~12v.
                          Check each connector pin and post your results with the voltages.
                          • johnjohnjohnjohn
                            • Sep 2019
                            • 120
                            • france
                            #53
                            I do it. I have one other usb c charger. It s the nintendo switch one. USB C, can negociate from 5 to 15V at 2.6A when the HP goes up to 3A
                            • mon2
                              • Dec 2019
                              • 13837
                              That is ok - try with the Nintendo unit to test the results.
                              Use the other USB C charger and connect to this HP.
                              • johnjohnjohnjohn
                                • Sep 2019
                                • 120
                                • france
                                #55
                                ok, meanwhile, I found two 5v pins with hp charger. nothing else
                                • johnjohnjohnjohn
                                  • Sep 2019
                                  • 120
                                  • france
                                  #56
                                  Wait, on the nintendo switch adapter, it s only written 5v and 15V. Will it fry something then ?
                                  • johnjohnjohnjohn
                                    • Sep 2019
                                    • 120
                                    • france
                                    #57
                                    I have a power supply, that can be set from 0 to 30V 5A. I can maybe wire it to the board ?
                                    • johnjohnjohnjohn
                                      • Sep 2019
                                      • 120
                                      • france
                                      #58
                                      ok, so let's forget the nintendo charger idea.
                                      So, I measured the usb c pins. If I measure themafter the board is on, without battery, only on the usb c charger, It's at 11.83V on two pins.
                                      If I measures them when the board is on battery, and i plug only after a seconde or two the usb c, they stay at 5V.
                                      I suppose that it means the board negociate with the adapter as it should. But then, why isn't the port ok anymore when the battery is plugged in ?
                                      • mon2
                                        • Dec 2019
                                        • 13837
                                        yes, agree with your last posting.
                                        Confirm that the external adapter is able to power the logic board everytime without the battery.
                                        On this board, connected to the CC1 & CC2 pins of the Type C connector will be a power delivery controller IC. This controller IC will feature a USB Vbus mosfet. Very likely this mosfet should be visible on the board - that is, the mosfet on the past generation of designs are still external to the controller IC.
                                        Review the board for other controller chips that should look similar to the 24780S - perhaps from Cypress or ST or Infineon (now the owners of Cypress).
                                        Take pics and post them here.
                                        • johnjohnjohnjohn
                                          • Sep 2019
                                          • 120
                                          • france
                                          #60
                                          could it be this one ?
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            by sam_sam_sam
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
                                            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                            by sam_sam_sam
                                            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                            So I have put them on the battery testing machine to drain each battery cell down to...
                                            09-04-2022, 04:45 PM
