HP - LA-D704P Rev 1.0 No Power Motherboard HELP
  • mon2
    • Dec 2019
    • 14673
    Re: HP - LA-D704P Rev 1.0 No Power Motherboard HELP
    It is important to note again that the mosfets attached to pu301 are dual mosfets inside the single package.
    Post your measurements and the pins used for each resistance check.
    • harshana
      • Aug 2022
      • 216
      • Sri Lanka
      #42
      I will share the measurements soon.
      • harshana
        • Aug 2022
        • 216
        • Sri Lanka
        #43
        PQ301(Mosfet removed. values taken from the pad)
        Source(5,6,7) to drain(2,3,4) -----> 6.38kohms
        Source(5,6,7) to Gate1(1)-----> No value
        Source(5,6,7) to Gate2(8)------> No Value
        drain(2,3,4) to Gate1(1)-----> No value
        drain(2,3,4) to Gate2(8)------> No Value
        D2/S1(pin9) to ground-----> 0.4ohms (this is the short I guess)
        PQ302(Mosfet is on the board)
        Source(5,6,7) to drain(2,3,4) -----> 6.36kohms
        D2/S1(pin9) to ground-----> 8.07kohms
        • harshana
          • Aug 2022
          • 216
          • Sri Lanka
          #44
          • harshana
            • Aug 2022
            • 216
            • Sri Lanka
            #45
            Any luck
            • harshana
              • Aug 2022
              • 216
              • Sri Lanka
              #46
              waiting for a reply
              • mon2
                • Dec 2019
                • 14673
                Putting out our own local fires so immediate replies are not always possible. Have an ipad from h*ll that almost burnt the owner's hands - good job Apple / Foxconn. Wage bonus for the design engineers. Just purchased the over priced thermal camera from Qianli which is not really helping. Any metal object is showing a higher temp than the parts. My hands are on 'fire' from the thermal view. Perhaps a learning curve here...
                Not good. So the short is either INSIDE the power supply IC @ PU301 if it is still soldered onboard OR could be downstream since the inductor PL302 is onboard.
                Start with lifting one leg of PL302 coil / inductor. Once this leg is removed, check the same pin # 9 of the dual mosfet resistance to ground.
                If the short is gone, then the short is INSIDE the power supply IC PU301.
                Post your test results.
                • harshana
                  • Aug 2022
                  • 216
                  • Sri Lanka
                  #48
                  Ops. sorry to hear about that.
                  actually PU301 already desoldered. still short on the pads.
                  • harshana
                    • Aug 2022
                    • 216
                    • Sri Lanka
                    #49
                    Not only the PU301. the power supply also removed from the board. So we can make sure the short isn't because of the power supply
                    • mon2
                      • Dec 2019
                      • 14673
                      Do you see a solder blob @PJ330 ? As a quick test, lift up one leg of PC309 capacitor.
                      Check if the short is still there. This power rail feeds all over the board but check this cap first.
                      • harshana
                        • Aug 2022
                        • 216
                        • Sri Lanka
                        #51
                        It's really hard to find components because the schematics part numbers are different from the what I see on the PCB.
                        Already removed that Capacitor but still short present.
                        • mon2
                          • Dec 2019
                          • 14673
                          With care, inject 1v onto this shorted line and check to see which part heats up.
                          Again, we want to keep the voltage low so that it does not kill the CPU, in case this rail reaches the CPU due to a leaking mosfet. It is possible the CPU is the fault but you will know from the heating up of the component.
                          • harshana
                            • Aug 2022
                            • 216
                            • Sri Lanka
                            #53
                            Already Injected 0.8v @ up to 5A and no one was heated. you can see that on our past messages. I removed the heat sink to test cpu as well. nothing found with my finger tips.
                            unfortunately I don't have a thermal camera to see a better view.
                            Do I need to inject again or whats next?
                            • mon2
                              • Dec 2019
                              • 14673
                              We just purchased a $1k thermal camera - so far not impressed with the results. The only thing heating up is my body heat and fingers as they traverse under the camera.
                              Trying to locate a part that may be causing the ipad to stall @ 467mA - others are reporting this fault as well. Some videos claim a bad cap but so far unable to find one.
                              Remove all power. What is the resistance to ground of your CPU Vcore rail ?
                              • harshana
                                • Aug 2022
                                • 216
                                • Sri Lanka
                                #55
                                I see 4 Inductors.
                                1---> 18.2ohms
                                2----> 17.6ohms
                                3----> 32.7ohms
                                4-----> 0.4 ohms
                                See the attachment.
                                • mon2
                                  • Dec 2019
                                  • 14673
                                  When you inject the voltage at the earlier 3v3 site, do you see any voltage at the coil with the 0.4 ohms ?
                                  • harshana
                                    • Aug 2022
                                    • 216
                                    • Sri Lanka
                                    #57
                                    1v with 2.4A injected again.
                                    No voltage at any of those 4 coils.
                                    • mon2
                                      • Dec 2019
                                      • 14673
                                      Yet, someone is consuming this current when you inject the voltage. The part is just not warm or hot enough for you to sense the location. Perhaps the part is on the bottom side?
                                      At your discretion, this is risky, but you can consider to dial up the voltage to a higher voltage but must remain under the expected 3v3 (max). Suggest, perhaps 1v5. Test again with the injection. The risk is if some mosfet is leaking and hits a low voltage rail at which point this higher voltage will kill that part.
                                      • harshana
                                        • Aug 2022
                                        • 216
                                        • Sri Lanka
                                        #59
                                        Injected upto 2.7V at max 5A. I'm afraid to go more. however nothing heats up. How is that possible. I checked both sides of my board. nothing heats up.
                                        However after 2-3 minutes My DC power supply fan gets on. I guess he is the person who heat by seeing this.
                                        What can we do?
                                        • harshana
                                          • Aug 2022
                                          • 216
                                          • Sri Lanka
                                          #60
                                          Still I have no Idea whats wrong with this. can't we disconnect sections one by one from 3v and test. worst thing is, there is no actual Schematics and also boardview file
                                          • glovecaps
                                            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                            by glovecaps
                                            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                            11-25-2024, 04:23 PM
                                          • Docus
                                            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                            by Docus
                                            Hi everyone 😀,
                                            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                            1. I already own the exact same model, but its plastic chassis is badly damaged.
                                            06-10-2025, 04:24 PM
                                          • Archimedes
                                            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                            by Archimedes
                                            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                            Fans are spinning. Blindly could install windows11 and got the device manager...
                                            07-30-2024, 05:14 PM
                                          • dragon3x
                                            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                            by dragon3x
                                            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                            power on.
                                            Here are some examples :
                                            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                            switching supply area).
                                            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                            than 6.3 V.)
                                            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                            I replaced capacitors with aluminum-polymer.
                                            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                            03-21-2025, 02:46 PM
                                            ASUS P5GC-MX motherboard recap
                                            by momaka
                                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                            So here is what the motherboard looked like with its original caps:
                                            CPU VRM area up close…...
                                            01-27-2021, 11:59 PM
