hp 250-g6 \la-e802p no power
  • Rekoo1997
    • Oct 2018
    • 26
    • Egypt
    I have la-e802p Mainboard
    +19V_VIN ok
    +19VB not found and ACDRV not found
    PRB9 is ok
    if connect battery and chrarger the device work on battery
    i changed ic CHARGER but same problem
    Can anybody let me know what I'm missing?
  • mon2
    • 14663
    Re: hp 250-g6 \la-e802p no power
    1) Link or post a schematic if available for this mainboard.
    2) https://www.badcaps.net/forum/showthread.php?t=90356
    3) power down -> remove the battery -> review the logic board -> locate the DCin connector.
    Review the usual 2 x DCin mosfets near this connector. What are the markings on these parts ?
    Near these parts will be the charger IC with 'BQ' or similar markings.
    What are the markings on the charger IC ?
    Often the fault you have raised are linked to the DCin mosfets. We need confirm if they are defective or not using resistance checks.
    With no power -> meter in resistance mode -> check the resistance of each mosfet as follows:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    post each measurement and the scale used on your meter for these tests. If the resistance is low, the mosfet is defective and must be replaced.
    • Rekoo1997
      • Oct 2018
      • 26
      • Egypt
      all DCin mosfets and chargind mosfet is ok
      • mon2
        • 14663
        Measure and post the voltage values for:
        Vcc pin 20
        REGN pin 16
        ACDRV pin 4
        CMSRC pin 3
        for charger IC @ PUB1.
        • Rekoo1997
          • Oct 2018
          • 26
          • Egypt
          Vcc pin 20
          REGN pin 16
          ACDRV pin 4
          CMSRC pin 3
          pin 20 = 19.57
          pin 16 = 6.08
          pin 17 BTST = 5.87
          pin 4 = 0.77
          pin 3 = 0.77
          • Rekoo1997
            • Oct 2018
            • 26
            • Egypt
            Can anybody help me
            • mon2
              • 14663
              1) With no power -> meter in resistance mode -> check the resistance of each mosfet as follows:
              2) Measure the voltage on each pin of the charger IC and post the readings.
              • Udemzy
                • May 2017
                • 164
                • Guatemala
                Originally posted by Rekoo1997
                pin 20 = 19.57
                pin 16 = 6.08
                pin 17 BTST = 5.87
                pin 4 = 0.77
                pin 3 = 0.77
                Since pin 4 is not available then ACOk is not available,in other to generate this you have to follow this steps.
                You already changed the charging ic and problem still persist,I believe the charging IC you changed is fine,if yes then check the impedance of ACOK, check the impedance of CMSRC and ACDRV and also check the communication via continuity of ACP and ACN to CLR.
                Don't forget to check the impedance of charging MOSFET and discharging MOSFET too.
                These are very important to generate ACOK/ACDRV
                • Rekoo1997
                  • Oct 2018
                  • 26
                  • Egypt
                  Thank you my friends
                  I changed all the charging MOSFET and discharging MOSFET
                  And the device is working properly
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Mita99
                    Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                    by Mita99
                    Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                    Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                    Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                    04-27-2025, 07:20 PM
                    03-31-2024, 02:12 PM
