Any substitute for TPS51285BRUKR_QFN20_3X3?
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    is there any substitute for ic TPS51285BRUKR_QFN20_3X3?
  • Bonzas
    • 472
    • Indonesia
    Re: Any substitute for TPS51285BRUKR_QFN20_3X3?
    https://www.badcaps.net/forum/showthread.php?t=76936
    worth to try
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Replace it with 51225C
      • usyusy
        • Sep 2021
        • 171
        • Pakistan
        sir so nice of you, thank you
        • usyusy
          • Sep 2021
          • 171
          • Pakistan
          Sir if we replace it with such ic (like TPS51225RUKR) which has only 3v Ldo always-on, what can be happen
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • RetroComputingGrotto
            Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
            by RetroComputingGrotto
            I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
            As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
            What is your advice/opinion on whether or not on old(er)...
            04-03-2024, 08:30 AM
          • learnmore
            How to choose a substitute mainboard
            by learnmore
            Hello again Community
            Anyone verse on how you go about choosing a substitute mainboard for your TV repair. Like the chap in the video below sometimes a 1:1 replacement board is too expensive and reballing a mainchip(s) maybe outside of your skillset . In the video the poster states one needs to match the replacement board with the SMPS, T-con (if not built in) and panel (and substitute cabling be also be required).
            I'm very interested in choosing a suitable replacement board for any model or make of TV and the general (or detailed if your willing) step this entails....
            03-23-2024, 02:55 AM
          • bembeno
            Need help in replace io Lenovo NM-C911 Rev: 1.0 GY550
            by bembeno
            I have to replace Io lenovo it 8227E so i want to know will it need to write ec firmware...
            10-22-2025, 12:04 AM
