Macbook Pro 13" A1706 820-00239 No power 20V 0A PP3V3_S5 not stable
  • GfilipeZ
    • May 2021
    • 43
    • Portugal
    This Logic Board suffered water damage.
    PPBUS_G3H = 13,09V
    When i started to check S5 power rails stage, i found that PP3V3_S5 was not stable.
    So I started to check from the beginning, SMC_PM_G2_EN. I took off R8110; then R9160 and finally U7650. Then i realized that PM_EN_PVXS5 only starts to oscillate when enter in U7650.
    I already tested with 2 different U7650, and with same result. So i suppose is ahead of U7650.
    Checked all power rails from schematic page 100 and 101, and no shorts, no low resistance.
    Any ideas?
  • mon2
    • 14592
    Re: Macbook Pro 13" A1706 820-00239 No power 20V 0A PP3V3_S5 not stable
    What is the voltage of
    SMBUS_SMC_5_G3H_SCL ?
    • GfilipeZ
      • May 2021
      • 43
      • Portugal
      The voltage is 3,4V but not stable. Varies between 2,9V 3,1V 3,4V.
      • mon2
        • 14592
        Voltage of PP5V_S4 ?
        SCL is a clock line so ok to fluctuate.
        • GfilipeZ
          • May 2021
          • 43
          • Portugal
          Of course, SCL
          PP5V_S4 = 0V
          PP5V_S5 is oscillating, not stable.
          • mon2
            • 14592
            What is the voltage you are measuring @ PP5V_S5 ?
            What is the voltage of P5VS5_EN (Pin #12, U7650)? Is it stable or oscillating ?
            The PP5V_S5 rail is a LDO output from U7650 which may be defective.
            Remove all power. Meter in resistance mode.
            Check the resistance to ground of PP5V_S5 (C7651, pin #1).
            • GfilipeZ
              • May 2021
              • 43
              • Portugal
              I'm measuring PP5V_S5 on C7651.
              P5VS5_EN also oscillating.
              I already tested with 2 different U7650, same thing.
              C7651-1 = 497,2Kohm (edited)
              • mon2
                • 14592
                Confirm if SMC_PM_G2_EN is oscillating.
                voltage of ALL_SYS_PWRGD ?
                • GfilipeZ
                  • May 2021
                  • 43
                  • Portugal
                  "Confirm if SMC_PM_G2_EN is oscillating." Yes, it is. If i take of U7650 it stabilizes.
                  ALL_SYS_PWRGD = 0V
                  • mon2
                    • 14592
                    ALL_SYS_PWRGD = 0V
                    So one or more of the voltage is not good and this line is pulled low to indicate this failed status.
                    Could be due to missing pull-up voltage PP3V3_S0 @ R7805 since you are not in this power state.
                    Remove all power, meter in resistance mode -> check the resistance to ground of this enable pin SMC_PM_G2_EN .
                    • GfilipeZ
                      • May 2021
                      • 43
                      • Portugal
                      Resistance is 100Kohm.
                      • Danielreinaa
                        HELP need password bios Macbook A1706
                        by Danielreinaa
                        Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                        Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                        Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                        gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                        Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                        09-07-2024, 03:47 PM
                      • moderator
                        A1706 - emc 3107 bios
                        by moderator
                        a1706 Bios file i am uploading , need cleaned, its not password locked..macbook is booting ..getthing chime also.but stuck on apple logo..in target mode disk is recognised and i was able to copy data...it happened while changing the touchbar
                        Serial number is C02STA7EHF1P
                        its A1706 - emc 3107...
                        05-17-2024, 07:00 AM
                      • mkdj
                        MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                        by mkdj
                        About me, my goal and the equipment I (don't) have:
                        I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                        About my issue and my goal:
                        A friend of mine has a MacBook Air M1 A2337 that does not...
                        04-03-2025, 08:28 AM
                      • capon5153
                        Macbook A1706 works perfectly but no data on USB C
                        by capon5153
                        hello,
                        so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                        i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                        06-22-2025, 09:42 AM
                      • madjid911
                        A1706 No power
                        by madjid911
                        Hello, I have a macbook a1706 (820-00923-A) that does not turn on, the 20v ubc triggers but no power consumption, no short and no liquid damage, PPBUS_G3H: 0V15 (16mohms no short), U7000 is well powered by the 20V, I looked at everything around the ISL9239 chip the resistors are good, so I replaced the chip twice but the result is the same, my skills stop there can you help me please?
                        02-17-2025, 12:32 PM
