iPhone XS Data recovery from NAND flash
+ More Options
Posts
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Hey guys, I have an iPhone XS which came in as dead. The phone was not worked on before (I was the first to open it). After diagnosis (Splitting board, etc) it's confirmed to have a shorted PP2v63_NAND line.
    Removed the NAND flash and short is gone on the board. Measuring directly on the NAND, there is about 2 to 15ohm to ground.
    Is there anyway of backing up data externally in such cases (Client has some very important files and no back ups)?
  • mon2
    • Dec 2019
    • 14148
    Re: iPhone XS Data recovery from NAND flash
    https://youtu.be/4RwGsbk1aos
    Consult with Jessa at ipadrehab.
    Search out her YouTube videos.
    May be practical to send in the phone to her but first relay your findings.
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      Watched a bunch of her videos in the past. I also contacted them, but its either send the phone or pay for forum. Since the customer is not ok paying for that, am not gonna bother.
      The video assumes the motherboard is damaged but nand chip is still OK. In my case the motherboard is OK but the NAND chip itself has a shorted PP2v63_NAND internally.
      Rephrasing my question: Is PP2v63_NAND required for an external nand clone?
      • mon2
        • Dec 2019
        • 14148
        Hmm. Too much fame for her I suppose.
        If the NAND is shorted, how can you be sure the contents are ok at this stage of the review ?
        We briefly did some searches in the past on NAND flash readers and tools - REWA should have these and they should be able to supply some answers.
        My concern is that the NAND flash is THE storage device yet the client is wanting their data to be extracted. Is it possible that some component on this power rail is shorted and not the NAND flash IC itself ?
        What are the details of this short? You have measure the resistance to ground of this NAND power rail ?
        Can you index the part # from the schematic and where you are observing the short ? Will check the schematic once at the office.
        Also post the logic board # so we are referencing the same.
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          It's called hope, lol But on a more serious note, I assume the power does not go directly to the internal array but through some other circuitry first.
          Correct, the NAND is the storage. My hope is that, using an external reader, maybe the 2v63 power rail is not needed (since there are also some other IO power rails).
          No, it's the NAND itself that is shorted since after removing it from the board there is no longer a short when measured on the board itself. But when measured on the NAND chip (by itself), the short is there (measure wrt to ground in both case).
          Short Values:
          2 to 15ohms (wrt to ground). Weird thing is, when it's left to rest with no power for over 10hours, the resistance increases to 30-40ish ohm but as soon as power is applied, it drops back to 0.8 - 2 ohm then stabilizes to 2-15ohms after a few minutes.
          Note:
          NAND would also get warm when power is applied. All caps on the shorted line was examined an showed no signs of damage. Those which looked even slightly suspicious were removed. As a last resort, the NAND itself was removed to give a definite fault location.
          NAND Flash is U2600 (per phoneboard viewer - iphoneXS Core board). PP2v63_NAND is the affected power rail.
          • mon2
            • Dec 2019
            • 14148
            Review this article:
            https://www.ipadrehab.com/article.cfm?ArticleNumber=33
            The nand, even if good enough to read, is encrypted.
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              Yes, its encrypted. Am not looking at reading/accessing the user data on a PC but more to clone the data from 1 nand to another known good nand then resolder the cloned nand back to the board. Data will be accessed through the phone itself.
              • repair_schematics
                • Aug 2022
                • Sweden
                Yes the NAND is crypted.
                There doesnt exist any readers for those new Iphone NANDs.
                Noone has reverseegineered the controller and protocol used.
                The only readers that exist are those that can read out config area of NAND.
                Userdata and firmware is not possible to copy with a desoldered NAND chip.
                To be able to read this NAND you probably need to inject that voltage on correct part "inside" NAND and isolate the short.
                After that solder repaired NAND back and extract the data you want with working phone.
                I think this is only a good idea in theory.
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  @repair schematics, thank you for your insight.
                  I was also considering scrapping up the top part to access the internals, but since I dont have any similar spare to practice on, i'ld rather avoid. I watched a video where this was successfully done on an iPhone wifi chip but cant find any info/pics of a decapped NAND.
                  Looks like this one will be going to trash.
                  • mon2
                    • Dec 2019
                    • 14148
                    Contact REWA for advice before throwing in the towel. Slim chance here but still not zero.
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      @mon2: I did try contacting them but no reply so far :/
                      • DoOm86
                        Swap nand flash smartphone for data recovery
                        by DoOm86
                        Hello everyone.
                        I would like to know more about the following topic:
                        Nand flash on smartphone for data recovery.
                        I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
                        But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
                        How does it works? How do I know if data are encrypted or where is the key?
                        I know there are also very expensive external socket where you can put the nand flash in...
                        08-20-2023, 07:10 AM
                      • SluggerB
                        Help with trying to fix phone that is not charging (Pics inside)
                        by SluggerB
                        I have two TCL A30 phones.
                        Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                        New Phone: Works fine, bought as a donor board to try and repair Old Phone
                        My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                        08-12-2024, 08:11 AM
                      • Deeloc
                        How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
                        by Deeloc
                        I have a 1tb WALRAM SSD (Photo)
                        Controller SM2259XT2G (photo)
                        Samsung memory (photo):
                        Part Number K9DVGB8J1B DCK0
                        Name V-NAND V6
                        Type TLC
                        The SSD itself is detected as 1gb, but is not initialized.
                        There is a Sata to USB adapter
                        A lot of SMI MPTool, did not flash it. compare flash fail (17)
                        K9DVGB8J1B is not listed anywhere
                        What to flash?​...
                        06-05-2024, 08:32 AM
                      • corrize
                        Nikon D800 camera - flash don’t work and capacitor don’t charge
                        by corrize
                        Hello, I'm stuck in troubleshooting…
                        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                        10-01-2022, 10:02 AM
                      • keeney123
                        new OS on a Sonim XP5s phone
                        by keeney123
                        To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                        I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                        05-13-2022, 07:19 PM
