X555LD Rev2.0 No Power No Mainboard Could you help
  • carso
    • Apr 2021
    • 6
    • türkiye
    Hello there
    X555LD REV 2.0 i7 4510u processor
    I closed and moved it while working, when I tried to open it again, there was no response
    I took the motherboard out and tested the power line with a multimeter
    I/O was heating up, we tried plugging in another chip, now the same chip doesn't heat up but still no power
    They said the processor south passed away but I want to be sure. What check should I do with the multimeter?
  • mon2
    • Dec 2019
    • 14258
    Re: X555LD Rev2.0 No Power No Mainboard Could you help
    Update:
    False alarm. See attached.
    Put away the non-alcoholic beverages. It is a capacitor and the readings are ok.
    • carso
      • Apr 2021
      • 6
      • türkiye
      Originally posted by mon2
      Update:
      i think about it
      I couldn't clarify whether this is the coil of the processor, I don't have a schematic reading
      So there's 19V to this marked place, where does it come from?
      • mon2
        • Dec 2019
        • 14258
        I believe to have both, the boardview and schematic files for this logic board or something very close to it. Will post more details after some beauty rest.
        In the meantime, the parts you show are the typical dcin mosfets.
        Post the markings from the top surface of each mosfet do we can compare notes.
        Remove all power. Meter in resistance mode.
        Check the resistance across the mosfet pins as usual:
        Source and drain
        Source and gate
        Gate and drain
        See the many many posts here on this forum about the same checks. If the resistance is too low, then the mosfet is defective and must be replaced.
        Do note the pin #1 of the original mosfet so it can be replaced. Take close up pics and post them here.
        Quite often, one or both of these mosfets get damaged. Read the sticky above from @Piernov for more details.
        • DanielDacko
          • Mar 2015
          • 325
          • Macedonia
          Here is the boardview and software used for viewing it.
          I don't provide help for people using CH341A and a clip.
          • carso
            • Apr 2021
            • 6
            • türkiye
            Source and drain
            Source and gate
            Gate and drain
            Do you have the X555 full schematic? can you share it?
            Which is the mosfet that controls the processor (to check if there is a short circuit)
            Your help is very helpful
            • carso
              • Apr 2021
              • 6
              • türkiye
              Hello
              This is where I start checking the circuit.
              when performing a robustness test at the diode location with a multimeter
              I did it without realizing it. The device worked and displayed as it appeared.
              I made a chassis with a multimeter.
              Screen VİDEO
              • mon2
                • Dec 2019
                • 14258
                Test without the RAM stick. Any difference?
                • carso
                  • Apr 2021
                  • 6
                  • türkiye
                  It works on ram with its old version.
                  there is no problem, it works with its current state, it is very strange
                  Thanks for everything, for adding something.
                  • t.danes
                    • Jan 2016
                    • 8
                    • ba
                    what are the designations and values of these components? one is a capacitor and the other is a resistor, I just don't know their value. thanks for the help, I didn't find the schematic, if someone has I would be grateful
                    • mon2
                      • Dec 2019
                      • 14258
                      Attached.
                      R2525 = 0402 size as well.
                      • t.danes
                        • Jan 2016
                        • 8
                        • ba
                        Attached.
                        • Serg9798
                          • Aug 2019
                          • 18
                          • Ukraine
                          Thank you very much.
                          • Mirenia
                            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                            by Mirenia
                            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                            03-30-2025, 06:47 AM
                          • orcic
                            MASTER TL240 and new mainboard LW36BKC01
                            by orcic
                            I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                            The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                            After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                            Now I have some doubts about how to connect the new mainboard to the old power supply.
                            First of...
                            05-12-2023, 08:10 AM
                          • Devonavar
                            Vizio M43-C1 - How closely do I need to match the mainboard number?
                            by Devonavar
                            I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                            I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                            Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                            So, I've ruled out the PSU for now.
                            The reboot loop...
                            08-14-2022, 08:46 PM
                          • Malva
                            Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                            by Malva
                            I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                            Mainboard model: EAX65684604
                            PCB marking: EBT62954607
                            SPI chip: Winbond W25X20CLNIG Problem description:
                            Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                            After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                            • I bought another
                            06-25-2025, 02:07 PM
                          • l0lhaxz1
                            QN65QN90A - Mainboard MLCC failed - now bootloop
                            by l0lhaxz1
                            Hi
                            I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
                            Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
                            Came to learn after a bit more research...
                            02-06-2023, 08:59 AM
