how to test power button when it is on keyboard
  • koby058
    • Jan 2017
    • 383
    • israel
    Hi
    Is there a generic way to test power button voltage or to power on a laptop without schematics when power button is on keyboard ?
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: how to test power button when it is on keyboard
    Originally posted by koby058
    Hi
    I guess that would be dependent of the Manufacturer and the model of the laptop. Of course, one could press the power button and if the unit did not turn on then one could assume a problem. It would be near impossible to diagnose a dead laptop without opening it because most connectors on the outside of the laptop are outputs. Even if one used a connector that has the ability to also input data, the unit would need to be up and running. I am sure if the keyboard could be removed there are testers that can power up the keyboard and test the keys if the unit is not running. Otherwise, one would have to determine if the power key is just a switch to power the unit on or if there is some type of strobe pattern that is going to the power key that another component is looking for then start up a power up sequence.
    • reformatt
      • Feb 2020
      • 1418
      Power buttons on keyboards can be metered usually at the last two pins of the keyboard connector, at least this is what I've found so far. One of the two will be ground of course, determine that with your meter. The other should be pulled up to 3.3V, and go low when power button is pressed. You can short these two pins with tweezers of course to see if lappie fires up. Had plenty of Acers with bad power buttons on the keyboards, and the tweezer method just confirms it. Also had plenty where the button is always triggering too, resulting in the laptop switching off randomly.
      • myth77
        Asus Gl753, gl553, fx553 keyboard power button not working
        by myth77
        I have i think 4 dead keyboards from laptops in the title...they are very similar...almost the same...and all of them have not working power buttons. All other keys are working...but when you press power button it doesnt short 3.3v to gnd...so you can only do it manually on the keyboard conector with tweezers or similar. I inspected in every detail ribbon cable that is going to the motherboard connector and removed power key button from keyboard to see anything wrong there, but all seems perfect.
        Has anyone with more expirience figured where is that power button line getting broken? because...
        07-13-2023, 12:30 PM
      • Till
        Broken power button (keyboard). How to jump start notebook?
        by Till
        Hi
        Yesterday while browsing the internet with my laptop I noticed that 3 keyboard buttons were not working anymore.
        Today, the notebook doesn't boot anymore. My assumption is that the keyboard went bad because the power button is on the keyboard.
        Is there a way to jump start directly from the motherboard?
        I tried to short all the pins of the connector for the keyboard cable with no luck.
        I found the schematics here on badcaps, but I didn't find the pin out for the keyboard. But truth be told, I am just a hobbyist who tries...
        07-31-2023, 06:33 PM
      • reessi
        Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
        by reessi
        With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
        No corrosion any where!
        Tried a replacement power button off ebay and the same.
        Very occasionally it will work with the power button connected!
        Same results with or without the battery.
        Can it be a fault with the Audio board or the mainboard?
        The touch Id assembly connects through the Audio board first then to the Mainboard.
        Flex...
        06-26-2024, 03:31 PM
      • dfear
        MSI GP62 6QF - powers on, keyboard and power button lights up, then switches off.
        by dfear
        Motherboard is: MS-16J51 (i think).
        Symptoms:
        1) press power button: keyboard and power button leds light up.
        a) nothing on the screen.
        b) fans are not spinning.
        c) no sounds.
        2) after about 1 min 15 secs the laptop switches off.
        Video of the issue: https://youtu.be/Q913lEgnYZ4
        I have tried flashing the bios, which I download from:
        here.
        Not sure this board has a separate flash chip for the EC....
        08-03-2022, 03:06 PM
      • modtool
        HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
        by modtool
        Dear colleagues,
        I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
        The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
        Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
        05-07-2025, 06:10 AM
