LA-6901P no display, cpu_core 0.5v and vgfx_core 0v
  • teknosrp
    • Nov 2018
    • 9
    • netherlands
    Hello
    I was trying to fix a laptop with LA-6901P board (schematic available in many sites). It was totally dead and found a problem with the battery charging circuitry. Bypassed it and now it powers on from the ac adapter, power led stays lit, fan spins a few seconds but shows no image. It does the same powering it from a already charged battery
    I started checking voltage rails and found all correct except cpu_core, which was at about 0.480v, too low for me, and vgfx_core, which remained at 0v. Removing the ram makes no difference, and removing the cpu makes vcore rise up to about 4v and board powers off itself after some seconds. Is this 0.480v vcore value normal before fully booting? What can be the problem?
    If someone wants to know, problem with battery charging circuitry was a shorted low-side mosfet at the charging buck regulator and an open resistor at the charging IC (ISL6251) 5v regulator input. IC was shorted internally and I had not replacement, so I removed the charging IC, fed 5v externally to pin 1 and tied to ground the ac adapter plugged in signal (ACPRN) in order to bypass it.
    Thanks to anyone reading this and willing to help.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: LA-6901P no display, cpu_core 0.5v and vgfx_core 0v
    0.48V as Vcore is too low. However, i think the reason could be charging IC bypass. You should get the requisite parts and replace them before diagnosing further. Charging ic is connected to SIO-so it may misbehave with some inputs/feedback missing.
    • teknosrp
      • Nov 2018
      • 9
      • netherlands
      Replacing the IC surely is the best option, but as it takes too long to arrive from china and this IC seems to have few feedback pins, I decided to try first without it.
      The IC is an ISL6251AHAZ. By reading the datasheet and looking at the board schematic I interpret that it is active only during ac adapter operation, and running the laptop from a already charged battery does not change the laptop behavior. So I doubt this is the problem.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Charging Ic communicates with SIO thru SMBUS.
        • teknosrp
          • Nov 2018
          • 9
          • netherlands
          Hello
          Thinking about the problem I have another hypothesis. The CPU VRM has two phases, and the GFX core one. Measuring the resistance between the high side mosfet gate of each phase to ground I obtain these values:
          - CPU phase 1: 40 ohm
          - CPU phase 2: 1.1k
          - GFX unique phase: 1.1K
          Maybe phase 1 is not working properly and hence I have an vcore of 0.5v, just a half of what it should be? But in this case, the feedback circuitry should not detect the voltage mismatch and reach the correct vcore voltage by using phase 2? Also measuring these resistance values just after turning off the board give different results that measuring them after leaving it to cool down for some time. The values indicated before correspond to this last situation.
          This charging IC does not have SMBUS capabilities. It is a pretty isolated subsystem with few and simple control signals, this is why I decided trying bypassing it.
          • teknosrp
            • Nov 2018
            • 9
            • netherlands
            Originally posted by teknosrp
            Hello
            - CPU phase 2: 1.1k
            Today I have tried removing the resistor (PR251) between the driver chip (ISL95831, PU12) and phase 1 high side mosfet (PQ61). After doing this, I still have a 40 ohm resistance between driver output to ground, but a high resistance between PQ61 gate and ground. This means that the ISL driver chip is gone?
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • Thomasraud
              Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
              by Thomasraud
              i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
              QUOTED
              -It works on charger (without battery connected-only charger)
              -It works on battery (without charger connected-only battery)
              -& it also works when plugged in battery & charger, but it's not charging the battery
              //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
              and..
              QUOTE
              The IC cannot maintain the input current level
              06-28-2022, 06:47 PM
            • Scoff
              HP Probook 470 G4 - Power and Charging Problem
              by Scoff
              Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
              Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
              07-03-2023, 09:28 AM
            • SluggerB
              Help with trying to fix phone that is not charging (Pics inside)
              by SluggerB
              I have two TCL A30 phones.
              Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
              New Phone: Works fine, bought as a donor board to try and repair Old Phone
              My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
              08-12-2024, 08:11 AM
            • Wang Tingting
              Acer Nitro 5 AN515-57-536Q not charging
              by Wang Tingting
              I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
              report is also good for battery.
              Following https://www.badcaps.net/forum/troubl...arging-circuit,
              • DCIN/VCC: 19.1
              • ACIN/ACDET: 3v
              • REGN/VDD: 6v
              • CMSRC : 19v
              • ACOK: 3.3v
              • ACDRV: it is 19v, not 25V(when charging, the ACDRV
              09-10-2025, 01:46 PM
