Ic 1285a replacement
  • kadi144
    • Aug 2015
    • 690
    • algerie
    hi
    i need a compatible -replacement of ic power IC 1285A in asus laptop
    thanks
  • khaahk
    • Dec 2013
    • 814
    • Estonia
    Re: Ic 1285a replacement
    https://cdn.badcaps-static.com/pdfs/...bc7e0fa746.pdf
    Replacement might be 51225b/c
    https://cdn.badcaps-static.com/pdfs/...2c6e6f33b6.pdf
    but not sure, if possible use original.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      tps51285 can be replaced with tps 51225. i have done it succesfully on asus mb TP550
      • kadi144
        • Aug 2015
        • 690
        • algerie
        thanks i will try
        • chronic519
          • Feb 2015
          • 13
          • canada
          hello, I am in the same situation. I have the tps 1285a and can only get the tps 1285b. Are they the same? We all come across asus ROG laptops? If so, was the overheating a give away?
          • Elwazeery
            • Aug 2020
            • 1
            • Finland
            I have the same problem
            Asus rog laptop
            How can I solve it?
            I can't find the same ic
            • efrain
              • Oct 2017
              • 12
              • colombia
              rt6585b = tps51285B
              Replacement
              equivalent ic
              • ZoOLf
                • Mar 2021
                • 61
                • NA
                What was the problem that needed to change this IC?
                • sikocan
                  • Oct 2019
                  • 344
                  This idea didn't work well on a ASUS UX550GD - High Side Mosfet for 3.3V rail kept burning.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    It works. you may have problem in load side. Remove the IC and check resistance on LDO lines. Do check all the fets for short.
                    • flayer23
                      • Apr 2012
                      • 13
                      • france
                      replacement of ic power tps51285A by tps51225 work for me in toshiba c50 m/b :pt10f
                      • nassimhamdi
                        • Feb 2016
                        • 150
                        • algeria
                        great
                        • Robin21
                          • Feb 2021
                          • 55
                          • the Netherlands
                          Originally posted by efrain
                          rt6585b = tps51285B
                          Replacement
                          equivalent ic
                          Thank You! I'll test it today.
                          • koby058
                            • Jan 2017
                            • 387
                            • israel
                            Hi
                            possible to replace TPS51285B with TPS51285A ?
                            https://www.ti.com/lit/ds/symlink/tp...oogle.com%252F
                            • reformatt
                              Macbook Air M2 A2681 Kernel panics after screen replacement
                              by reformatt
                              Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                              It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                              07-31-2025, 08:37 PM
                            • the_rem
                              Unknown transformer : how to find a good replacement part ?
                              by the_rem
                              Hello guys,
                              I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                              I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                              04-23-2025, 01:48 AM
                            • ezenia
                              PS4 controller left stick potentiometer replacement issue
                              by ezenia
                              Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                              So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                              I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                              09-30-2023, 02:19 PM
                            • boosti45
                              Macbook pro logic board replacement parts quesion
                              by boosti45
                              i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                              08-21-2024, 05:23 AM
                            • r2digital
                              klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                              by r2digital
                              I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                              04-18-2024, 03:50 PM
